Button text forced to uppercase
For the first time I am using a dashboard button and I notice that the text on the button is always in uppercase, whatever I put in the button configuration. Is that expected?
Node-RED version: v1.0.2
Node.js version: v10.18.1
Dashboard version 2.17.1
Running on Ubuntu.
This intentional and based on the material design design guidelines:
You can change the behaviour by adding text-transform: capitalize; to the button style.
That isn't really what I want either, I just want the text displayed as entered. Or do you mean that if I force text-transform: none then it will leave them alone?
Indeed, if you use text-transform: none; then it will will stay as it was.
OK, thanks.
where to add text-transform: none;?
To ui_button.html?
you can add the following to a ui_template node set with template style "Added to site head section":
<style>
button{
    text-transform: none !important;
</style>
