Thermostat flow I came up with
Anyone in this forum knows I can barely spell I.T. however, I have all the functionality sorted out now after only 3 years, so I'm going back to try to make things look a little better. I started with this thermostat and I think me and chatgpt did a really good job.
and here's the flow,
[{"id":"3f0bb353bfa06f22","type":"function","z":"04de3cddb4a6f215","name":"tempSet","func":"\n\nvar tempSet;\n\nif (msg.topic == \"Setpoint\"){\n  tempSet = msg.payload;\n  if (tempSet < 10){\n    tempSet = 10;\n  }\n  if (tempSet > 25){\n    tempSet = 25;\n  }\n  flow.set(\"tempSet\", tempSet);\n  node.status({ fill: \"blue\", shape: \"dot\", text: tempSet });\n  return msg;\n};\n\n\nlet Y = msg.topic;\n\nif(Y == \"Plus\"){\n  tempSet = flow.get(\"tempSet\");\n  if (tempSet == 'undefined'){\n    flow.set(\"tempSet\",10);\n    tempSet = 10;\n  }\n  if (isNaN(tempSet)) {\n    flow.set(\"tempSet\",10);\n    tempSet = 10;\n    }\n  tempSet = tempSet + .5;\n  if (tempSet > 25) {\n    tempSet = 25;\n  }\n  flow.set(\"tempSet\", tempSet);\n  node.status({ fill: \"blue\", shape: \"dot\", text: tempSet });\n  return msg;\n}\n\nif (Y == \"Minus\") {\n  let tempSet = flow.get(\"tempSet\");\n  if (tempSet == 'undefined') {\n    flow.set(\"tempSet\", 10);\n    tempSet = 10;\n  }\n  if (isNaN(tempSet)) {\n    flow.set(\"tempSet\", 10);\n    tempSet = 10;\n  }\n  tempSet = tempSet - .5;\n  if (tempSet < 10) {\n    tempSet = 10;\n  }\n  flow.set(\"tempSet\", tempSet);\n  node.status({ fill: \"blue\", shape: \"dot\", text: tempSet });\n  return msg;\n}\n\n\nreturn null;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":620,"y":280,"wires":[["595a26fd2a2e4546"]]},{"id":"595a26fd2a2e4546","type":"function","z":"04de3cddb4a6f215","name":"aggregate","func":"/*\nmsg.payload[0] = power\nmsg.payload[1] = fan\nmsg.payload[2] = cog\nmsg.payload[3] = flame\nmsg.payload[4] = tempAmb\nmsg.payload[5] = tempSet\n*/\nlet Sensor = \"good\";\n\nlet Sensor1 = global.get(\"Sensor1\");\nlet Sensor2 = global.get(\"Sensor2\");\ncontext.set(\"Sensor1\",Sensor1);\ncontext.set(\"Sensor2\",Sensor2);\n\nif (Sensor1 == \"failed\" && Sensor2 == \"failed\"){\n    Sensor = \"failed\";\n}\n\nlet Fan = flow.get(\"Fan\");\nlet tempSet = flow.get(\"tempSet\");\n\n\nlet Cog = flow.get(\"Cog\");\nif (Cog == \"On\") {\n    let W = cToF(tempSet);\n    let X = W.toFixed(1);\n    tempSet = X;\n}\n\nfunction cToF(num) {\n    var f = ((num * 1.8) + 32);\n    return f;\n}\n\nfunction fToC(num) {\n    var c = ((num - 32) * (5 / 9));\n    return c;\n}\n\nlet tempAmb = flow.get(\"tempAmb\");\nlet Power = flow.get(\"Power\");\nif (Sensor == \"failed\"){\n    Power = \"None\";\n//    flow.set(\"Power\",\"Off\");\n}\nvar Flame = \"\";\nif (global.get(\"heat_running\") == true){\n    Flame = \"On\";\n}\nif (global.get(\"heat_running\") == false){\n    Flame = \"Off\";\n}\n//let Flame = flow.get(\"Flame\");\nCog = flow.get(\"Cog\");\nconst payload=[];\n\nmsg = {\n    payload: [Power,Fan,Cog,Flame],\n    tempSet: tempSet,\n    tempAmb: tempAmb,\n}\n\n\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":420,"y":380,"wires":[["9c56b5c3aa936f5b"]]},{"id":"65470a8bed182c70","type":"link in","z":"04de3cddb4a6f215","name":"3 sec in","links":["637589bc3f933b91"],"x":235,"y":380,"wires":[["d67d430dec3dad02","595a26fd2a2e4546","ffdec737ec9672ee","3f0bb353bfa06f22"]]},{"id":"bab4ddb531211035","type":"function","z":"04de3cddb4a6f215","name":"Pwr","func":"\nif (msg.topic != \"Power\"){\n    return null;\n}\n\nlet Power = context.get(\"Power\");\nif (Power == 'undefined'){\n    context.set(\"Power\",\"On\");\n    flow.set(\"Power\",\"On\")\n    Power = \"On\";\n    node.status({ fill: \"blue\", shape: \"dot\", text: Power });\n}\n\nif (Power == \"On\"){\n    context.set(\"Power\",\"Off\");\n    flow.set(\"Power\",\"Off\");\n} else {\n    context.set(\"Power\", \"On\");\n    flow.set(\"Power\", \"On\");\n}\n\nnode.status({ fill: \"blue\", shape: \"dot\", text: Power });\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":380,"wires":[[]]},{"id":"d41568c07d7fba67","type":"function","z":"04de3cddb4a6f215","name":"Cog","func":"\nif (msg.topic != \"Cog\"){\n    return null;\n}\n\nlet Cog = context.get(\"Cog\");\nif (Cog == 'undefined'){\n    context.set(\"Cog\",\"Off\");\n    flow.set(\"Cog\",\"Off\")\n    Cog = \"Off\";\n    node.status({ fill: \"blue\", shape: \"dot\", text: Cog });\n}\n\nif (Cog == \"On\"){\n    context.set(\"Cog\",\"Off\");\n    flow.set(\"Cog\",\"Off\");\n} else {\n    context.set(\"Cog\", \"On\");\n    flow.set(\"Cog\", \"On\");\n}\n\nnode.status({ fill: \"blue\", shape: \"dot\", text: Cog });\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":440,"wires":[[]]},{"id":"953d89927c79927c","type":"function","z":"04de3cddb4a6f215","name":"Fan","func":"\nif (msg.topic != \"Fan\"){\n    return null;\n}\n\nlet Fan = context.get(\"Fan\");\nif (Fan == 'undefined'){\n    context.set(\"Fan\",\"Off\");\n    flow.set(\"Fan\",\"Off\")\n    Fan = \"Off\";\n    node.status({ fill: \"blue\", shape: \"dot\", text: Fan });\n}\n\nif (Fan == \"On\"){\n    context.set(\"Fan\",\"Off\");\n    flow.set(\"Fan\",\"Off\");\n    node.status({ fill: \"blue\", shape: \"dot\", text: \"Fan Off\"});\n} else {\n    context.set(\"Fan\", \"On\");\n    flow.set(\"Fan\", \"On\");\n    node.status({ fill: \"blue\", shape: \"dot\", text: \"Fan On\" });\n}\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":500,"wires":[[]]},{"id":"d67d430dec3dad02","type":"function","z":"04de3cddb4a6f215","name":"Thermostat logic","func":"let TempSet = Number(flow.get(\"tempSet\"));\nlet TempAmb = Number(flow.get(\"tempAmb\"));\nlet Power = flow.get(\"Power\");\nvar HeatOn; \n\nflow.set(\"Flame\", \"Off\");\nflow.set('heating_status', \"Off\");\nHeatOn = false;\n\n\nif(Power == \"On\"){\n    if (TempSet <= TempAmb + 0.2) {\n        HeatOn = false;\n        flow.set(\"Flame\", \"Off\");\n    } else {\n        if (TempSet > TempAmb + 0.2) {\n            HeatOn = true;\n            flow.set('heating_status', HeatOn);\n            flow.set(\"Flame\", \"On\");\n        } \n    }\n}\n\nnode.status({ fill: \"blue\", shape: \"dot\", text: HeatOn});\n\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":450,"y":440,"wires":[[]]},{"id":"ffdec737ec9672ee","type":"function","z":"04de3cddb4a6f215","name":"heat running","func":"\nlet Heat = global.get(\"heat_running\");\n\nnode.status({ fill: \"blue\", shape: \"dot\", text: \"Heat On \" + Heat});\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":260,"wires":[[]]},{"id":"9c56b5c3aa936f5b","type":"ui-template","z":"04de3cddb4a6f215","group":"546c6a08d800a5e9","page":"","ui":"","name":"good thermo","order":2,"width":"4","height":"11","head":"","format":"\n\n\n\n\n\n\n\n<template>\n  <container>\n    <div class=\"nexus\">\n\n      <!-- HEADER -->\n      <div class=\"nexus-header\">\n        <div class=\"brand\">\n          <span class=\"brand-icon\">◈</span>\n          <div>\n            <div class=\"brand-name\">Systatium</div>\n            <div class=\"brand-sub\">CLIMATE CONTROL SYSTEM</div>\n          </div>\n        </div>\n      </div>\n\n      <!-- MAIN INSTRUMENT -->\n      <div class=\"main-instrument\">\n\n        <!-- TEMPERATURE DIAL -->\n        <div\n          class=\"temperature-ring\"\n          :class=\"{\n            adjusting: dialDragging,\n            heating: flame === 'On'\n          }\"\n        >\n          <svg\n            class=\"ring-svg\"\n            viewBox=\"0 0 300 300\"\n            preserveAspectRatio=\"xMidYMid meet\"\n            @pointerdown=\"startDial\"\n            @pointermove=\"moveDial\"\n            @pointerup=\"endDial\"\n            @pointercancel=\"endDial\"\n            @lostpointercapture=\"endDial\"\n          >\n\n            <!-- BACKGROUND TRACK -->\n            <circle\n              class=\"ring-track\"\n              cx=\"150\"\n              cy=\"150\"\n              r=\"132\"\n              stroke-dasharray=\"622 829\"\n              transform=\"rotate(-135 150 150)\"\n            />\n\n            <!-- TEMPERATURE PROGRESS -->\n            <circle\n              class=\"ring-progress\"\n              cx=\"150\"\n              cy=\"150\"\n              r=\"132\"\n              stroke-dasharray=\"622 829\"\n              :stroke-dashoffset=\"622 - (dialProgress * 622)\"\n              transform=\"rotate(-135 150 150)\"\n            />\n\n            <!-- ENERGY SWEEP -->\n            <circle\n              class=\"energy-sweep\"\n              cx=\"150\"\n              cy=\"150\"\n              r=\"132\"\n              stroke-dasharray=\"38 791\"\n              transform=\"rotate(-135 150 150)\"\n            />\n\n            <!-- INNER RING -->\n            <circle\n              class=\"ring-inner\"\n              cx=\"150\"\n              cy=\"150\"\n              r=\"108\"\n            />\n\n            <!-- TEMPERATURE TICKS -->\n            <g class=\"dial-ticks\">\n              <line\n                v-for=\"tick in dialTicks\"\n                :key=\"'tick-' + tick.temp\"\n                :x1=\"tick.x1\"\n                :y1=\"tick.y1\"\n                :x2=\"tick.x2\"\n                :y2=\"tick.y2\"\n                :class=\"{\n                  'major-tick': tick.major,\n                  'active-tick': tick.temp <= dialCurrentTemp\n                }\"\n              />\n\n              <!-- TEMPERATURE LABELS -->\n              <text\n                v-for=\"tick in dialTicks.filter(t => t.major)\"\n                :key=\"'label-' + tick.temp\"\n                :x=\"tick.labelX\"\n                :y=\"tick.labelY\"\n                class=\"dial-label\"\n                :class=\"{\n                  'active-label': tick.temp <= dialCurrentTemp\n                }\"\n                text-anchor=\"middle\"\n                dominant-baseline=\"middle\"\n              >\n                {{ tick.temp }}°\n              </text>\n            </g>\n\n            <!-- DIAL INDICATOR -->\n            <circle\n              class=\"dial-indicator\"\n              :cx=\"150 + 132 * Math.cos(dialAngle * Math.PI / 180)\"\n              :cy=\"150 + 132 * Math.sin(dialAngle * Math.PI / 180)\"\n              r=\"8\"\n            />\n\n          </svg>\n\n          <!-- CENTRAL TEMPERATURE DISPLAY -->\n          <div class=\"temperature-center\">\n            <div class=\"temp-caption\">CURRENT TEMP</div>\n\n            <div class=\"ambient-temp\">\n              {{ tempAmb }}<span class=\"degree\">°</span>\n            </div>\n\n            <div class=\"temp-unit\">CELSIUS</div>\n          </div>\n\n          <!-- DIAL INSTRUCTION -->\n          <div class=\"dial-hint\">\n            {{ dialDragging ? 'ADJUSTING SETPOINT' : 'DRAG TO ADJUST' }}\n          </div>\n        </div>\n\n        <!-- TARGET TEMPERATURE -->\n        <div class=\"target-display\">\n          <div class=\"target-label\">\n            TARGET TEMPERATURE\n          </div>\n\n          <div class=\"target-value\">\n            {{ Number(dialCurrentTemp).toFixed(1) }}<span>°</span>\n          </div>\n\n          <div class=\"target-label\">\n            DRAG THE OUTER RING TO CHANGE\n          </div>\n        </div>\n      </div>\n\n      <!-- BOTTOM BUTTONS -->\n      <div class=\"button-container\">\n\n<v-card\n  class=\"thermoValue stretch-button\"\n  @click=\"Power\"\n>\n  <v-icon\n    size=\"36\"\n    :class=\"{ 'power-icon-active': powerOn }\"\n  >\n    mdi-power\n  </v-icon>\n</v-card>\n\n<!-- FAN -->\n<v-card\n  class=\"thermoValue stretch-button\"\n  :class=\"{ 'fan-active': fanOn }\"\n  @click=\"Fan\"\n>\n  <v-icon\n    size=\"36\"\n    :class=\"{ 'fan-spinning': fanOn }\"\n  >\n    mdi-fan\n  </v-icon>\n</v-card>\n\n      </div>\n\n    </div>\n  </container>\n</template>\n\n<script>\nexport default {\n  props: {\n    msg: Object,\n  },\n\n  data() {\n    return {\n      // Heating state\n      flame: 'Off',\n      powerOn: false,\n      fanOn: false,\n\n      // Temperatures\n      tempAmb: '--',\n      tempSet: '--',\n\n      // Dial configuration\n      dialMin: 10,\n      dialMax: 25,\n      dialStep: 0.25,\n\n      // Interactive dial\n      dialDragging: false,\n      dialCurrentTemp: 20,\n\n      // Pointer tracking\n      activePointerId: null,\n    }\n  },\n\n  computed: {\n    // Dial progress from 0 to 1\n    dialProgress() {\n      return Math.max(\n        0,\n        Math.min(\n          1,\n          (this.dialCurrentTemp - this.dialMin) /\n            (this.dialMax - this.dialMin),\n        ),\n      )\n    },\n\n    // Indicator angle\n    dialAngle() {\n      return -135 + this.dialProgress * 270\n    },\n\n    // Temperature markings\n    dialTicks() {\n      const ticks = []\n\n      for (\n        let temp = this.dialMin;\n        temp <= this.dialMax;\n        temp++\n      ) {\n        const progress =\n          (temp - this.dialMin) /\n          (this.dialMax - this.dialMin)\n\n        const angle = -135 + progress * 270\n        const radians = (angle * Math.PI) / 180\n        const major = temp % 5 === 0\n\n        ticks.push({\n          temp,\n          major,\n\n          x1: 150 + (major ? 119 : 123) * Math.cos(radians),\n          y1: 150 + (major ? 119 : 123) * Math.sin(radians),\n\n          x2: 150 + 130 * Math.cos(radians),\n          y2: 150 + 130 * Math.sin(radians),\n\n          labelX: 150 + 138 * Math.cos(radians),\n          labelY: 150 + 138 * Math.sin(radians),\n        })\n      }\n\n      return ticks\n    },\n  },\n\n  watch: {\n    // Incoming Node-RED updates\n    msg: {\n      immediate: true,\n\n      handler(newVal) {\n        if (!newVal) return\n\n\n      // Power status\nif (newVal.power !== undefined) {\n  this.powerOn = newVal.power === 'On';\n}\n\n// Fan status\nif (newVal.fan !== undefined) {\n  this.fanOn = newVal.fan === 'On';\n}\n\n\n        // Heating status\n        if (Array.isArray(newVal.payload)) {\n          const [, , , flame] = newVal.payload\n\n          if (flame !== undefined) {\n            this.flame = flame\n          }\n        }\n\n        // Ambient temperature\n        if (newVal.tempAmb !== undefined) {\n          this.tempAmb = newVal.tempAmb\n        }\n\n        // Set temperature\n        if (newVal.tempSet !== undefined) {\n          this.tempSet = newVal.tempSet\n\n          if (!this.dialDragging) {\n            const value = Number.parseFloat(newVal.tempSet)\n\n            if (Number.isFinite(value)) {\n              this.dialCurrentTemp = this.clampTemp(value)\n            }\n          }\n        }\n      },\n    },\n  },\n\n  methods: {\n    // Temperature limits\n    clampTemp(value) {\n      return Math.max(\n        this.dialMin,\n        Math.min(this.dialMax, value)\n      )\n    },\n\n  Power() {\n    this.send({\n      topic: \"Power\"\n    });\n\n    this.powerOn = !this.powerOn;\n  },\n\n\nFan() {\n  this.send({\n    topic: \"Fan\"\n  });\n\n  this.fanOn = !this.fanOn;\n},\n\n\n\n    // Send setpoint to Node-RED\n    sendSetpoint(value) {\n      const temp = this.clampTemp(value)\n\n      this.dialCurrentTemp = temp\n\n      this.send({\n        topic: 'Setpoint',\n        payload: temp,\n      })\n    },\n\n    // Calculate temperature from dial position\n    getDialTemperature(event) {\n      const rect =\n        event.currentTarget.getBoundingClientRect()\n\n      const x =\n        event.clientX - rect.left - rect.width / 2\n\n      const y =\n        event.clientY - rect.top - rect.height / 2\n\n      const distance = Math.sqrt(x * x + y * y)\n\n      if (distance < 85) return null\n\n      const angle =\n        (Math.atan2(y, x) * 180) / Math.PI\n\n      let relative = (angle + 135 + 360) % 360\n\n      if (relative > 270) {\n        relative = relative < 315 ? 270 : 0\n      }\n\n      let temp =\n        this.dialMin +\n        (relative / 270) *\n        (this.dialMax - this.dialMin)\n\n      temp =\n        Math.round(temp / this.dialStep) *\n        this.dialStep\n\n      return this.clampTemp(temp)\n    },\n\n    // Start dial\n    startDial(event) {\n      if (this.dialDragging) return\n\n      const temp = this.getDialTemperature(event)\n\n      if (temp === null) return\n\n      event.preventDefault()\n\n      this.dialDragging = true\n      this.activePointerId = event.pointerId\n\n      event.currentTarget.setPointerCapture(\n        event.pointerId\n      )\n\n      this.sendSetpoint(temp)\n    },\n\n    // Move dial\n    moveDial(event) {\n      if (!this.dialDragging) return\n\n      if (event.pointerId !== this.activePointerId) return\n\n      const temp = this.getDialTemperature(event)\n\n      if (temp === null) return\n\n      if (temp === this.dialCurrentTemp) return\n\n      this.sendSetpoint(temp)\n    },\n\n    // End dial\n    endDial(event) {\n      if (\n        this.activePointerId !== null &&\n        event.pointerId !== undefined &&\n        event.pointerId !== this.activePointerId\n      ) {\n        return\n      }\n\n      this.dialDragging = false\n      this.activePointerId = null\n    },\n  },\n}\n</script>\n\n<style scoped>\n\n/* =================================\n   NEXUS DESIGN\n================================= */\n\n.nexus {\n  --cyan: #00d9ff;\n  --amber: #ff9d32;\n\n  width: 100%;\n  box-sizing: border-box;\n  padding: 18px;\n\n  color: #d9f5ff;\n\n  background: radial-gradient(\n    ellipse at 50% 30%,\n    #102a40 0%,\n    #091725 48%,\n    #050c15 100%\n  );\n\n  border: 1px solid #17394d;\n  border-radius: 18px;\n\n  font-family: Roboto, Arial, sans-serif;\n  overflow: hidden;\n}\n\n/* HEADER */\n\n.nexus-header {\n  display: flex;\n  align-items: center;\n  padding-bottom: 18px;\n  border-bottom: 1px solid #18374a;\n}\n\n.brand {\n  display: flex;\n  align-items: center;\n  gap: 11px;\n}\n\n.brand-icon {\n  font-size: 34px;\n  color: var(--cyan);\n  text-shadow: 0 0 15px var(--cyan);\n}\n\n.brand-name {\n  font-size: 21px;\n  font-weight: 800;\n  letter-spacing: 4px;\n}\n\n.brand-sub {\n  font-size: 8px;\n  color: #65869a;\n  letter-spacing: 2px;\n  margin-top: 3px;\n}\n\n/* MAIN INSTRUMENT */\n\n.main-instrument {\n  padding: 8px 0 20px;\n  text-align: center;\n}\n\n.instrument-label,\n.target-label {\n  font-size: 10px;\n  letter-spacing: 2px;\n  color: #648ba1;\n}\n\n/* CIRCULAR DIAL */\n\n.temperature-ring {\n  position: relative;\n  width: min(290px, 82vw);\n  aspect-ratio: 1;\n  margin: 8px auto 18px;\n\n  user-select: none;\n  -webkit-user-select: none;\n\n  animation: nexusBoot 1.2s ease-out both;\n}\n\n/* SVG */\n\n.ring-svg {\n  display: block;\n  position: relative;\n  z-index: 2;\n\n  width: 100%;\n  height: 100%;\n\n  overflow: visible;\n  touch-action: none;\n  cursor: grab;\n}\n\n.ring-svg:active {\n  cursor: grabbing;\n}\n\n.ring-svg circle {\n  fill: none;\n}\n\n/* BACKGROUND TRACK */\n\n.ring-track {\n  stroke: #18364a;\n  stroke-width: 5;\n}\n\n/* TEMPERATURE PROGRESS */\n\n.ring-progress {\n  stroke: var(--cyan);\n  stroke-width: 5;\n  stroke-linecap: round;\n\n  filter:\n    drop-shadow(0 0 5px var(--cyan))\n    drop-shadow(0 0 12px #007da9);\n\n  transition:\n    stroke-dashoffset 0.25s ease,\n    stroke 0.4s ease;\n}\n\n/* ENERGY SWEEP */\n\n.energy-sweep {\n  stroke: var(--cyan);\n  stroke-width: 7;\n  stroke-linecap: round;\n\n  filter:\n    drop-shadow(0 0 5px var(--cyan))\n    drop-shadow(0 0 12px var(--cyan));\n\n  animation: energyTravel 4s linear infinite;\n  pointer-events: none;\n}\n\n/* INNER RING */\n\n.ring-inner {\n  stroke: #173448;\n  stroke-width: 1;\n  stroke-dasharray: 3 7;\n}\n\n/* TEMPERATURE TICKS */\n\n.dial-ticks line {\n  stroke: #31546a;\n  stroke-width: 1;\n  transition: stroke 0.3s;\n}\n\n.dial-ticks .major-tick {\n  stroke: #7194a8;\n  stroke-width: 2;\n}\n\n.dial-ticks .active-tick {\n  stroke: var(--cyan);\n  filter: drop-shadow(0 0 3px var(--cyan));\n}\n\n.dial-label {\n  font-size: 10px;\n  font-weight: 500;\n  fill: #648398;\n  transition: fill 0.3s;\n}\n\n.dial-label.active-label {\n  fill: #b8f5ff;\n  filter: drop-shadow(0 0 4px var(--cyan));\n}\n\n/* DIAL INDICATOR */\n\n.dial-indicator {\n  fill: #e8fcff;\n  stroke: var(--cyan);\n  stroke-width: 4;\n\n  filter:\n    drop-shadow(0 0 5px var(--cyan))\n    drop-shadow(0 0 10px var(--cyan));\n\n  transition:\n    cx 0.08s,\n    cy 0.08s,\n    stroke 0.4s;\n}\n\n/* HEATING ACTIVE - AMBER */\n\n.temperature-ring.heating .ring-progress {\n  stroke: var(--amber);\n\n  filter:\n    drop-shadow(0 0 5px var(--amber))\n    drop-shadow(0 0 12px #ff7300);\n}\n\n.temperature-ring.heating .energy-sweep {\n  stroke: var(--amber);\n\n  filter:\n    drop-shadow(0 0 6px var(--amber))\n    drop-shadow(0 0 15px #ff7300);\n\n  animation-duration: 2s;\n}\n\n.temperature-ring.heating .dial-indicator {\n  stroke: var(--amber);\n\n  filter:\n    drop-shadow(0 0 8px var(--amber))\n    drop-shadow(0 0 12px #ff7300);\n}\n\n.temperature-ring.heating .dial-ticks .active-tick {\n  stroke: var(--amber);\n  filter: drop-shadow(0 0 3px var(--amber));\n}\n\n.temperature-ring.heating .dial-label.active-label {\n  fill: #ffc078;\n  filter: drop-shadow(0 0 4px var(--amber));\n}\n\n/* DIAL ADJUSTMENT GLOW */\n\n.temperature-ring.adjusting .ring-progress {\n  filter:\n    drop-shadow(0 0 8px var(--cyan))\n    drop-shadow(0 0 20px #00aaff);\n}\n\n.temperature-ring.heating.adjusting .ring-progress {\n  filter:\n    drop-shadow(0 0 8px var(--amber))\n    drop-shadow(0 0 20px #ff7300);\n}\n\n/* CENTRAL TEMPERATURE */\n\n.temperature-center {\n  position: absolute;\n  inset: 0;\n  z-index: 3;\n\n  display: flex;\n  flex-direction: column;\n  align-items: center;\n  justify-content: center;\n\n  pointer-events: none;\n}\n\n.temp-caption {\n  font-size: 9px;\n  letter-spacing: 2px;\n  color: #648ba1;\n}\n\n.ambient-temp {\n  font-size: clamp(55px, 14vw, 76px);\n  line-height: 1.15;\n  font-weight: 300;\n  color: #e6faff;\n\n  text-shadow: 0 0 20px #00a9db66;\n}\n\n.degree {\n  font-size: 34px;\n  color: var(--cyan);\n  vertical-align: top;\n}\n\n.temp-unit {\n  font-size: 9px;\n  color: #63859a;\n  letter-spacing: 3px;\n}\n\n/* DIAL HINT */\n\n.dial-hint {\n  position: absolute;\n  z-index: 4;\n  bottom: 24px;\n  width: 100%;\n\n  text-align: center;\n\n  font-size: 8px;\n  letter-spacing: 2px;\n  color: #527b91;\n\n  pointer-events: none;\n}\n\n/* TARGET DISPLAY */\n\n.target-display {\n  position: relative;\n  z-index: 5;\n\n  padding: 9px 15px;\n  margin: 0 auto;\n  max-width: 310px;\n\n  background: #0c1d2b;\n  border: 1px solid #1b4055;\n  border-radius: 12px;\n\n  box-shadow: inset 0 0 25px #00bfff08;\n}\n\n.target-value {\n  font-size: 32px;\n  font-weight: 300;\n  color: var(--cyan);\n  margin: 2px 0 5px;\n\n  text-shadow: 0 0 12px #00bfff55;\n}\n\n.target-value span {\n  font-size: 20px;\n}\n\n/* ANIMATIONS */\n\n@keyframes energyTravel {\n  from {\n    stroke-dashoffset: 0;\n    opacity: 0.3;\n  }\n\n  50% {\n    opacity: 1;\n  }\n\n  to {\n    stroke-dashoffset: -829;\n    opacity: 0.3;\n  }\n}\n\n@keyframes nexusBoot {\n  from {\n    opacity: 0;\n    transform: scale(0.94);\n  }\n\n  to {\n    opacity: 1;\n    transform: scale(1);\n  }\n}\n\n/* RESPONSIVE */\n\n@media (max-width: 350px) {\n  .nexus {\n    padding: 12px;\n  }\n\n  .brand-name {\n    font-size: 17px;\n  }\n}\n\n/* REDUCED MOTION */\n\n@media (prefers-reduced-motion: reduce) {\n  .energy-sweep,\n  .temperature-ring {\n    animation: none;\n  }\n\n  .ring-progress,\n  .dial-indicator {\n    transition: none;\n  }\n}\n\n/* =================================\n   BOTTOM BUTTON LAYOUT\n================================= */\n\n.button-container {\n  display: flex !important;\n  flex-flow: row nowrap !important;\n  justify-content: center;\n  align-items: center;\n  gap: 14px;\n\n  width: 100%;\n  padding: 5px 10px 5px;\n  margin-top: 0;\n\n  box-sizing: border-box;\n}\n\n.stretch-button {\n  flex: 1 1 0;\n  width: auto;\n  max-width: 150px;\n  min-width: 0;\n  min-height: 75px;\n\n  display: flex !important;\n  justify-content: center;\n  align-items: center;\n\n  background: #3B3B3B !important;\n  border: none !important;\n  box-shadow: none !important;\n\n  border-radius: 14px !important;\n  overflow: hidden;\n\n  color: #ffffff;\n}\n\n/* POWER BUTTON STATES */\n\n.stretch-button {\n  background: #3B3B3B !important;\n  color: #ffffff !important;\n  transition:\n    background 0.3s ease,\n    color 0.3s ease,\n    box-shadow 0.3s ease;\n}\n\n/* POWER ICON ACTIVE STATE */\n\n.power-icon-active {\n  color: #7CFC00 !important;\n  filter: drop-shadow(0 0 6px #7CFC0088);\n  transition: color 0.3s ease, filter 0.3s ease;\n}\n\n\n/* FAN ACTIVE STATE */\n\n.fan-active {\n  background: #3B3B3B !important;\n  color: #00D9FF !important;\n  box-shadow: 0 0 14px #00D9FF55 !important;\n}\n\n/* ROTATING FAN */\n\n.fan-spinning {\n  animation: fanRotate 1s linear infinite;\n}\n\n@keyframes fanRotate {\n  from {\n    transform: rotate(0deg);\n  }\n\n  to {\n    transform: rotate(360deg);\n  }\n}\n\n\n\n</style>\n","noerr":0,"storeOutMessages":true,"passthru":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":610,"y":380,"wires":[["953d89927c79927c","3f0bb353bfa06f22","bab4ddb531211035","d41568c07d7fba67"]]},{"id":"546c6a08d800a5e9","type":"ui-group","name":"Thermo","page":"8f9ca4f2e85412d6","width":"4","height":"5","order":1,"showTitle":false,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"8f9ca4f2e85412d6","type":"ui-page","name":"Thermostat","ui":"e666d999ff129a18","path":"/Thermostat","icon":"mdi-thermostat","layout":"grid","theme":"f34d19a187ddca0b","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":1,"className":"","visible":"true","disabled":"false"},{"id":"e666d999ff129a18","type":"ui-base","name":"Sprink1","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":true,"notificationDisplayTime":5,"showDisconnectNotification":true,"allowInstall":true},{"id":"f34d19a187ddca0b","type":"ui-theme","name":"Main","colors":{"surface":"#000000","primary":"#000000","bgPage":"#000000","groupBg":"#000000","groupOutline":"#000000"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}},{"id":"acd310ce547eab86","type":"global-config","env":[],"modules":{"@flowfuse/node-red-dashboard":"1.36.0"}}]
The little blue dash on the ring spins around the circle continuously and the dash and circle changes to red when the furnace kicks on. A few things in the flow besides thermostat, When the whole new DB2 came along I really dreaded the change and it took a long time to get even remotely comfortable but now that I got to it there are a lot of really cool things you can do.
Thanks for the comments. The plus and minus stuff was left over from a previous thermostat attempt that I missed, I removed it but left the undefined stuff and moved it in the code and used your suggestion.
Thank you
