This flow is generating interesting files
I wrote this flow recently to try and help track my daily computer usage.
The flow:
[{"id":"39fd3a77.cbb756","type":"group","z":"26262ba1.62dcbc","name":"Uptime","style":{"label":true},"nodes":["ece2d27e.1926e8","4511a9a0.0b2e38","97bdf5b5.57e4c8","611b65a9.71b0f4","ac7fc38f.acb178","1f6371fd.ba4d56","2fa4bddf.cb243a","15466412.7808ac","1644881a.fb9ab","abd001b.e0ee4","fadf9736.69d95","11f8a8d.dd42957","6a30385a.7bb1f","ad90ee9d.430698","8042da6d.3015d"],"x":4204,"y":39,"w":792,"h":242},{"id":"5a81f3be.561bdc","type":"subflow","name":"Time Stamp","info":"**3 outputs.  1 - msg.payload holds the time. 2 - msg.time holds the time in a way to be used for reading time in a log file. 3 - outputs nsg.time in a format usable for file names**","category":"","in":[{"x":80,"y":100,"wires":[{"id":"682ac304.0590d4"}]}],"out":[{"x":640,"y":180,"wires":[{"id":"cf554e88.9fff18","port":0},{"id":"682ac304.0590d4","port":0}]},{"x":640,"y":230,"wires":[{"id":"682ac304.0590d4","port":0},{"id":"3db4df41.634848","port":0}]},{"x":640,"y":280,"wires":[{"id":"e4ca4227.3109c8","port":0},{"id":"682ac304.0590d4","port":0}]}],"env":[],"color":"#FF8888","outputLabels":["For use in log files","msg.time","For filename use"],"icon":"node-red/timer.svg"},{"id":"cf554e88.9fff18","type":"moment","z":"5a81f3be.561bdc","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Australia/Sydney","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYY-MM-DD HH:mm:ss","locale":"en_AU","output":"payload","outputType":"msg","outTz":"Australia/Sydney","x":390,"y":180,"wires":[["e4ca4227.3109c8","c810aa73.a5706"]]},{"id":"e4ca4227.3109c8","type":"string","z":"5a81f3be.561bdc","name":"","methods":[{"name":"replaceAll","params":[{"type":"str","value":":"},{"type":"str","value":""}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":440,"y":280,"wires":[[]]},{"id":"c810aa73.a5706","type":"change","z":"5a81f3be.561bdc","name":"TOPIC","rules":[{"t":"move","p":"payload","pt":"msg","to":"time","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":230,"wires":[["3db4df41.634848"]]},{"id":"be4fd533.c9abb","type":"change","z":"5a81f3be.561bdc","name":"Save","rules":[{"t":"set","p":"payload","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":140,"wires":[["c7ad4b3c.3a5368"]]},{"id":"3db4df41.634848","type":"change","z":"5a81f3be.561bdc","name":"Get","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":230,"wires":[[]]},{"id":"682ac304.0590d4","type":"switch","z":"5a81f3be.561bdc","name":"check topic","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"TIMESTAMP","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":200,"y":100,"wires":[[],["be4fd533.c9abb"]]},{"id":"c7ad4b3c.3a5368","type":"change","z":"5a81f3be.561bdc","name":"TimeStamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":180,"wires":[["cf554e88.9fff18"]]},{"id":"ece2d27e.1926e8","type":"subflow:5a81f3be.561bdc","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"","x":4520,"y":150,"wires":[["97bdf5b5.57e4c8"],[],[]]},{"id":"4511a9a0.0b2e38","type":"inject","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"Clock","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":4350,"y":150,"wires":[["611b65a9.71b0f4","ece2d27e.1926e8"]]},{"id":"97bdf5b5.57e4c8","type":"gate","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":4690,"y":120,"wires":[["ac7fc38f.acb178"]]},{"id":"611b65a9.71b0f4","type":"exec","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","command":"uptime -p","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":4510,"y":100,"wires":[["2fa4bddf.cb243a"],[],[]]},{"id":"ac7fc38f.acb178","type":"function","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"","func":"msg.payload = flow.get(\"Uptime\") + \"Last alive \" + msg.payload;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":4805,"y":120,"wires":[["15466412.7808ac","1644881a.fb9ab","8042da6d.3015d"]],"l":false},{"id":"1f6371fd.ba4d56","type":"function","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"set","func":"msg.payload = \"open\";\nmsg.topic = \"control\";\nreturn msg;","outputs":1,"noerr":0,"x":4690,"y":160,"wires":[["97bdf5b5.57e4c8"]]},{"id":"2fa4bddf.cb243a","type":"change","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"Uptime","rules":[{"t":"set","p":"Uptime","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":4700,"y":80,"wires":[[]]},{"id":"15466412.7808ac","type":"file","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"Alive","filename":"/home/me/.node-red/public/uptime.txt","appendNewline":true,"createDir":true,"overwriteFile":"true","encoding":"none","x":4900,"y":120,"wires":[[]]},{"id":"1644881a.fb9ab","type":"debug","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"Uptime","active":false,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":4850,"y":160,"wires":[]},{"id":"abd001b.e0ee4","type":"delay","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":4700,"y":200,"wires":[["1f6371fd.ba4d56"]]},{"id":"fadf9736.69d95","type":"subflow:5a81f3be.561bdc","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"","x":4520,"y":200,"wires":[[],["abd001b.e0ee4"],["11f8a8d.dd42957"]]},{"id":"11f8a8d.dd42957","type":"function","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"build msg","func":"msg.spath = \"/home/me/.node-red/public/\";\nmsg.dpath = \"/home/me/.node-red/public/history/\";\n\nmsg.payload = \"Powered on at \" + msg.payload + \".db\";\nnode.status(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":4700,"y":240,"wires":[["ad90ee9d.430698"]]},{"id":"6a30385a.7bb1f","type":"inject","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"Boot detector","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":"2","topic":"","payload":"BOOT SIGNAL","payloadType":"str","x":4330,"y":200,"wires":[["fadf9736.69d95"]]},{"id":"ad90ee9d.430698","type":"fs-ops-move","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"","sourcePath":"spath","sourcePathType":"msg","sourceFilename":"uptime.txt","sourceFilenameType":"str","destPath":"dpath","destPathType":"msg","destFilename":"payload","destFilenameType":"msg","link":false,"x":4850,"y":240,"wires":[[]]},{"id":"8042da6d.3015d","type":"mqtt out","z":"26262ba1.62dcbc","g":"39fd3a77.cbb756","name":"","topic":"uptime/txt","qos":"","retain":"","broker":"378c0403.8cda04","x":4910,"y":80,"wires":[]},{"id":"378c0403.8cda04","type":"mqtt-broker","name":"TIMEPI MQTT","broker":"192.168.0.99","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"true","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
No foreign nodes, but a sub-flow I wrote included.
Basically it does this:
Boot: rename and move current file to (existing path)/history
and rename it to one of my weird filenames. (Not really that weird)
MQTT listens in and a python script shows me on the screen the usage for THIS time.
Ok. No problem/s yet.
But!
Today is 9 Feb. This is the only time I have turned on the machine. (First/only session for today)
Looking in the directory (history) I see this:
How (semi rhetorical) were those files made?
I get that today when I turned it on, yesterday's "log" would be renamed to "Powerd on at...." with today's timestamp.
That explaines one of the two files.
06:48 is about the time I powered on the machine.
But it hasn't been turned off since then.
Note I did say ABOUT. 07:40 is also possible.
This is what a screen shot of the flow shows me which is why I changed the original claim of 06:xx to 07:xx
DIgging a bit deeper, these are the file contents:
me@me-desktop:~/.node-red/public/history$ cat Powered\ on\ at\ 2021-02-09\ 064813.db
up 1 hour, 3 minutes
Last alive 2021-02-08 22:55:30
me@me-desktop:~/.node-red/public/history$ cat Powered\ on\ at\ 2021-02-09\ 074737.db
up 58 minutes
Last alive 2021-02-09 07:47:11
me@me-desktop:~/.node-red/public/history$ cd ..
me@me-desktop:~/.node-red/public$ cat uptime.txt
up 3 hours, 3 minutes
Last alive 2021-02-09 09:52:35
So uptime.txt us the current session.
Uptime 3:03. So that means it started .... 09:54 - 3:03 = 06:51
Which doesn't tie in with the flow's "powered on at" time.
It says 07:47
The uptime does match. The 2:54 and 3:03` is only 9 minutes and that would have passed as I was looking at things and posting.
Low priority.
But it just seems confusing how the second file got created with todays' date if I haven't tured off the machine today since I turned it on.
Update:
The flow I posted is in a group. Shame on me for not reading all the stuff on groups.
But it would appear that the inject node set to inject on boot is triggered every time I DEPLOY something on any flow on the machine.
Errrr....... Is that what should happen?
If the inject node is set to run at an interval, yes it will run when you deploy.
Only at boot.
And I have deployed OTHER parts of other flows on the machine.
But it seems (note: seems) to be that it is triggered with deploy also.
ARGH!
I added this because I was doing something just below the group and when I deployed I could have sworn I saw the "last booted at" time change.
It did because I have these screen shots.
07:47:37
Now, I know you are going to say: "But you added nodes in the group."
Alas I wasn't smart enough to take a shot before I did that.
But it did change.
And now: typically
When I try: It doesn't.
The Gremlins don't like me and are taunting me.
Are you doing a full or partial deploy?
Partial / changed nodes.
Full deploys aren't needed for what I usually do.
In that case inject nodes set to fire on startup should not inject when you deploy.
Tricky one. I noticed this myself when using groups with the inject node (also "trigger once at start") and some custom nodes that do register/deregister stuff on deploy, even if I didn't touch them at all.
Note: I always use the least disruptive deploy mode "Modified Nodes".
It seems, some changes to groups trigger a redeploy (thus reinitialization) of the nodes within.
Things I observed so far:
Redeploy does happen, if you:
  • add/remove a node to a group
  • move a node within a group that changes the group's size as result
  • change the group's visual properties (name, colors, etc...)
Redeploy does NOT happen, if you:
  • move a node within a group that doesn't change the group's size
  • add/delete wires
As a result, nodes de-register and re-register themselves, and even the context of (untouched) function nodes gets cleared. Those unexpected redeploys of unchanged nodes makes some use-cases harder when modifying running systems, especially when you explicitly rely on "Modified Nodes" only. :sweat_smile:
Is this intended behaviour? Maybe @knolleary has some insights? :slightly_smiling_face:
Ooops.
That's what I meant.
Thanks.
I'll keep those things in mind.
