[{"id":"b66797468a67cb4c","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"600","payloadType":"num","x":430,"y":7580,"wires":[["f36f7029d193716a"]]},{"id":"f36f7029d193716a","type":"change","z":"d1395164b4eec73e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload * 60000","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":7580,"wires":[["08314625ecfc11b3","56c54d06fe7000cc","07f2c16e944cac25","7540e5c86e4a9482","3a700b6789d1b591","15575090472d83b5","b8a000dcac74b96a","172e90efec9ccacf","3b21d12430d9e666"]]},{"id":"08314625ecfc11b3","type":"ui_text_input","z":"d1395164b4eec73e","name":"Ton","label":"Start at : ","tooltip":"","group":"4f791fdc1745d3d9","order":17,"width":0,"height":0,"passthru":false,"mode":"time","delay":"500","topic":"topic","sendOnBlur":false,"className":"","topicType":"msg","x":790,"y":7560,"wires":[["e01fd2ca7e8772fd"]]},{"id":"56c54d06fe7000cc","type":"ui_text_input","z":"d1395164b4eec73e","name":"Ton","label":"Start at : ","tooltip":"","group":"4f791fdc1745d3d9","order":17,"width":0,"height":0,"passthru":false,"mode":"time","delay":"500","topic":"topic","sendOnBlur":false,"className":"","topicType":"msg","x":790,"y":7600,"wires":[[]]},{"id":"07f2c16e944cac25","type":"ui_text_input","z":"d1395164b4eec73e","name":"Ton","label":"Start at : ","tooltip":"","group":"4f791fdc1745d3d9","order":17,"width":0,"height":0,"passthru":false,"mode":"time","delay":"500","topic":"topic","sendOnBlur":false,"className":"","topicType":"msg","x":790,"y":7640,"wires":[[]]},{"id":"7540e5c86e4a9482","type":"ui_text_input","z":"d1395164b4eec73e","name":"Ton","label":"Start at : ","tooltip":"","group":"4f791fdc1745d3d9","order":17,"width":0,"height":0,"passthru":false,"mode":"time","delay":"500","topic":"topic","sendOnBlur":false,"className":"","topicType":"msg","x":790,"y":7680,"wires":[[]]},{"id":"3a700b6789d1b591","type":"ui_text_input","z":"d1395164b4eec73e","name":"Ton","label":"Start at : ","tooltip":"","group":"4f791fdc1745d3d9","order":17,"width":0,"height":0,"passthru":false,"mode":"time","delay":"500","topic":"topic","sendOnBlur":false,"className":"","topicType":"msg","x":790,"y":7720,"wires":[[]]},{"id":"15575090472d83b5","type":"ui_text_input","z":"d1395164b4eec73e","name":"Ton","label":"Start at : ","tooltip":"","group":"4f791fdc1745d3d9","order":17,"width":0,"height":0,"passthru":false,"mode":"time","delay":"500","topic":"topic","sendOnBlur":false,"className":"","topicType":"msg","x":790,"y":7760,"wires":[[]]},{"id":"b8a000dcac74b96a","type":"ui_text_input","z":"d1395164b4eec73e","name":"Ton","label":"Start at : ","tooltip":"","group":"4f791fdc1745d3d9","order":17,"width":0,"height":0,"passthru":false,"mode":"time","delay":"500","topic":"topic","sendOnBlur":false,"className":"","topicType":"msg","x":790,"y":7800,"wires":[[]]},{"id":"172e90efec9ccacf","type":"ui_text_input","z":"d1395164b4eec73e","name":"Ton","label":"Start at : ","tooltip":"","group":"4f791fdc1745d3d9","order":17,"width":0,"height":0,"passthru":false,"mode":"time","delay":"500","topic":"topic","sendOnBlur":false,"className":"","topicType":"msg","x":790,"y":7840,"wires":[[]]},{"id":"3b21d12430d9e666","type":"ui_text_input","z":"d1395164b4eec73e","name":"Ton","label":"Start at : ","tooltip":"","group":"4f791fdc1745d3d9","order":17,"width":0,"height":0,"passthru":false,"mode":"time","delay":"500","topic":"topic","sendOnBlur":false,"className":"","topicType":"msg","x":790,"y":7880,"wires":[[]]},{"id":"e01fd2ca7e8772fd","type":"debug","z":"d1395164b4eec73e","name":"debug 2537","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload &\"-\"& payload1","statusType":"jsonata","x":1010,"y":7560,"wires":[]},{"id":"4f791fdc1745d3d9","type":"ui_group","name":"micro","tab":"c954274bbed7292e","order":1,"disp":false,"width":"18","collapse":false,"className":""},{"id":"c954274bbed7292e","type":"ui_tab","name":"Solar","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
close dashboard browser tab, deploy, open dashboard.
Can you show how you filter unchanged mqtt inputs?
