UI_Text Display Nodes using Flow.get instead of {{msg.payload}}
How to use flow.get instead of msg.payload into text display node?
Welcome to the forum @Shyama_Gupta
Insert a Change node before the display node, configured to Set msg.payload To the flow variable
You can feed the change node from an Inject node set to repeat at the interval you want.
Alternatively, why don't you just feed the value you are sending the flow variable direct to the text node?
