I'm relatively new to this, so apologies in advance.
I'm polling an API and storing a few time stamps and converting them to Unix to do basic calculations. What I would like to do is have an I/O triggered when the current time is 24 hours prior to the stored timestamp.
I'm able get the values and see them in the debug nodes but storing them to call or compare is proving to be difficult:
sysTime = Date.now()
startTimeTwentyFour = msg.TFhourStart
while (msg.eventid !== null)
if (sysTime >= startTimeTwentyFour){
trigger = 1;
} else {
trigger = 0;}
I'm probably doing something obviously wrong, but can't seem to figure it out. How can I pass the trigger value??
[{"id":"b5d50dec.34ffc","type":"http request","z":"64b0889c.049f88","name":"Dispatch Events","method":"GET","ret":"txt","paytoqs":"query","url":"https://link-stg.cpowercorp.com/vLinkService.svc/{{{seshid}}}/DispatchEvents","tls":"","persist":true,"proxy":"","authType":"","senderr":false,"x":120,"y":240,"wires":[["de017d2b.63308","8ef32e9e.5606b"]]},{"id":"de017d2b.63308","type":"xml","z":"64b0889c.049f88","name":"","property":"payload","attr":"","chr":"","x":130,"y":320,"wires":[["3b6b89f24daf877e","e2b7f3c51ac56d1f"]]},{"id":"e00b1d51a858d12a","type":"function","z":"64b0889c.049f88","name":"24 hour logic","func":"sysTime = Date.now()\nstartTimeTwentyFour = msg.TFhourStart\nwhile (global.eventid !== null)\n if (sysTime >= startTimeTwentyFour){\n trigger = 1;\n } else {\n trigger = 0;}\n \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1110,"y":360,"wires":[["1e75c370236a42e8"]]},{"id":"3b6b89f24daf877e","type":"change","z":"64b0889c.049f88","name":"","rules":[{"t":"set","p":"StartTime","pt":"msg","to":"payload.DispatchEventResult.DispatchEventList[0].DispatchEvent[0].StartDate[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":320,"wires":[["74f49c601e5bd373"]]},{"id":"e2b7f3c51ac56d1f","type":"change","z":"64b0889c.049f88","name":"","rules":[{"t":"set","p":"EndTime","pt":"msg","to":"payload.DispatchEventResult.DispatchEventList[0].DispatchEvent[0].EndDate[0]","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":360,"wires":[["93b144dedfa00494"]]},{"id":"1e75c370236a42e8","type":"debug","z":"64b0889c.049f88","name":"","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1340,"y":320,"wires":[]},{"id":"93b144dedfa00494","type":"function","z":"64b0889c.049f88","name":"End Time Epoch Conv","func":"msg.payload = new Date(msg.EndTime)\nmsg.payload = msg.payload.getTime()\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":360,"wires":[["fba9751eab0a4d17"]]},{"id":"fba9751eab0a4d17","type":"debug","z":"64b0889c.049f88","name":"End Time Epoch Conv","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":660,"y":400,"wires":[]},{"id":"74f49c601e5bd373","type":"function","z":"64b0889c.049f88","name":"Start Time Epoch Conv","func":"msg.payload = new Date(msg.StartTime)\nmsg.payload = msg.payload.getTime()\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":670,"y":320,"wires":[["f4e69f49fe1e21f3"]]},{"id":"edcb7613e0cf2e84","type":"debug","z":"64b0889c.049f88","name":"Start Time Epoch Conv","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1370,"y":380,"wires":[]},{"id":"f4e69f49fe1e21f3","type":"function","z":"64b0889c.049f88","name":"Start Time Epoch Conv -24hours","func":"msg.payload = msg.payload - (24*60*60);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":950,"y":320,"wires":[["9f0acfc3bccac6c1"]]},{"id":"69bc7967decad8a4","type":"debug","z":"64b0889c.049f88","name":"Start Time Epoch Conv -24hours","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1390,"y":260,"wires":[]},{"id":"9f0acfc3bccac6c1","type":"change","z":"64b0889c.049f88","name":"","rules":[{"t":"set","p":"TFhourStart","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":920,"y":360,"wires":[["69bc7967decad8a4","e00b1d51a858d12a"]]}]
