Trigger a flow from other flow (instead of polling)
In Flow 1 I have a function which calculates stuff and then returns a msg with some content.
 msg.payload = 2;
 msg.text = "State 10 reached";
In the second flow I have a periodic trigger which checks the state of a variable every minute.
Now I want to trigger this second flow from the function body from flow 1. I tried of course to educate myself but got stuck.
Reason that I want it to trigger instead of polling is that flow 2 should start immediately after in flow 1 that condition is reached.
Hi, welcome to the forum.
Cant you just use a link-out (attached to the function that calculates) connected to a link-in node attached to the 2nd flow where you want to trigger something?
you can always add a filter node that checks the value has actually changed.
Perfect, exactly what was looking for! Thanks!
