Hello, I would like to know how to modify the theme of my dashboard directly on the dashboard without going through the classic change of theme with Node RED
Welcome Lucabo69!
What du you mean with "directly on the dashboard"? Do you know this thread:
I'd call that "Mission Impossible" but that would be wrong because of it can be done.
The way I see it would be possible is that you should first override almost everything theme colors related to get access to the properties. Then feed new color to the ui_template where you can override related values for each element where theme based colors affect.
Kind of a lot of work....
