Trigger reset with a deploy
hello
i am not sure it is a bug or a feature but,
in a flow i use a trigger.
the flow works and have a active trigger, so it waits!
if i set up into another flow and deploy it it will reset all trigger in all flows on the node Red.
i think to deploy new nodes should not make a reset of the Node 'trigger'
have a nice day
vinc
Don't deploy all nodes as that essentially reinitialises all nodes. click the drop down and choose modified nodes. Then when you deploy, only added/modified nodes will be affected.
Merci found this option
