I am using node red to run a NN inference. So Im using
"node-red-contrib-tf-model" module, which version is 0.1.11
tfjs version = 1.5.1
The problem I am facing is that my nodes tf-function & tf-model appear on the manage palette as not found !
Can someone help me please ?
Can you explain what you mean by that?
Did you follow the instructions in the README about installing the co-reqs?
(You have to do this outside the Node-RED editor)
hello
I have solved the problem of the palette
But still have an issue with nodes releated to tfjs( I tried to run the command suggested but still not working and Im using WSL)
Yes I've followed the official documentation
and yes I did it outside node red editor
What happened when you followed the instructions in the error message? Go into the .node-red folder before running the command.
