TreeList widget is not visible
I studied the contents of the link, but the treelist is not visible.
TreeList Widget : Node-RED
node-red/60-link.html at master · node-red/node-red · GitHub
Below is my code.
<script type="text/html" data-template-name="api-gui">
    <div class="form-row node-input-link-row"></div>
</script>
 oneditprepare: function() {
            let treeList;
            treeList = $("<div>")
            .css({width: "100%", height: "100%"})
            .appendTo(".node-input-link-row")
            .treeList({});
            treeList.treeList('data',[{label:"Colours", id:'my-red-item'}]);
            setTimeout(function() {
                treeList.treeList('show', 'my-red-item');
            }, 100);
I ran it even without setTimeout, but I don't see it.
Did I write something wrong?
Please, give me a solution.
Please don't double post. There was no need to open this 2nd post.
People will answer if they know how to help.
Your code looks fine. However, you need to resize the form-row.
You could add a height style ...
<div class="form-row node-input-link-row" style="height: calc(100% - 40px);">
OR
Do what the link node does (as I linked to in your other thread)
See this: 60-link.html#L156-L165
and this: 60-link.html#L267
Thanks for your reply.
I solved the problem thanks to you!
And I'll make sure not to double-post.
