I have a dashboard text node that's 44 units across that's not showing up in the layout mode. It was 30 units across and was located on the layout screen. Once I changed it to over 30 units in the properties tab, it disappeared. The dashboard only allowed me to push the text node to 30. It would not let me go past 30.
Hi yes that is indeed a hard limit in the layout editor - we can try bumping it up and see what happens. You can still use the manual layout option of the sidebar to locate the text widget where you wish it to appear.
