I haven't used it much, but am/was helping someone with their question and wrote a small flow for them as an example.
[{"id":"581f105619104477","type":"rbe","z":"437e4108076e5928","name":"","func":"narrowbandEq","gap":"123","start":"1","inout":"out","septopics":true,"property":"payload","topi":"topic","x":430,"y":830,"wires":[["efa5c2e3feaba7eb"]]},{"id":"28ea8176f333dba5","type":"inject","z":"437e4108076e5928","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"-127","payloadType":"num","x":240,"y":790,"wires":[["581f105619104477"]]},{"id":"9f9494fc438016cd","type":"inject","z":"437e4108076e5928","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"20","payloadType":"num","x":240,"y":830,"wires":[["581f105619104477"]]},{"id":"0dd225f37914946e","type":"inject","z":"437e4108076e5928","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"11","payloadType":"num","x":240,"y":870,"wires":[["581f105619104477"]]},{"id":"3f2c03f6c720f8e8","type":"inject","z":"437e4108076e5928","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"40","payloadType":"num","x":240,"y":910,"wires":[["581f105619104477"]]},{"id":"efa5c2e3feaba7eb","type":"debug","z":"437e4108076e5928","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":610,"y":830,"wires":[]}]
It is to filter messages with value of -127.
The node is set to 123 and is narrow band mode.
I set the initial value to 1 so that is a reference point - or so I thought.
Thing is if I press the -127 button after a DEPLOY the -127 gets through.
But if I DEPLOY and press any of the other ones then the -127, the -127 is blocked.
WHY?
Is this a bug (probably not) or am I reading the docs wrong?
