I am new to NodeRed and I'm trying to setup a flow where the spoken text is directed to the Echo that triggered the NodeRed and external event. The Echo triggers a non NodeRed event which generates a MQTT message which triggers the flow. The flow I have will send the text to the previous Echo that triggered the flow. I tried adding a delay the MQTT flow with no effect.
[{"id":"b1b88fbe.49525","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"c728388a.d5faf8","type":"mqtt in","z":"b1b88fbe.49525","name":"","topic":"sensor/winecellar/bottletemp","qos":"2","datatype":"json","broker":"3a99576a.d87548","nl":false,"rap":true,"rh":0,"x":230,"y":220,"wires":[["dce659d8.6aebc8","44474013.99388"]]},{"id":"dce659d8.6aebc8","type":"debug","z":"b1b88fbe.49525","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":500,"y":220,"wires":[]},{"id":"339f331f.84896c","type":"function","z":"b1b88fbe.49525","name":"","func":"var i, j, k, l;\n\ni = Math.abs(msg.payload.BottleTemp - msg.payload.AirTemp).toFixed(2) + \" degrees\";\nif (msg.payload.BottleTemp > msg.payload.AirTemp) {\n j = i + \" cooler \";\n}\nelse if (msg.payload.BottleTemp < msg.payload.AirTemp) {\n j = i + \" warmer \";\n}\nelse {\n j = \"\";\n}\nif (msg.payload.Quiet == \"On\") {\n k = ' <amazon:effect name=\"whispered\">'\n l = ' </amazon:effect>'\n\n}\nelse {\n k = \"\"\n l = \"\"\n}\n\nmsg.payload = \"<speak>\\n\" +\n k +\n \" <s>The bottle temp is \" +\n msg.payload.BottleTemp.toFixed(1) + \" degrees fahrenheit</s>\\n\" +\n ' <break time=\"100ms\"/>\\n' +\n \" <s>the air temp is \" + msg.payload.AirTemp.toFixed(1) + \n \" degrees fahrenheit</s>\\n\" +\n j +\n l +\n \"</speak>\\n\" \n\n \n//msg.payload = \"The Bottle Temp is \" + msg.payload.BottleTemp.toFixed(1) + \" Degrees Farhenheit\" + \" The air temp is \" + k + \" degrees Farenheit \" + i + \" at \" + msg.payload.AirTemp.toFixed(1) + \" Degrees\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":360,"wires":[["b2cd17ab.280e78","e645d8a3.3d7c58"]]},{"id":"b2cd17ab.280e78","type":"debug","z":"b1b88fbe.49525","name":"function output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":600,"y":300,"wires":[]},{"id":"e645d8a3.3d7c58","type":"alexa-remote-routine","z":"b1b88fbe.49525","name":"","account":"9ef6e15e.eaf13","routineNode":{"type":"speak","payload":{"type":"ssml","text":{"type":"msg","value":"payload"},"devices":{"type":"flow","value":"echodevice"}}},"x":580,"y":400,"wires":[[]]},{"id":"d2a76609.2b38d8","type":"alexa-remote-event","z":"b1b88fbe.49525","name":"Listening to Alexa Events","account":"9ef6e15e.eaf13","event":"ws-device-activity","x":190,"y":560,"wires":[["95bace6b.fcd78","7b539097.11935"]]},{"id":"95bace6b.fcd78","type":"change","z":"b1b88fbe.49525","name":"Set Echo you're talking to","rules":[{"t":"set","p":"echodevice","pt":"flow","to":"payload.name","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":560,"wires":[[]]},{"id":"7b539097.11935","type":"debug","z":"b1b88fbe.49525","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":450,"y":640,"wires":[]},{"id":"44474013.99388","type":"delay","z":"b1b88fbe.49525","name":"","pauseType":"delay","timeout":"50","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":370,"y":280,"wires":[["339f331f.84896c"]]},{"id":"3a99576a.d87548","type":"mqtt-broker","name":"","broker":"192.168.1.6","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"9ef6e15e.eaf13","type":"alexa-remote-account","name":"","authMethod":"proxy","proxyOwnIp":"192.168.1.18","proxyPort":"3456","cookieFile":"/home/patrick/n-r-c-alexa-cakebaked.txt","refreshInterval":"3","alexaServiceHost":"pitangui.amazon.com","amazonPage":"amazon.com","acceptLanguage":"en-US","userAgent":"","useWsMqtt":"on","autoInit":"on"}]
