Hey Guys,
Cant find an answer for this.. not sure there is a way to do it.
Is there a way to monitor a template node that is displaying a MJPEG feed to make sure its active?
The MJPEG feed is a .cgi from a VLC transcode
Hey Guys,
What does active mean ? Its sitting there waiting for data OK ? Or data is arriving ? Or ...
You can put whatever code you like in your template and use it to either create an output or node status
Hi!
I have a MJPEG stream running in a template which is being transcoded from command line VLC which creates a .cgi stream on port 8888
I would like to monitor when that isnt displaying and refresh it... I cant think of a way to do it hence why i thought id throw it out there
so presumably there is code in there to grab the data when it arrives ? use that to also start/reset a separate timer loop - if it times out (nothing arrives) then change the node.status
So would a status node work for this?
err sorry thinking about it this is a ui node so no... - but it can just send regular output. (as if it was a button etc)
Not sure what you mean.. could you elaborate a bit
You can use a http request node, enter the vlc url, if it returns 200 you know it is alive.
