Hi and good evening,
the template-Node below contains two figures:
<svg version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink"
width="350" height="400" xml:space="preserve" id="OG">
<g>
<rect fill="rgb(249, 0, 0)" x="80" y="200" width="75" height="75" rx="2" />
</g>
<g>
<path fill="rgb(0, 249, 0)" d="M 125 0 L 75 100 L 175 100 Z" />
</g>
</svg>
While NodeRed colours the rectangle correctly red, the path is drawn with the Base Setting Colout of the dashboard. A similar html-example in chrome is working as expectedt (rectangle = red , path = green).
What's the reason and how to overcome the issue?.
Thanks a lot
