I have a small question regarding the tree list widget.
I have a list with child items. If a child is checked I like that the parents are checked dynamically.
I have done a event function which changes the data but this don`t refesh the tree conetent:
var extensionsTreeCheck = function(item) {
var checkParents = function(parent) {
parent.selected=true;
if (parent.hasOwnProperty('parent')) checkParents(parent.parent);
if (item.hasOwnProperty('parent')) checkParents(item.parent);
So my workaround is this. Reading the tree data with `.data()' and writing it back to the widget.
.on('treelistselect', function(event, item) {
if (item.selected) {
node.extensionsTreeCheck(item);
extensionData[$('#node-input-exDeviceId').val() || node.exDeviceId] = treeLists[id].treeList('data');
treeLists[id].treeList('data',extensionData[$('#node-input-exDeviceId').val() || node.exDeviceId]);
(I have more than one treeList so this is why there is a treelist[id]. And many contexts depending on a select dropdown.)
This works but it is not the best way (I think) as it clears the treeList and redraws it.
Is there a better solution?
