Topic for mqtt node?
I'm a newbie to node red and I just can't seem to work out the correct topic value for an MQTT node, I am using Tasmota on a Sonoff device and Mosquitto MQTT.
If I use "#" as the topic value I get
tele/sonoff/SENSOR : msg.payload : string[91]
"{"Time":"2019-10-19T17:50:44","SI7021":{"Temperature":14.6,"Humidity":68.7},"TempUnit":"C"}"
This makes sense to me and. if I use "tele/#" as the topic it works as well, however if I use either "sonoff" or "tele/sonoff" I don't get any response.
In Tasmota I have the topic set as "sonoff" and "%prefix%/%topic%/" as the full topic.
Everywhere I look it seems to imply that "sonoff" as the topic should work, what am I doing wrong?
Hope someone can tell me where I am going wrong.
Gordon
this should be it:
Keeping things simple, # is a wildcard.
So # matches anything
tele/# matches anything starting with tele
tele/sonoff/# matches anything starting tele/sonoff
Thanks, I had tried "sonoff/SENSOR" earlier but not since I worked out it needed to start "tele" rookie mistake!
when connecting to the sonoff device, the topic(s) can be seen at the console output during logging events
Try mqtt explorer to get a better view of the topics in the broker (can also be copied from there)
