Hello Colin,
This flow showing image 1 when you play something via youtube.
[{"id":"37b37ea9.6287b2","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"3ccbfc8a.e078f4","type":"kodi-in","z":"37b37ea9.6287b2","name":"kodi","controller":"d202ce84.24c45","x":433,"y":525.67724609375,"wires":[["3fbc2b19.ab6894"]],"outputLabels":["title"]},{"id":"c613a39b.10347","type":"debug","z":"37b37ea9.6287b2","name":"baslik-debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":812,"y":469.67724609375,"wires":[]},{"id":"75da431e.8ee85c","type":"ui_text","z":"37b37ea9.6287b2","group":"2f101410.857cfc","order":13,"width":0,"height":0,"name":"","label":"Başlık","format":"{{msg.payload}}","layout":"col-center","x":823.482666015625,"y":542,"wires":[]},{"id":"3fbc2b19.ab6894","type":"change","z":"37b37ea9.6287b2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.data.data.item.title","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":581.982666015625,"y":603,"wires":[["c613a39b.10347","75da431e.8ee85c"]]},{"id":"b95135e6.b5a078","type":"kodi-in","z":"37b37ea9.6287b2","name":"kodi","controller":"d202ce84.24c45","x":494.982666015625,"y":275,"wires":[["959cce11.c1ad2"]],"outputLabels":["title"]},{"id":"98b0f83d.229a38","type":"debug","z":"37b37ea9.6287b2","name":"baslik-debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":873.982666015625,"y":219,"wires":[]},{"id":"587dc49.c67aa3c","type":"ui_text","z":"37b37ea9.6287b2","group":"2f101410.857cfc","order":15,"width":0,"height":0,"name":"","label":"Yıl","format":"{{msg.payload}}","layout":"col-center","x":885.46533203125,"y":291.32275390625,"wires":[]},{"id":"959cce11.c1ad2","type":"change","z":"37b37ea9.6287b2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.data.data.item.year","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":643.96533203125,"y":352.32275390625,"wires":[["98b0f83d.229a38","587dc49.c67aa3c"]]},{"id":"d202ce84.24c45","type":"kodi-controller","z":"","name":"kodi","host":"localhost","port":"9090"},{"id":"2f101410.857cfc","type":"ui_group","z":"","name":"Kodi Kontrol","tab":"743f23a2.ece61c","order":4,"disp":true,"width":"6","collapse":true},{"id":"743f23a2.ece61c","type":"ui_tab","z":"","name":"R10 Dome","icon":"home","order":2,"disabled":false,"hidden":false}]
and this is the debug message:
13.01.2020 20:29:39node: baslik-debugkodi : msg : Object
object
topic: "kodi"
payload: "Thomas Bergersen - One Million Voices"
_msgid: "ba3635ae.089a08"
I am able to see title and year information if debug output like this. (i.e. image 1)
The same flow, giving this debug when I change the volume:
13.01.2020 20:33:45node: baslik-debugkodi : msg : Object
object
topic: "kodi"
payload: object
notification: "Application.OnVolumeChanged"
data: object
data: object
muted: false
volume: 65
sender: "xbmc"
_msgid: "53955c64.8bad14"
If debug looking like this; I obtain image2. This information is also shown in the dashboard and stays still until I play/pause the song/video.
I hope I could express myself and this post give what you need to solve the problem. Sorry for my bad English.
Edit: this is live radio broadcast flow:
[{"id":"37b37ea9.6287b2","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"d1d980f6.293ef","type":"function","z":"37b37ea9.6287b2","name":"love ice radio","func":"return {\n payload: \n {\n \"cmd\":\"Player.Open\",\n \"args\":{\n \"item\":{\n \"file\":\"http://100radio-love.ice.infomaniak.ch/100radio-love-128.mp3\" \n }\n \n }\n }\n};","outputs":1,"noerr":0,"x":500,"y":322,"wires":[["b5865d60.c3d8d"]]},{"id":"b5865d60.c3d8d","type":"kodi-out","z":"37b37ea9.6287b2","name":"media-server kodi","controller":"d202ce84.24c45","unit_number":"1","output":"1","kodicommand":"empty","x":744.944450378418,"y":325.999990940094,"wires":[]},{"id":"48d0e259.d54aac","type":"inject","z":"37b37ea9.6287b2","name":"play","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":316.99999237060547,"y":321,"wires":[["d1d980f6.293ef"]]},{"id":"37275f95.ac14c","type":"ui_button","z":"37b37ea9.6287b2","name":"","group":"2f101410.857cfc","order":11,"width":0,"height":0,"passthru":false,"label":"Love Radio","tooltip":"","color":"","bgcolor":"","icon":"fa-broadcast-tower","payload":"","payloadType":"str","topic":"","x":400.4826354980469,"y":369.211669921875,"wires":[["d1d980f6.293ef"]]},{"id":"d202ce84.24c45","type":"kodi-controller","z":"","name":"kodi","host":"localhost","port":"9090"},{"id":"2f101410.857cfc","type":"ui_group","z":"","name":"Kodi Kontrol","tab":"743f23a2.ece61c","order":4,"disp":true,"width":"6","collapse":true},{"id":"743f23a2.ece61c","type":"ui_tab","z":"","name":"R10 Dome","icon":"home","order":2,"disabled":false,"hidden":false}]
If radio plays I can't see any info related to title, but I can see volume-related untidy messages like image2. Here is debug message:
13.01.2020 20:45:37node: kodimsg : string[73]
"send error: Error: Server responded with error: Failed to execute method."
