Is there a node that allows text entry in the flow editor? Similar to an inject node, but where the text-entry box is always open.
I want to use this for setting flow variables. Ideally, it would also show the current value that a variable is assigned to (The node-red-show-value node already performs this duty).
I have searched Google and this forum, but not found anything like this. Thanks in advance for any help.
I assume this is mostly for debugging / validating flows?
I think it would be a bit difficult to do directly in the 'flow editor' itself, but easy to do using the 'node-red-dashboard'. Use Manage Palette, install the 'node-red-dashboard', make sure to add a new Dashboard page, add 'ui_text_input', add an 'OK' button, and then go visit the URL of the small page it creates - e.g. : "http://localhost:1880/ui". You will see a section for displaying / entering text and the button.
Bind the click event from the OK button to write to a variable. Then each time you click the button the contents of the variable are updated.
Cheers,
Paul
If you leave the inject config window open you can edit the payload or whatever property - and then hit
without having to re-deploy.
Those are both decent options. Just not exactly what I was hoping for. Maybe I need to look into writing my own node.
