Token in Cred files
i would like to add an influxdb token in flows_cred.json it s done but in my node says authorisation require
Add it manualy (the same) and it s ok (same id)
i missed something ?
You might want to add the token first to the node in the flow, save it and deploy it once, and then copy the flow_creds.json . maybe that might have the token?
Hi thanks , solution not possible i have made a script that install influxdb get a token with API and install node-red i try to make a full automatic installation. from "scratch"
