[{"id":"260e8ac429d0545f","type":"inject","z":"38412910c32a18b1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"on","payloadType":"str","x":110,"y":480,"wires":[["9a277257f84c649d"]]},{"id":"9a277257f84c649d","type":"function","z":"38412910c32a18b1","name":"function 13","func":"let msg1 = {}\nlet msg2 = {}\nlet msg3 = {}\nmsg3.reset = ''\n\nlet lux = flow.get('lux')\n\nlet pulse = true // false if pir have timeout\n\nlet invar = msg.payload\nswitch (invar) {\n case 'on':\n msg1.payload = lux\n node.send([msg1, msg3, msg3])\n if(pulse) {\n msg2.payload = 'on'\n node.send([null, msg2, null])\n }\n break\n case 'off':\n if(!pulse) {\n msg2.payload = 'on'\n node.send([null, msg2, null])\n }\n break\n}\n\n","outputs":3,"noerr":0,"initialize":"","finalize":"","libs":[],"x":280,"y":480,"wires":[["ba1fcebbcab40872","e16392bf3f5d81a7"],["278243f9175161ae"],["ac7a68b5e196c905"]]},{"id":"ba1fcebbcab40872","type":"zigbee2mqtt-out","z":"38412910c32a18b1","name":"","server":"389af9cbf5b0a79d","friendly_name":"Krone1 (4058075208421)","device_id":"0xf0d1b8000017513c","command":"brightness","commandType":"z2m_cmd","payload":"payload","payloadType":"msg","optionsValue":"","optionsType":"nothing","x":890,"y":460,"wires":[]},{"id":"278243f9175161ae","type":"delay","z":"38412910c32a18b1","name":"","pauseType":"delay","timeout":"6","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":460,"y":500,"wires":[["ac92ca3490c5d4a5"]]},{"id":"ac7a68b5e196c905","type":"delay","z":"38412910c32a18b1","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":460,"y":560,"wires":[["2130ac0e97cc13fd"]]},{"id":"ac92ca3490c5d4a5","type":"function","z":"38412910c32a18b1","name":"function 14","func":"let msg1 = {}\nlet activ = flow.get('activ')\nlet lux = flow.get('lux')\n\nif (activ) {\n msg1.payload = lux / 4\n node.warn(\"lux/4\");\n}\nif (!activ) {\n msg1.payload = lux / 20\n node.warn(\"lux/20\");\n}\nnode.send(msg1);","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":630,"y":500,"wires":[["ba1fcebbcab40872","ac7a68b5e196c905","e16392bf3f5d81a7"]]},{"id":"2130ac0e97cc13fd","type":"function","z":"38412910c32a18b1","name":"function 15","func":"let msg1 = {}\n\nmsg1.payload = 0\nnode.send(msg1);","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":630,"y":560,"wires":[["ba1fcebbcab40872","e16392bf3f5d81a7"]]},{"id":"4fe037caae8f2558","type":"inject","z":"38412910c32a18b1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"off","payloadType":"str","x":110,"y":520,"wires":[["9a277257f84c649d"]]},{"id":"bcf763031ab16414","type":"inject","z":"38412910c32a18b1","name":"true at 21:00","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"00 21 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":140,"y":340,"wires":[["5be6ae88718cddbb"]]},{"id":"e65801e6292657cc","type":"inject","z":"38412910c32a18b1","name":"false at 05:00","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"00 05 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":140,"y":380,"wires":[["5be6ae88718cddbb"]]},{"id":"5be6ae88718cddbb","type":"function","z":"38412910c32a18b1","name":"function 16","func":"let msg1 = {}\nlet activ = flow.get('activ') || false\nlet lux = flow.get('lux') || 50\n\nif (msg.payload === true) {\n activ = true\n node.status({ fill: \"green\", shape: \"ring\", text: \"on\" });\n lux = 100\n}\n\nif (msg.payload === false) {\n activ = false\n node.status({ fill: \"red\", shape: \"ring\", text: \"off\" })\n lux = 50\n}\n\nmsg1.payload = activ\nmsg1.topic = 'control'\nflow.set('activ', activ)\nflow.set('lux', lux)\n\nreturn msg1","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":370,"y":360,"wires":[[]]},{"id":"7b1201567f0b7548","type":"comment","z":"38412910c32a18b1","name":"let pulse = true // false if pir have timeout","info":"","x":380,"y":440,"wires":[]},{"id":"e16392bf3f5d81a7","type":"debug","z":"38412910c32a18b1","name":"debug 8","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":860,"y":400,"wires":[]},{"id":"389af9cbf5b0a79d","type":"zigbee2mqtt-server","name":"","host":"localhost:1883","mqtt_port":"1883","mqtt_username":"","mqtt_password":"","mqtt_qos":"0","tls":"","usetls":false,"base_topic":"zigbee2mqtt"}]
In function 16, you set lux high and lux low.
In function 13, you select whether the pier has a pulse or timeout.
Right now it is set to true, ie. sends a pulse every time there is movement.
Insert your own node.
