Text Align in Ui_Buttons
I obeyed the rules ... but there is always a way as I tried to point you to:
place this into a template node & select:
<style>
    button {
        text-transform: none !important;
        text-align: left !important;
        padding: 0px 10px !important;
</style>
you can play arround with the HTML parameters as you like. Building a UI around all of them and maintain them is a lot of work and will never please everybody. So to stick to an accepted set of rules and give a way to break them is totally understandable.
!important is "important" this prevents your properties to be overwritten later.
[{"id":"643d17deb8e3a719","type":"ui_button","z":"db39bbbe01b608ed","name":"","group":"e8592788a2921318","order":2,"width":0,"height":0,"passthru":false,"label":"Test me 😁","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"topic","topicType":"msg","x":950,"y":300,"wires":[[]]},{"id":"736d918fa650ae76","type":"ui_template","z":"db39bbbe01b608ed","group":"e8592788a2921318","name":"Style Button","order":3,"width":0,"height":0,"format":"<style>\n    button {\n        text-transform: none !important;\n        text-align: left !important;\n        padding: 0px 10px !important;\n    }\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","x":950,"y":340,"wires":[[]]},{"id":"e8592788a2921318","type":"ui_group","name":"Basics","tab":"3c1f8373e77c2cdd","order":1,"disp":true,"width":"20","collapse":true},{"id":"3c1f8373e77c2cdd","type":"ui_tab","name":"uPlot","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
