Download uitable
How do I download this ui table in csv
I am using node-red ui table
Below is the flow, click inject timestamp to inject table data
        "id": "758b47d77078d14e",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "6c1e8c2ff814d53b",
        "type": "junction",
        "z": "758b47d77078d14e",
        "x": 1135.5078125,
        "y": 240.5234375,
        "id": "4bddba03ed588b14",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
        "id": "19bfae636033fa2a",
        "type": "ui_group",
        "name": "Default",
        "tab": "4bddba03ed588b14",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "e68fcfd07d233151",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 580,
        "y": 240,
                "f0d7239424d59422"
        "id": "f0d7239424d59422",
        "type": "function",
        "name": "function 1",
        "func": "msg.payload = [\n    {\n        \"Name\": \"Kazuhito Yokoi\",\n        \"Age\": \"35\",\n        \"Favourite Color\": \"red\",\n        \"Date Of Birth\": \"12/09/1983\"\n    },\n    {\n        \"Name\": \"Oli Bob\",\n        \"Age\": \"12\",\n        \"Favourite Color\": \"cyan\",\n        \"Date Of Birth\": \"12/08/2017\"\n    }\n];\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 740,
        "y": 240,
                "36237ab869efb9e9"
        "id": "36237ab869efb9e9",
        "type": "ui_table",
        "group": "19bfae636033fa2a",
        "name": "table",
        "order": 0,
        "width": "4",
        "height": "3",
        "columns": [],
        "outputs": 1,
        "cts": true,
        "x": 1180,
        "y": 240,
                "867f55192d7b8e1b"
        "id": "867f55192d7b8e1b",
        "type": "ui_button",
        "order": 14,
        "width": "4",
        "height": "1",
        "passthru": false,
        "label": "Download",
        "tooltip": "click to download",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "{\"command\":\"download\",\"arguments\":[\"csv\",\"table.csv\",{\"delimiter\":\";\"}],\"returnPromise\":false}",
        "payloadType": "json",
        "topic": "",
        "topicType": "str",
        "x": 1350,
        "y": 240,
Please don't open duplicate threads. This is the same as Trying to download UI table in csv format - #3 by tenziki
I will be closing this thread.
I've reopened this thread at @tenziki request and closed the older thread.
Try this, import this node
[{"id":"3174e50e97f2069c","type":"function","z":"758b47d77078d14e","name":"setup download","func":"msg.payload = {\n    \"command\": \"download\",\n    \"arguments\": [\n        \"csv\",\n        \"table.csv\",\n        {\n            \"delimiter\": \";\"\n        }\n    ],\n    \"returnPromise\": false\n}\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"_mcu":{"mcu":false},"x":140,"y":220,"wires":[["36237ab869efb9e9"]]}]
feed the output of the button node to this function node and then feed the output of the function node to the ui-table node. Deploy and test.
