I am trying to wrap up a proof of concept i am making to store and display process control data in a node red dashboard. i will start by saying i am very green when it comes to html, javascript, and node-red. i have spent a fair amount of time in node red trying to learn as i go but i seem to be stumped and ai code generation has almost gotten me there but i am having an issue when using actual data instead of test/sample data.
My data is going to be pulled from a ms-sql database via a "node-red-contrib-mssql-plus" node. here is a small sample of how the data is output via msg.payload:
"[{"Stamp":"2025-07-08T12:25:50.427Z","Last_Weighed":203.24,"Target":156,"LCL":103.89,"UCL":201.45,"LSL":120.28,"USL":179.91,"Xbar":164.772},{"Stamp":"2025-07-08T12:25:51.123Z","Last_Weighed":199.11,"Target":156,"LCL":103.89,"UCL":201.45,"LSL":120.28,"USL":179.91,"Xbar":164.888},{"Stamp":"2025-07-08T12:25:51.660Z","Last_Weighed":186.5,"Target":156,"LCL":103.89,"UCL":201.45,"LSL":120.28,"USL":179.91,"Xbar":164.961},{"Stamp":"2025-07-08T12:25:52.233Z","Last_Weighed":171.52,"Target":156,"LCL":103.89,"UCL":201.45,"LSL":120.28,"USL":179.91,"Xbar":164.983},{"Stamp":"2025-07-08T12:25:52.877Z","Last_Weighed":148.91,"Target":156,"LCL":103.89,"UCL":201.45,"LSL":120.28,"USL":179.91,"Xbar":164.929}]"
Here is what the layout of my dashboard (@flowfuse/node-red-dashboard) looks like with the working static chart:
now, once i amend the code to accept data via msg.payload instead of it being statically built in, the chart does not display at all, just leaving a blank canvas. Any thoughts on where my issue lies?
Thank you in advance
"id": "db379ea65e11bedc",
"type": "ui-template",
"z": "422ecc23a312cf7c",
"group": "78941b46bdde56bb",
"page": "",
"ui": "",
"name": "working static chart (dont delete)",
"order": 17,
"width": "3",
"height": "10",
"head": "",
"format": "<!DOCTYPE html>\n<html>\n<head>\n <title>Line Chart Example</title>\n <script src=\"https://cdn.jsdelivr.net/npm/chart.js\"></script>\n</head>\n<body>\n <canvas id=\"myChart\" width=\"900\" height=\"450\"></canvas>\n\n <script>\n // Example data (replace with your actual data arrays)\n const stamp = [\n \"2025-07-01T10:00:00Z\",\n \"2025-07-01T11:00:00Z\",\n \"2025-07-01T12:00:00Z\"\n ];\n\n const last_weighed = [98, 99.5, 97.8];\n const target = [100, 100, 100];\n const xbar = [98.5, 99.2, 98.7];\n const lcl = [95, 95, 95];\n const ucl = [105, 105, 105];\n const lsl = [90, 90, 90];\n const usl = [110, 110, 110];\n\n const ctx = document.getElementById('myChart').getContext('2d');\n\n new Chart(ctx, {\n type: 'line',\n data: {\n labels: stamp, // x-axis values\n datasets: [\n {\n label: 'Last Weighed',\n data: last_weighed,\n borderColor: 'blue',\n fill: false,\n tension: 0.1\n },\n {\n label: 'Target',\n data: target,\n borderColor: 'green',\n fill: false,\n borderDash: [5, 5],\n tension: 0.1\n },\n {\n label: 'X̄ (Xbar)',\n data: xbar,\n borderColor: 'black',\n fill: false,\n tension: 0.1\n },\n {\n label: 'LCL',\n data: lcl,\n borderColor: 'orange',\n fill: false,\n borderDash: [4, 4],\n tension: 0.1\n },\n {\n label: 'UCL',\n data: ucl,\n borderColor: 'orange',\n fill: false,\n borderDash: [4, 4],\n tension: 0.1\n },\n {\n label: 'LSL',\n data: lsl,\n borderColor: 'red',\n fill: false,\n borderDash: [6, 2],\n tension: 0.1\n },\n {\n label: 'USL',\n data: usl,\n borderColor: 'red',\n fill: false,\n borderDash: [6, 2],\n tension: 0.1\n }\n ]\n },\n options: {\n responsive: true,\n scales: {\n x: {\n type: 'time',\n time: {\n tooltipFormat: 'MMM d, HH:mm',\n unit: 'hour'\n },\n title: {\n display: true,\n text: 'Timestamp'\n }\n },\n y: {\n title: {\n display: true,\n text: 'Value'\n }\n }\n },\n plugins: {\n legend: {\n position: 'top'\n },\n title: {\n display: true,\n text: 'Process Control Chart'\n }\n }\n }\n });\n </script>\n</body>\n</html>",
"storeOutMessages": true,
"passthru": true,
"resendOnRefresh": true,
"templateScope": "local",
"className": "",
"x": 470,
"y": 1520,
"id": "3a6b0941167264eb",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 200,
"y": 1520,
"db379ea65e11bedc"
"id": "0bdbcb2aab9e05ba",
"page": "",
"ui": "",
"name": "chart if injected data - not working",
"order": 12,
"width": "3",
"height": "10",
"head": "",
"format": "<style>\n#myChart {\n width: 100% !important;\n height: 300px !important;\n}\n</style>\n\n<canvas id=\"myChart\"></canvas>\n\n<script src=\"https://cdn.jsdelivr.net/npm/chart.js\"></script>\n\n<script>\nexport default {\n data() {\n return {\n chart: null\n };\n },\n methods: {\n renderChart(data) {\n if (!Array.isArray(data) || data.length === 0) return;\n\n const labels = data.map(d => new Date(d.Stamp).toLocaleTimeString());\n const lastWeighed = data.map(d => d.Last_Weighed);\n const target = data.map(d => d.Target);\n const xbar = data.map(d => d.Xbar);\n const lcl = data.map(d => d.LCL);\n const ucl = data.map(d => d.UCL);\n const lsl = data.map(d => d.LSL);\n const usl = data.map(d => d.USL);\n\n const ctx = this.$el.querySelector('#myChart').getContext('2d');\n\n if (this.chart) {\n this.chart.destroy();\n }\n\n this.chart = new Chart(ctx, {\n type: 'line',\n data: {\n labels: labels,\n datasets: [\n {\n label: 'Last Weighed',\n data: lastWeighed,\n borderColor: 'blue',\n fill: false,\n tension: 0.1\n },\n {\n label: 'Target',\n data: target,\n borderColor: 'green',\n fill: false,\n borderDash: [5, 5],\n tension: 0.1\n },\n {\n label: 'X̄ (Xbar)',\n data: xbar,\n borderColor: 'black',\n fill: false,\n tension: 0.1\n },\n {\n label: 'LCL',\n data: lcl,\n borderColor: 'orange',\n fill: false,\n borderDash: [4, 4],\n tension: 0.1\n },\n {\n label: 'UCL',\n data: ucl,\n borderColor: 'orange',\n fill: false,\n borderDash: [4, 4],\n tension: 0.1\n },\n {\n label: 'LSL',\n data: lsl,\n borderColor: 'red',\n fill: false,\n borderDash: [6, 2],\n tension: 0.1\n },\n {\n label: 'USL',\n data: usl,\n borderColor: 'red',\n fill: false,\n borderDash: [6, 2],\n tension: 0.1\n }\n ]\n },\n options: {\n responsive: true,\n scales: {\n x: {\n title: {\n display: true,\n text: 'Timestamp'\n }\n },\n y: {\n title: {\n display: true,\n text: 'Value'\n }\n }\n },\n plugins: {\n legend: {\n position: 'top'\n },\n title: {\n display: true,\n text: 'Process Control Chart'\n }\n }\n }\n });\n }\n },\n watch: {\n $props: {\n immediate: true,\n deep: true,\n handler(newProps) {\n if (newProps.payload) {\n this.renderChart(newProps.payload);\n }\n }\n }\n }\n};\n</script>",
"passthru": true,
"className": "",
"x": 460,
"y": 1560,
"id": "f56cd6a5f86661a1",
"type": "inject",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "[{\"Stamp\":\"2025-07-08T12:25:04.220Z\",\"Last_Weighed\":105.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.383},{\"Stamp\":\"2025-07-08T12:25:04.917Z\",\"Last_Weighed\":90.14,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.044},{\"Stamp\":\"2025-07-08T12:25:05.473Z\",\"Last_Weighed\":105.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.778},{\"Stamp\":\"2025-07-08T12:25:06.113Z\",\"Last_Weighed\":115.02,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.558},{\"Stamp\":\"2025-07-08T12:25:06.660Z\",\"Last_Weighed\":130.99,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.411},{\"Stamp\":\"2025-07-08T12:25:07.327Z\",\"Last_Weighed\":148.91,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.346},{\"Stamp\":\"2025-07-08T12:25:07.860Z\",\"Last_Weighed\":171.52,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.382},{\"Stamp\":\"2025-07-08T12:25:08.433Z\",\"Last_Weighed\":186.5,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.485},{\"Stamp\":\"2025-07-08T12:25:09.057Z\",\"Last_Weighed\":199.11,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.643},{\"Stamp\":\"2025-07-08T12:25:09.610Z\",\"Last_Weighed\":203.24,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.817},{\"Stamp\":\"2025-07-08T12:25:10.310Z\",\"Last_Weighed\":210.72,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.023},{\"Stamp\":\"2025-07-08T12:25:10.850Z\",\"Last_Weighed\":213.66,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.24},{\"Stamp\":\"2025-07-08T12:25:11.507Z\",\"Last_Weighed\":210.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.441},{\"Stamp\":\"2025-07-08T12:25:12.040Z\",\"Last_Weighed\":210.72,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.641},{\"Stamp\":\"2025-07-08T12:25:12.743Z\",\"Last_Weighed\":203.24,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.808},{\"Stamp\":\"2025-07-08T12:25:13.273Z\",\"Last_Weighed\":199.11,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.955},{\"Stamp\":\"2025-07-08T12:25:13.923Z\",\"Last_Weighed\":186.5,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":165.047},{\"Stamp\":\"2025-07-08T12:25:14.463Z\",\"Last_Weighed\":171.52,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":165.075},{\"Stamp\":\"2025-07-08T12:25:15.037Z\",\"Last_Weighed\":148.91,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":165.006},{\"Stamp\":\"2025-07-08T12:25:15.737Z\",\"Last_Weighed\":130.99,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.863},{\"Stamp\":\"2025-07-08T12:25:16.290Z\",\"Last_Weighed\":115.02,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.653},{\"Stamp\":\"2025-07-08T12:25:16.920Z\",\"Last_Weighed\":105.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.406},{\"Stamp\":\"2025-07-08T12:25:17.453Z\",\"Last_Weighed\":90.14,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.096},{\"Stamp\":\"2025-07-08T12:25:18.040Z\",\"Last_Weighed\":105.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.854},{\"Stamp\":\"2025-07-08T12:25:18.633Z\",\"Last_Weighed\":115.02,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.652},{\"Stamp\":\"2025-07-08T12:25:19.220Z\",\"Last_Weighed\":130.99,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.517},{\"Stamp\":\"2025-07-08T12:25:19.923Z\",\"Last_Weighed\":148.91,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.457},{\"Stamp\":\"2025-07-08T12:25:20.467Z\",\"Last_Weighed\":171.52,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.49},{\"Stamp\":\"2025-07-08T12:25:21.110Z\",\"Last_Weighed\":186.5,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.584},{\"Stamp\":\"2025-07-08T12:25:21.643Z\",\"Last_Weighed\":199.11,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.728},{\"Stamp\":\"2025-07-08T12:25:22.227Z\",\"Last_Weighed\":203.24,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.887},{\"Stamp\":\"2025-07-08T12:25:22.810Z\",\"Last_Weighed\":210.72,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.075},{\"Stamp\":\"2025-07-08T12:25:23.517Z\",\"Last_Weighed\":213.66,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.273},{\"Stamp\":\"2025-07-08T12:25:24.053Z\",\"Last_Weighed\":210.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.458},{\"Stamp\":\"2025-07-08T12:25:24.717Z\",\"Last_Weighed\":210.72,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.641},{\"Stamp\":\"2025-07-08T12:25:25.260Z\",\"Last_Weighed\":203.24,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.794},{\"Stamp\":\"2025-07-08T12:25:25.830Z\",\"Last_Weighed\":199.11,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.929},{\"Stamp\":\"2025-07-08T12:25:26.430Z\",\"Last_Weighed\":186.5,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":165.014},{\"Stamp\":\"2025-07-08T12:25:27.140Z\",\"Last_Weighed\":171.52,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":165.039},{\"Stamp\":\"2025-07-08T12:25:27.683Z\",\"Last_Weighed\":148.91,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.976},{\"Stamp\":\"2025-07-08T12:25:28.243Z\",\"Last_Weighed\":130.99,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.845},{\"Stamp\":\"2025-07-08T12:25:28.810Z\",\"Last_Weighed\":115.02,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.652},{\"Stamp\":\"2025-07-08T12:25:29.523Z\",\"Last_Weighed\":105.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.425},{\"Stamp\":\"2025-07-08T12:25:30.067Z\",\"Last_Weighed\":90.14,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.14},{\"Stamp\":\"2025-07-08T12:25:30.637Z\",\"Last_Weighed\":105.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.917},{\"Stamp\":\"2025-07-08T12:25:31.347Z\",\"Last_Weighed\":115.02,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.731},{\"Stamp\":\"2025-07-08T12:25:31.890Z\",\"Last_Weighed\":130.99,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.607},{\"Stamp\":\"2025-07-08T12:25:32.430Z\",\"Last_Weighed\":148.91,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.551},{\"Stamp\":\"2025-07-08T12:25:33.107Z\",\"Last_Weighed\":171.52,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.581},{\"Stamp\":\"2025-07-08T12:25:33.653Z\",\"Last_Weighed\":186.5,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.667},{\"Stamp\":\"2025-07-08T12:25:34.293Z\",\"Last_Weighed\":199.11,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.799},{\"Stamp\":\"2025-07-08T12:25:34.847Z\",\"Last_Weighed\":203.24,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.946},{\"Stamp\":\"2025-07-08T12:25:35.453Z\",\"Last_Weighed\":210.72,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.119},{\"Stamp\":\"2025-07-08T12:25:36.017Z\",\"Last_Weighed\":213.66,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.302},{\"Stamp\":\"2025-07-08T12:25:36.607Z\",\"Last_Weighed\":210.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.472},{\"Stamp\":\"2025-07-08T12:25:37.310Z\",\"Last_Weighed\":210.72,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.641},{\"Stamp\":\"2025-07-08T12:25:37.837Z\",\"Last_Weighed\":203.24,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.782},{\"Stamp\":\"2025-07-08T12:25:38.423Z\",\"Last_Weighed\":199.11,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.907},{\"Stamp\":\"2025-07-08T12:25:39.030Z\",\"Last_Weighed\":186.5,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.985},{\"Stamp\":\"2025-07-08T12:25:39.610Z\",\"Last_Weighed\":171.52,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":165.009},{\"Stamp\":\"2025-07-08T12:25:40.307Z\",\"Last_Weighed\":148.91,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.951},{\"Stamp\":\"2025-07-08T12:25:40.847Z\",\"Last_Weighed\":130.99,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.829},{\"Stamp\":\"2025-07-08T12:25:41.433Z\",\"Last_Weighed\":115.02,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.651},{\"Stamp\":\"2025-07-08T12:25:42.017Z\",\"Last_Weighed\":105.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.441},{\"Stamp\":\"2025-07-08T12:25:42.723Z\",\"Last_Weighed\":90.14,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.178},{\"Stamp\":\"2025-07-08T12:25:43.263Z\",\"Last_Weighed\":105.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.97},{\"Stamp\":\"2025-07-08T12:25:43.927Z\",\"Last_Weighed\":115.02,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.798},{\"Stamp\":\"2025-07-08T12:25:44.447Z\",\"Last_Weighed\":130.99,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.683},{\"Stamp\":\"2025-07-08T12:25:45.020Z\",\"Last_Weighed\":148.91,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.631},{\"Stamp\":\"2025-07-08T12:25:45.717Z\",\"Last_Weighed\":171.52,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.659},{\"Stamp\":\"2025-07-08T12:25:46.247Z\",\"Last_Weighed\":186.5,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.738},{\"Stamp\":\"2025-07-08T12:25:46.910Z\",\"Last_Weighed\":199.11,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.861},{\"Stamp\":\"2025-07-08T12:25:47.553Z\",\"Last_Weighed\":203.24,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.996},{\"Stamp\":\"2025-07-08T12:25:48.093Z\",\"Last_Weighed\":210.72,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.157},{\"Stamp\":\"2025-07-08T12:25:48.633Z\",\"Last_Weighed\":213.66,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.326},{\"Stamp\":\"2025-07-08T12:25:49.313Z\",\"Last_Weighed\":210.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.484},{\"Stamp\":\"2025-07-08T12:25:49.853Z\",\"Last_Weighed\":210.72,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.641},{\"Stamp\":\"2025-07-08T12:25:50.427Z\",\"Last_Weighed\":203.24,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.772},{\"Stamp\":\"2025-07-08T12:25:51.123Z\",\"Last_Weighed\":199.11,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.888},{\"Stamp\":\"2025-07-08T12:25:51.660Z\",\"Last_Weighed\":186.5,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.961},{\"Stamp\":\"2025-07-08T12:25:52.233Z\",\"Last_Weighed\":171.52,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.983},{\"Stamp\":\"2025-07-08T12:25:52.877Z\",\"Last_Weighed\":148.91,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.929},{\"Stamp\":\"2025-07-08T12:25:53.420Z\",\"Last_Weighed\":130.99,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.816},{\"Stamp\":\"2025-07-08T12:25:54.117Z\",\"Last_Weighed\":115.02,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.651},{\"Stamp\":\"2025-07-08T12:25:54.657Z\",\"Last_Weighed\":105.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.455},{\"Stamp\":\"2025-07-08T12:25:55.340Z\",\"Last_Weighed\":90.14,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.21},{\"Stamp\":\"2025-07-08T12:25:55.870Z\",\"Last_Weighed\":105.55,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.017},{\"Stamp\":\"2025-07-08T12:25:56.517Z\",\"Last_Weighed\":115.02,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.856},{\"Stamp\":\"2025-07-08T12:25:57.087Z\",\"Last_Weighed\":130.99,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.749},{\"Stamp\":\"2025-07-08T12:25:57.630Z\",\"Last_Weighed\":148.91,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.7},{\"Stamp\":\"2025-07-08T12:25:58.247Z\",\"Last_Weighed\":171.52,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.726},{\"Stamp\":\"2025-07-08T12:25:58.837Z\",\"Last_Weighed\":186.5,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.8},{\"Stamp\":\"2025-07-08T12:25:59.407Z\",\"Last_Weighed\":199.11,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":163.913},{\"Stamp\":\"2025-07-08T12:26:00.120Z\",\"Last_Weighed\":203.24,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.04},{\"Stamp\":\"2025-07-08T12:26:00.663Z\",\"Last_Weighed\":210.72,\"Target\":156,\"LCL\":103.89,\"UCL\":201.45,\"LSL\":120.28,\"USL\":179.91,\"Xbar\":164.189}]",
"payloadType": "json",
"x": 210,
"y": 1560,
"0bdbcb2aab9e05ba"
"id": "78941b46bdde56bb",
"type": "ui-group",
"name": "Report",
"page": "c9362b93aa48a81c",
"width": "6",
"height": "1",
"order": 1,
"showTitle": true,
"className": "",
"visible": "true",
"disabled": "false",
"groupType": "default"
"id": "c9362b93aa48a81c",
"type": "ui-page",
"name": "Reporting",
"ui": "0984762e823e159c",
"path": "/Reporting",
"icon": "home",
"layout": "tabs",
"theme": "8842e361403cacce",
"breakpoints": [
"name": "Default",
"px": "0",
"cols": "3"
"name": "Tablet",
"px": "576",
"cols": "6"
"name": "Small Desktop",
"px": "768",
"cols": "9"
"name": "Desktop",
"px": "1024",
"cols": "12"
"order": 2,
"className": "",
"visible": "true",
"disabled": "false"
"id": "0984762e823e159c",
"type": "ui-base",
"name": "My Dashboard",
"path": "/dashboard",
"includeClientData": true,
"acceptsClientConfig": [
"ui-notification",
"ui-control"
"showPathInSidebar": false,
"headerContent": "page",
"navigationStyle": "default",
"titleBarStyle": "default",
"notificationDisplayTime": 5
"id": "8842e361403cacce",
"type": "ui-theme",
"name": "All Fill",
"colors": {
"surface": "#433d3d",
"primary": "#ff4d00",
"bgPage": "#918d8d",
"groupBg": "#ffffff",
"groupOutline": "#ff4d00"
"sizes": {
"density": "default",
"pagePadding": "12px",
"groupGap": "12px",
"groupBorderRadius": "4px",
"widgetGap": "12px"
