Trying to gather global vars into a single object once daily
Hi folks. I have a flow that is monitoring a series of IoT things and sending SMS alerts just fine.
I am trying to do something that seems simple enough. Create a daily SMS that gathers designated saved global variables.
I thought that generating a single json object using the Change Node would be pretty straight forward but I just can't get the syntax right.
When I try something like
"var1" : global.get(x),
it chokes on the 'g'.
When I use
"var1": "global.get(x)" or global.x
it literally prints the string "global.get..."
Any ideas on the best way to do this?
"var1": $globalContext("x"),
Should be corrext. Select JSONata in the dropdown .
