Hi All,
I'm looking to fill the area between the line and the x-axis ... unlucky so far with the msg.ui_control.
Here is what I've tried with a change node:
What am I missing ?
Works fine for me
What is the version of the dashboard you are using?
Ah!
Thanks for pointing the dashboard version, that was the issue... (did not check as it was a fresh install ...)
I updated dashboard up to version 2.19.3, issue is solved.
