The quantity of payload in each 10 min
Hi guys. Can you please let me know how I can sum the number of payloads in each 10 min and send it to the debug node? Thank you so much
P.S: I already have the counter of payload from the beginning but I was asked to send the quantity of payload in each 10 min .
If you used an inject node set to 10mins, you could use the output to reset your total every 10 mins.
you can use the aggregator node.
Or store the total every ten mins with a inject and calculate the difference from last storing of total.
Thank you so much, I also found the message counter node and it works too.
You can use
And set an inject node which sends msg.reset every 10 min
Thank you so much. I used node-red-contrib-message-counter and it works too :slight_smile :slight_smile:
Hi, not 100% certain if it is the sum total of payload values or count of payloads but here is a demo that should cater for both...
chrome_u2IzTPcroS
[{"id":"226f9f18a6afc487","type":"function","z":"a0a5ddea2fa4216f","name":"Payload Total","func":"\nlet payload_history = context.get(\"payload_history\") || [];//get remembered count\nlet statusMessage;\nlet sum = 0, count = 0;\n\nif (msg.topic === \"release\") {\n    sum = payload_history.reduce((a, b) => a + b, 0) \n    count = payload_history.length;\n    payload_history = [];\n    node.status(\"Sum: 0\");\n} else if(typeof msg.payload === \"number\") {\n    payload_history.push(msg.payload);\n    sum = payload_history.reduce((a, b) => a + b, 0) \n    count = payload_history.length;\n    node.status(\"Sum: \" + sum);\n}\n\ncontext.set(\"payload_history\", payload_history); //remember count\n\nif(msg.topic == \"release\") {\n    msg.payload = {\n        count: count,\n        sum: sum\n    }\n    return [null, msg];\n} \n\nreturn [msg, null];\n\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":690,"y":660,"wires":[["5999900b2df185a4"],["e6140c609f34d805"]]},{"id":"5999900b2df185a4","type":"debug","z":"a0a5ddea2fa4216f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":850,"y":620,"wires":[]},{"id":"0f206903f17e01f9","type":"inject","z":"a0a5ddea2fa4216f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":510,"y":580,"wires":[["226f9f18a6afc487"]]},{"id":"08c8d12fc86a3f32","type":"inject","z":"a0a5ddea2fa4216f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"5","payloadType":"num","x":510,"y":620,"wires":[["226f9f18a6afc487"]]},{"id":"e6140c609f34d805","type":"debug","z":"a0a5ddea2fa4216f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":850,"y":700,"wires":[]},{"id":"9a5781f4bb1f8711","type":"inject","z":"a0a5ddea2fa4216f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"10","payloadType":"num","x":510,"y":660,"wires":[["226f9f18a6afc487"]]},{"id":"339f7d87c33b9917","type":"inject","z":"a0a5ddea2fa4216f","name":"Release (every 10m)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"600","crontab":"","once":false,"onceDelay":0.1,"topic":"release","payload":"0","payloadType":"num","x":460,"y":720,"wires":[["226f9f18a6afc487"]]}]
Amazing , Thank you so much
Thank you :slight_smile:
Thank u so much
Thank you
