Transform data from array
How do i transform the below data from this format
[[a,b,c,d],[1,2,3,4],[10,20,30,40]]
to
[[a,1,10],[b,2,20],[c,3,30],[d,4,40]]
i have got some examples on forum for converting static data from one form to another
but, I have got this output from a mysql query and the results are dynamic coming in msg.payload
[[1672064640,1672064580,1672064520,1672064460],[969,969,969,972],[6,6,7,6]]
but I need the same data in this form
[[1672064640,969,6],[1672064580,969,6],[1672064520,969,7],[1672064460,972,6]]
I thought i had the solution when i started this topic, but now i am unable to get the same result.
@smanjunath211 I've moved your question to it's own topic (as the original topic was about barcharts & flexdash, you are more likely to get a reply if the title is more direct to the question, as more members will read it)
I have tried chat.openai.com for this:
My first question was:
So then I tried it without nested loops:
I also asked him to write a Jsonata expression for this, but I think the Change node will explode if you enter such a long expression :wink:
And you can ask him also more specific to do it in one or another way:
A JSONata expression in a change node.
$$.payload[0]#$index.$.[
       $$.payload[1][$index],
       $$.payload[2][$index]
I have no clue how to use this in my situation. please bear with me
please help in understanding what and where should i replace. i am pasting the values i get from my mysql query below
[{"Time":1672071900,"m":0,"temp":93.6},{"Time":1672071840,"m":0,"temp":92.7},{"Time":1672071780,"m":0,"temp":93.3},{"Time":1672071720,"m":0,"temp":93.9}]
and i need this to be in this format for FlexDash input
[[1672064640,86.9,6],[1672064580,93.9,6],[1672064520,96.9,7],[1672064460,97.2,6]]
by using your previous suggestion in another thread, i am able to get upto here.
but it is not in required format.
[[1672072140,1672072080,1672072020,1672071960],[7,6,6,6],[95.7,95.4,95.1,96]]
EDIT
the following change node gives me one set of data in required format. not 4 sets,
what is the change required ?
[{"id":"1003e61f5e5b0cee","type":"change","z":"bbf5094bc59a03b8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload[0].Time.$.[\t   [\t       $,\t       $$.payload[0].m,\t       $$.payload[0].temp \t   ]\t]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":1840,"wires":[["acd36e1efad02cf0","9c0c7165cb86de68"]]}]
change node content
       $$.payload[0].m,
       $$.payload[0].temp
results this
[[1672072980,6,98.1]]
only one set
That is not the same format as
one is an array of objects and the other an array of arrays.
Please be clear with your examples.
To guess on output this may work $$.payload.[$.*]
If you require more help, i will require a sample flow with the input data in a inject node and a clear example of the output.
[edit] from examples given
[{"id":"1b26608e566196d3","type":"inject","z":"da8a6ef0b3c9a5c8","name":"My SQL Query Output (rawdata)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"Time\":1672073400,\"m\":6,\"temp\":99},{\"Time\":1672073340,\"m\":7,\"temp\":98.1},{\"Time\":1672073280,\"m\":6,\"temp\":98.7},{\"Time\":1672073220,\"m\":6,\"temp\":98.7}]","payloadType":"json","x":310,"y":600,"wires":[["95f032d857efa5ed"]]},{"id":"95f032d857efa5ed","type":"change","z":"da8a6ef0b3c9a5c8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload.[$.*]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":600,"wires":[["22e0d6e0318685cd"]]},{"id":"22e0d6e0318685cd","type":"debug","z":"da8a6ef0b3c9a5c8","name":"debug 86","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":700,"y":600,"wires":[]},{"id":"06fa988581035686","type":"inject","z":"da8a6ef0b3c9a5c8","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[[1672073400,6,99],[1672073340,7,98.1],[1672073280,6,98.7],[1672073220,6,98.7]]","payloadType":"json","x":230,"y":640,"wires":[["d2d1a9c2eae2f28a"]]},{"id":"d2d1a9c2eae2f28a","type":"debug","z":"da8a6ef0b3c9a5c8","name":"debug 87","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":600,"y":640,"wires":[]}]
Sorry for this confusion, i have a totally messed up flow doing so many things
please consider this.
first inject is what i get from mysql query
second inject is what i expect the change node to do.
[{"id":"1b26608e566196d3","type":"inject","z":"bbf5094bc59a03b8","name":"My SQL Query Output (rawdata)","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"Time\":1672073400,\"m\":6,\"temp\":99},{\"Time\":1672073340,\"m\":7,\"temp\":98.1},{\"Time\":1672073280,\"m\":6,\"temp\":98.7},{\"Time\":1672073220,\"m\":6,\"temp\":98.7}]","payloadType":"json","x":230,"y":1940,"wires":[["22e0d6e0318685cd"]]},{"id":"06fa988581035686","type":"inject","z":"bbf5094bc59a03b8","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[[1672073400,6,99],[1672073340,7,98.1],[1672073280,6,98.7],[1672073220,6,98.7]]","payloadType":"json","x":150,"y":1980,"wires":[["d2d1a9c2eae2f28a"]]},{"id":"22e0d6e0318685cd","type":"debug","z":"bbf5094bc59a03b8","name":"debug 86","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":520,"y":1940,"wires":[]},{"id":"d2d1a9c2eae2f28a","type":"debug","z":"bbf5094bc59a03b8","name":"debug 87","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":520,"y":1980,"wires":[]}]
Have you tried what @E1cid suggested in his last post?
He has just edited and added the solution at the end of post. and it WORKS!
and amazingly the content of the change node is just this
$$.payload.[$.*]
Flexdash is taking the data happily.
Just check the final solution, its just one word. Amazing @E1cid and his Jsonata skills.
