Trying to download UI table in csv format
Hi
I am trying to download the ui table in csv format
But am unable to do so, any help will be appreciated
        "id": "4239e513d67818ad",
        "type": "inject",
        "z": "a1fe963ffcba0f9a",
        "name": "Generate weld",
        "props": [
                "p": "weld",
                "v": "{\"p1\":null,\"p2\":null,\"p3\":null}",
                "vt": "json"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 260,
        "y": 800,
                "acb22296609c4bce",
                "abed8dae9bdbe212"
        "id": "abed8dae9bdbe212",
        "type": "function",
        "name": "Generate weld parameters",
        "func": "// Get the weld number\nlet weldNum = flow.get(\"weldNum\");\n\n// If init, then set it to 1\nif (weldNum === undefined) {\n    weldNum = 1\n    flow.set(\"weldNum\", 1);\n} else {\n// Otherwise increment each weld that is generated\n    weldNum += 1\n    flow.set(\"weldNum\", weldNum)\n}\n\n// Create a 'weld' with multiple parameters\nlet weld = msg.weld;\nlet numLength = 6;\n\nweld.num = weldNum;\nweld.p1 = (Math.random()).toFixed(numLength);\nweld.p2 = (Math.random() * .5).toFixed(numLength);\nweld.p3 = (Math.random() * 2).toFixed(numLength);\nweld.p4 = (Math.random() * 2).toFixed(numLength);\nweld.p5 = (Math.random() * 2).toFixed(numLength);\nweld.name = \"Weld \" + weld.num;\n\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 560,
        "y": 720,
                "1f43cbb06a104ac7",
                "e1663bd95aa089e9"
        "id": "1f43cbb06a104ac7",
        "type": "function",
        "name": "Keep persistent table of welds",
        "func": "let tableData = flow.get(\"tableData\") || [];\n\ntableData.unshift(msg.weld);\n\n\n\nmsg.tableData = tableData\n\nflow.set(\"tableData\", tableData)\nreturn msg;\n\n// // Wrapped Object (tableData) that's stored in msg\n// // Each Table has properties for each column in that part of the table to be dynamic\n// {\n//     // Left Table (fixed). Key = header name, Value = Array of values in tab\n//     \"left\": {\n//         \"num\": [1, 2, 3, 4, 5]\n//     },\n//     // Center Table (scrollable). Key = header name, Value = Array of values in tab\n//     \"center\": {\n//         \"p1\": [1.234, 1.892, 1.429, 1.952, 1.041],\n//             \"p2\": [2.587, 2.018, 2.593, 2.104, 2.501],\n//                 \"p3\": [3.014, 3.581, 3.590, 3.901, 3.291],\n//                     \"p4\": [4.104, 4.194, 4.981, 4.761, 4.385],\n//                         \"p5\": [5.012, 5.831, 5.123, 5.741, 5.689]\n//     },\n//     // Right Table (fixed). Key = header name, Value = Array of values in tab\n//     \"right\": {\n//         \"name\": [\"a\", \"b\", \"c\", \"d\", \"e\"]\n//     }\n// }",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 830,
        "y": 720,
                "55548ac5744b3d38",
                "302ddd18b58fcba7"
        "id": "55548ac5744b3d38",
        "type": "debug",
        "name": "TableData",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "tableData",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 1060,
        "y": 780,
        "id": "e1663bd95aa089e9",
        "type": "debug",
        "name": "Weld",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "weld",
        "statusVal": "",
        "x": 770,
        "y": 780,
        "id": "c6e3576e93b962d7",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 220,
        "y": 1080,
                "c8aa5e644299dc4e"
        "id": "c8aa5e644299dc4e",
        "type": "ui_template",
        "group": "8922194f09dd9a54",
        "name": "Home page",
        "order": 7,
        "width": "0",
        "height": "0",
        "format": "<style>\n\n.box {\n    width: 50vw;\n    height: 50vh;\n    border: \"black\";\n    border-style: solid;\n}\n\n.bg {\n    background-color: #e3e3e3;\n}\n    \n</style>\n\n<div class=\"box bg\">\n    <h1 class=\"bg\"> \n        The main page\n    </h1>\n</div>\n\n",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 370,
        "y": 1080,
        "id": "5f41d81469a3aea0",
        "type": "ui_etable",
        "payload": "[{\"formatter\":\"rowSelection\",\"titleFormatter\":\"rowSelection\",\"hozAlign\":\"center\",\"headerSort\":false,\"frozen\":true},{\"title\":\"Weld Num\",\"field\":\"num\",\"frozen\":true},{\"title\":\"Name\",\"field\":\"name\",\"align\":\"left\",\"editor\":\"input\",\"frozen\":true},{\"title\":\"P1\",\"field\":\"p1\"},{\"title\":\"P2\",\"field\":\"p2\"},{\"title\":\"P3\",\"field\":\"p3\"},{\"title\":\"P4\",\"field\":\"p4\"},{\"title\":\"P5\",\"field\":\"p5\"},{\"title\":\"Complete Weld\",\"field\":\"weldComplete\",\"width\":90,\"align\":\"center\",\"formatter\":\"tickCross\",\"sorter\":\"boolean\",\"editor\":true,\"frozen\":true},{\"title\":\"Visual Inspection\",\"field\":\"visInsp\",\"editor\":\"select\",\"editorParams\":{\"values\":[\"pass\",\"fail\"]},\"frozen\":true}]",
        "payloadType": "json",
        "options": "{\"movableColumns\":true,\"resizableColumns\":true,\"selectable\":5,\"responsiveLayout\":\"collapse\",\"autoResize\":true,\"layout\":\"fitColumns\",\"pagination\":\"local\",\"height\":\"70vh\"}",
        "group": "c31affb830f65b0a",
        "order": 4,
        "width": 0,
        "height": 0,
        "columns": [],
        "outputs": 1,
        "cts": false,
        "x": 1255,
        "y": 660,
                "425a2ec0c17ac8f8",
                "54564d05cf3f2d53",
                "89b67776c07e52bd"
        "l": false
        "id": "302ddd18b58fcba7",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "tableData",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1080,
        "y": 720,
                "5f41d81469a3aea0"
        "id": "425a2ec0c17ac8f8",
        "type": "function",
        "name": "Update table with Change",
        "func": "// If the callback from the table node doesn't indicate a edited cell. Don't continue\nif (msg.callback !== \"cellEdited\") {\n    return;\n}\n\n// Extract edited cell from payload\nlet editedCell = msg.payload;\nlet numEditedCell = editedCell.num;\n\n// Get the table data and swap out the old with the new\nlet tableData = flow.get(\"tableData\");\nlet originalCellIndex = tableData.findIndex(row => row.num === numEditedCell);\ntableData[originalCellIndex] = editedCell;\nflow.set(\"tableData\", tableData);\n\n// Set the payload to give back to the table node\nmsg.payload = tableData;\n\n\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1730,
        "y": 340,
        "id": "f9fee590e2be195d",
        "type": "ui_button",
        "order": 2,
        "width": 2,
        "height": 1,
        "passthru": false,
        "label": "Clear Table",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "true",
        "payloadType": "bool",
        "topic": "payload",
        "topicType": "msg",
        "x": 870,
        "y": 600,
                "9bd3eead4585dd2a"
        "id": "9bd3eead4585dd2a",
        "type": "function",
        "name": "Clear Table",
        "func": "// Resets all table related data\nflow.set(\"tableData\", []);\nflow.set(\"weldNum\", undefined);\nmsg.payload = [];\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1030,
        "y": 600,
                "5f41d81469a3aea0"
        "id": "acb22296609c4bce",
        "order": 1,
        "width": 3,
        "height": 1,
        "passthru": true,
        "label": "Generate weld",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "{\"p1\":null,\"p2\":null,\"p3\":null}",
        "topic": "weld",
        "topicType": "msg",
        "x": 300,
        "y": 740,
                "572d19d4c8a7dc98"
        "id": "572d19d4c8a7dc98",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "weld",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 310,
        "y": 680,
                "abed8dae9bdbe212"
        "id": "54564d05cf3f2d53",
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "x": 1800,
        "y": 400,
        "id": "1f084d4e29b09f7a",
        "type": "ui_ui_control",
        "events": "all",
        "x": 580,
        "y": 860,
        "id": "a31f4f0c8064271f",
        "type": "comment",
        "name": "Main page TEMP template",
        "info": "",
        "x": 250,
        "y": 1020,
        "id": "12c03fb8f3b36c73",
        "type": "comment",
        "name": "Data Collection Page - Undocumented",
        "info": "",
        "x": 290,
        "y": 540,
        "id": "89b67776c07e52bd",
        "type": "csv",
        "name": "welderstats.csv",
        "sep": ",",
        "hdrin": "",
        "hdrout": "none",
        "multi": "one",
        "ret": "\\n",
        "temp": "",
        "skip": "0",
        "strings": true,
        "include_empty_strings": "",
        "include_null_values": "",
        "x": 1380,
        "y": 860,
                "5151ca4c842e2cd9"
        "id": "b625ab77800c3e39",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 280,
        "y": 860,
                "abed8dae9bdbe212"
        "id": "5151ca4c842e2cd9",
        "type": "file",
        "name": "write to file",
        "filename": "C:\\NODE\\node_red_ui\\public\\downloads\\test.csv",
        "filenameType": "str",
        "appendNewline": true,
        "createDir": true,
        "overwriteFile": "false",
        "encoding": "utf8",
        "x": 1560,
        "y": 840,
                "f08fbf9e55c3b426"
        "id": "f08fbf9e55c3b426",
        "order": 1,
        "width": 3,
        "height": 1,
        "passthru": true,
        "label": "Download",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "{     \"payload\": {         \"command\": \"addData\",             \"arguments\": [                 {                     \"facility\": \"daemon\",                     \"facilityCode\": 3,                     \"severity\": \"info\",                     \"severityCode\": 6,                     \"tag\": \"systemd[1]\",                     \"timestamp\": \"2020-01-02T19:17:39.793Z\",                     \"hostname\": \"localhost\",                     \"address\": \"127.0.0.1\",                     \"family\": \"IPv4\",                     \"port\": 38514,                     \"size\": 80,                     \"msg\": \"some demo data\",                     \"id\": 2351                 },                 true             ],                 \"returnPromise\": true     } }",
        "topic": "payload",
        "topicType": "msg",
        "x": 1780,
        "y": 840,
        "id": "8922194f09dd9a54",
        "type": "ui_group",
        "name": "Main",
        "tab": "565c1bb57d8fd73a",
        "order": 1,
        "disp": false,
        "width": "22",
        "collapse": false,
        "className": ""
        "id": "c31affb830f65b0a",
        "type": "ui_group",
        "name": "Main Table",
        "tab": "2141872d82d783c8",
        "order": 1,
        "disp": true,
        "width": 22,
        "collapse": true,
        "className": ""
        "id": "565c1bb57d8fd73a",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "order": 3,
        "disabled": false,
        "hidden": false
        "id": "2141872d82d783c8",
        "type": "ui_tab",
        "name": "Data Collection",
        "order": 2,
        "disabled": false,
        "hidden": false
Which table node are you using? there are two of them.
Sorry updated it
        "type": "inject",
        "props": [
                "p": "weld",
                "vt": "json"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 260,
        "y": 800,
                "acb22296609c4bce",
                "abed8dae9bdbe212"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 560,
        "y": 720,
                "1f43cbb06a104ac7",
                "e1663bd95aa089e9"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 830,
        "y": 720,
                "55548ac5744b3d38",
                "302ddd18b58fcba7"
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1060,
        "y": 780,
        "type": "debug",
        "name": "Weld",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "weld",
        "statusVal": "",
        "x": 770,
        "y": 780,
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 220,
        "y": 1080,
                "c8aa5e644299dc4e"
        "order": 7,
        "width": "0",
        "height": "0",
        "className": "",
        "x": 370,
        "y": 1080,
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "tableData",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1080,
        "y": 720,
                "5f41d81469a3aea0"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1730,
        "y": 340,
        "order": 2,
        "width": 2,
        "height": 1,
        "passthru": false,
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "true",
        "topic": "payload",
        "topicType": "msg",
        "x": 870,
        "y": 600,
                "9bd3eead4585dd2a"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1030,
        "y": 600,
                "5f41d81469a3aea0"
        "order": 1,
        "width": 3,
        "height": 1,
        "passthru": true,
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "topic": "weld",
        "topicType": "msg",
        "x": 300,
        "y": 740,
                "572d19d4c8a7dc98"
        "type": "change",
        "rules": [
                "t": "set",
                "p": "weld",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 310,
        "y": 680,
                "abed8dae9bdbe212"
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 1800,
        "y": 400,
        "events": "all",
        "x": 580,
        "y": 860,
        "type": "comment",
        "info": "",
        "x": 250,
        "y": 1020,
        "type": "comment",
        "info": "",
        "x": 290,
        "y": 540,
        "type": "csv",
        "sep": ",",
        "hdrin": "",
        "hdrout": "none",
        "multi": "one",
        "ret": "\\n",
        "temp": "",
        "skip": "0",
        "strings": true,
        "x": 1380,
        "y": 860,
                "5151ca4c842e2cd9"
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 280,
        "y": 860,
                "abed8dae9bdbe212"
        "type": "file",
        "filename": "C:\\NODE\\node_red_ui\\public\\downloads\\welderstats.csv",
        "createDir": true,
        "encoding": "utf8",
        "x": 1560,
        "y": 840,
                "75bd0d773a0a8274"
        "order": 4,
        "width": 0,
        "height": 0,
        "columns": [],
        "outputs": 1,
        "cts": false,
        "x": 1255,
        "y": 660,
                "425a2ec0c17ac8f8",
                "54564d05cf3f2d53",
                "89b67776c07e52bd"
        "l": false
        "id": "75bd0d773a0a8274",
        "type": "downloadfile",
        "filename": "welderstats.csv",
        "encoding": "none",
        "x": 2030,
        "y": 840,
        "id": "500f83d2422b5af3",
        "order": 2,
        "width": 2,
        "height": 1,
        "passthru": true,
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "true",
        "topic": "payload",
        "topicType": "msg",
        "x": 1780,
        "y": 1000,
                "75bd0d773a0a8274"
        "type": "ui_group",
        "name": "Main",
        "order": 1,
        "disp": false,
        "width": "22",
        "collapse": false,
        "className": ""
        "type": "ui_group",
        "order": 1,
        "disp": true,
        "width": 22,
        "collapse": true,
        "className": ""
        "type": "ui_tab",
        "name": "Home",
        "order": 3,
        "disabled": false,
        "hidden": false
        "type": "ui_tab",
        "order": 2,
        "disabled": false,
        "hidden": false
what is the actual name of the node i.e. node-red-contrib.?????
node-red-contrib-ui-etable
Thread closed as user wanted to try a different approach - see
