Hi all,
I'm having trouble getting all my flows rto show up in the layout. I have two flows but I can't get both to show up in the Layout.
Been looking at a tutorial that says to select the proper group on each object but I can't see how to do that.
Also, I am trying to set a switch to toggle but can't get that to work either.
I am controlling a Raspberry Pi Zero W. I am able to turn on and off an LED with two switches but cannot get the CPU temperature (using a parsing function and a gauge) .
Thanks in advance for your help
Mike
I'm afraid you're not gonna get a lot of help unless you post screen shots and your flow (export it and paste between three ticks ``` code here ```)
There is barely anything to go on with what you have posted.
Some tips...
- Add debug nodes after every node and verify what you expect is correct.
- Be more specific
- nclude the OS, node version, npm version, node-red version,
- what nodes you're using,
- what hardware you're using and communicating to
- What you have tried and where you're stuck
- Check out examples and the cookbook (links at the top of this forum or search cookbook)
- Search this forum - there are many examples and tips
Hi Mike.
I too (as do many people) have a RPI.
For me, getting the temperature is a command.
I put an exec node in the flow and enter this command in it to be run.
/opt/vc/bin/vcgencmd measure_temp| sed 's/[^0-9]*//g'
The exec node has 3 outputs. I take the output of the first (top) output and put it through a function node with this in it:
msg.payload = Number(msg.payload)/10;
msg.topic=global.get('myDeviceName');
msg.topic ="TEMP/" + msg.topic;
Then the message is on-sent to other nodes.
If the node wants the temperature, it just reads the msg.payload.
The msg.payload can then be sent into a gauge or chart node quite easily.
Hope that helps.
