Trying to log data to Google sheets
I'll start saying I'm a Javascript novice which I think is the source of my troubles.
The method I'm trying to use is the HTTP request node that connects to a form created via google drive.
The basic idea is here: Sending Data of Wireless Vibration and Temperature to Google Sheets Using Node-RED : 37 Steps - Instructables
In my case, I'm joining 3 nodes to get the following node.
test2/test2/humidity : msg : Object
"topic":"test2/test2/humidity", //topic
"payload":
"test2/test2/temp_c":"24.90", //payload["test2/test2/temp_c"] 24.90
"test2/test2/temp_f":"76.82", //payload["test2/test2/temp_f"]
"test2/test2/humidity":"34.00" //payload["test2/test2/humidity"]
"qos":1,
"retain":false,
"_topic":"test2/test2/humidity",
"_msgid":"4393f367.357e2c"
What I am trying to understand is why inserting this into the forms URL didn't work:
...formResponse?usp=pp_url&entry.1464860579={{payload["test2/test2/temp_c"]}}... (snipped for brevity).
What I ended up having to do is to use a function node to copy the data from the object in the payload to 3 separate entries in the payload:
msg.payload.temp_c = msg.payload["test2/test2/temp_c"];
msg.payload.temp_f = msg.payload["test2/test2/temp_f"];
msg.payload.humidity = msg.payload["test2/test2/humidity"];
Then I could build the URL like so:
...formResponse?usp=pp_url&entry.1464860579={{payload.temp_c}}...
Then it all worked.
What I am trying to understand is if there is a way I can use payload["test2/test2/temp_c"] (and the other fields) directly and if so, what is the correct syntax?
I went this route and it's worked well - node-red-contrib-google-sheets (node) - Node-RED
Do you have any examples for using that node? That was one of the issues I was running into.
One that that isn't clear to me is what the input to the node needs to be, especially for the append row mode to work.
No problem. I first added a function node to create an Excel timestamp format:
var date1 = new Date();
var dateexcel = 25569.0 + ((date1.getTime() - (date1.getTimezoneOffset() * 60 * 1000)) / (1000 * 60 * 60 * 24));
msg.timestamp = new Date().toLocaleTimeString('en-US');
msg.datestamp = new Date().toLocaleDateString('en-US');
msg.dateexcel = dateexcel.toString().substr(0,20);
I then use a template node to create the input to the Google Sheet node:
Let me know if that helps, here's a screenshot of the flow (the subflow is just a single function node of the above so I can use it with multiple injects.
Thanks for the help!
The biggest hurdle is the lack of documentation on that node, but after some fiddling, it looks like it can handle a few different input types.
Is that template node there to create a CSV entry? If so, then I think I have all the work to make this happen.
One thing I'd like to know is if I can have the GSheet node skip the first row so I can make it a header.
For one flow, I have 2 temperature and humidity sensors as well as 2 temperature sensors I want to log side by side to compare and analyze. So having a heading row to keep all that straight will be important.
I set the node to append row, then it adds the data from the template node as a new row in the column order as submitted from the template.
I have the GSheet node working but only if msg.payload is an array.
Is your template node producing a parsed JSON array or is the output plain text?
In my case, I have 4 separate topics I'm joining then trying to log that. Because the timing of the topics is variable, the order in the join operation is not guaranteed. I ended up having to write a function that transforms the payload from a JSON object to an array in a specific order.
But the good news is that it works now and I'm sharing what I've done so hopefully it can help someone else trying to use the node-red-contrib-google-sheets node.
Here is my sample flow I used for debugging (gsheets node has not been configured to hide credentials):
[{"id":"abc60c3f.532ff","type":"tab","label":"sample_solution","disabled":false,"info":""},{"id":"23108ab0.cc5a86","type":"debug","z":"abc60c3f.532ff","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1210,"y":240,"wires":[]},{"id":"4bc3a186.df034","type":"moment","z":"abc60c3f.532ff","name":"","topic":"","input":"","inputType":"date","inTz":"ETC/UTC","adjAmount":"0","adjType":"hours","adjDir":"subtract","format":"dd:HH:mm:ss","locale":"en-US","output":"payload","outputType":"msg","outTz":"US/Pacific","x":340,"y":160,"wires":[["b22f4ff3.c4a2f"]]},{"id":"f12ea934.0a3e18","type":"join","z":"abc60c3f.532ff","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"4","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":670,"y":60,"wires":[["e4b57bd8.5c7f18","1f5095d3.bbb29a"]]},{"id":"babaaa00.f54548","type":"debug","z":"abc60c3f.532ff","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1070,"y":40,"wires":[]},{"id":"b22f4ff3.c4a2f","type":"change","z":"abc60c3f.532ff","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"test2/timestamp","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":530,"y":160,"wires":[["f12ea934.0a3e18"]]},{"id":"e4b57bd8.5c7f18","type":"debug","z":"abc60c3f.532ff","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":790,"y":180,"wires":[]},{"id":"1f5095d3.bbb29a","type":"function","z":"abc60c3f.532ff","name":"","func":"//var payload = {};\n//msg.payload.temp_c = msg.payload[\"test2/test2/temp_c\"];\n//msg.payload.temp_f = msg.payload[\"test2/test2/temp_f\"];\n//msg.payload.humidity = msg.payload[\"test2/test2/humidity\"];\n//payload.timestamp = msg.payload[\"test2/timestamp\"]\n//payload.temp_c = msg.payload[\"test2/test2/temp_c\"];\n//payload.temp_f = msg.payload[\"test2/test2/temp_f\"];\n//payload.humidity = msg.payload[\"test2/test2/humidity\"];\n//msg.payload = payload;\n\nvar data_array = [msg.payload[\"test2/timestamp\"],\nmsg.payload[\"test2/test2/temp_c\"],\nmsg.payload[\"test2/test2/temp_f\"],\nmsg.payload[\"test2/test2/humidity\"]];\nmsg.payload = data_array\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":880,"y":40,"wires":[["babaaa00.f54548","b8800c06.3a846"]]},{"id":"828ff31f.2c596","type":"inject","z":"abc60c3f.532ff","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"test2/test2/temp_c","payload":"0","payloadType":"str","x":90,"y":20,"wires":[["f12ea934.0a3e18"]]},{"id":"5e7e2387.e398dc","type":"inject","z":"abc60c3f.532ff","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"test2/test2/temp_f","payload":"32","payloadType":"str","x":100,"y":60,"wires":[["f12ea934.0a3e18"]]},{"id":"dfb13806.a15ca8","type":"inject","z":"abc60c3f.532ff","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"test2/test2/humidity","payload":"25","payloadType":"str","x":100,"y":100,"wires":[["f12ea934.0a3e18","4bc3a186.df034"]]},{"id":"b8800c06.3a846","type":"GSheet","z":"abc60c3f.532ff","creds":"","method":"append","action":"","sheet":"","cells":"","flatten":false,"name":"","x":1080,"y":120,"wires":[["23108ab0.cc5a86"]]}]
Parsed Json. The '[ ]' in the mustache template produces the array for sending to the node (if I'm remembering correctly).
You could use a Join node using msg.parts to specify the order of the join - Join Sequence Recipe (flow) - Node-RED
