Type Error when starting Node-RED
Hello, i have encounter this during starting up my node-red
12 Jun 15:21:20 - [info] Starting flows
TypeError: Cannot read property 'id' of undefined
at remapSubflowNodes (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/Subflow.js:412:64)
at new Subflow (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/Subflow.js:85:9)
at Object.createSubflow [as create] (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/Subflow.js:435:12)
at Flow.start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/Flow.js:187:51)
at start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/index.js:329:33)
at tryCatchReject (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:845:30)
at runContinuation1 (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:804:4)
at Fulfilled.when (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:592:4)
at Pending.run (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:483:13)
at Scheduler._drain (/usr/lib/node_modules/node-red/node_modules/when/lib/Scheduler.js:62:19)
Ever since this error happened i can't create any Context variable. Any insight that might help?
Best Regards
Tell us what hardware and operating system you are using and post the complete startup log, starting with the welcome to node red message.
Also what did you change that started the problem?
this is the welcome to the node-red message
Welcome to Node-RED
13 Jun 09:49:51 - [info] Node-RED version: v0.20.5
13 Jun 09:49:51 - [info] Node.js version: v10.15.3
13 Jun 09:49:51 - [info] Linux 4.15.0-48-generic x64 LE
13 Jun 09:49:52 - [info] Loading palette nodes
13 Jun 09:49:53 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
13 Jun 09:49:53 - [warn] rpi-gpio : Cannot find Pi RPi.GPIO python library
13 Jun 09:49:53 - [info] Settings file : /home/ubuntu/.node-red/settings.js
13 Jun 09:49:53 - [info] Context store : 'default' [module=memory]
13 Jun 09:49:53 - [info] User directory : /home/ubuntu/.node-red
13 Jun 09:49:53 - [warn] Projects disabled : editorTheme.projects.enabled=false
13 Jun 09:49:53 - [info] Flows file : /home/ubuntu/.node-red/flows_ubuntu23.json
13 Jun 09:49:53 - [info] Server now running at http://127.0.0.1:1880/
13 Jun 09:49:54 - [warn]
your credentials.
13 Jun 09:49:54 - [info] Starting flows
13 Jun 09:49:55 - [info] Started flows
13 Jun 09:49:55 - [info] [mqtt-broker:8bd04cb3.99d51] Connected to broker: mqtt://10.23.14.19:1883
13 Jun 09:56:52 - [error] [function:Material] TypeError: this.subflowInstanceNodes[sfId].getNode is not a function
That error shows up now everytime i want to create a context/flow/global variable.
As what did I change? Nothing. THAT's what confused me. It's running just fine until yesterday.
I was just checking my program because it's been one week running. This is the program:
[{"id":"338389b4.ee7de6","type":"subflow","name":"I/O Data","info":"","category":"EWS","in":[{"x":60,"y":240,"wires":[{"id":"f80327cb.61ae68"}]}],"out":[{"x":440,"y":60,"wires":[{"id":"edaaf21.b59571","port":0}]},{"x":1300,"y":80,"wires":[{"id":"c8165c6d.03c58","port":0}]},{"x":1300,"y":120,"wires":[{"id":"3093c42c.dcfffc","port":0}]},{"x":1160,"y":180,"wires":[{"id":"10f08c43.368dc4","port":0}]},{"x":1280,"y":240,"wires":[{"id":"4150f35b.b0d5fc","port":0},{"id":"4fbdf7d6.a53d88","port":0},{"id":"5369cbc1.55fdd4","port":0},{"id":"f1da942f.fb70c8","port":0}]}],"env":[]},{"id":"e2dd5a4e.4e6598","type":"function","z":"338389b4.ee7de6","name":"Increment","func":"var data = msg.payload;\nvar status = data.status;\n\nif (status==\"R\"){\n    msg.increment = 1;\n}\nelse if (status==\"F\"){\n    msg.reset=true;\n}\nreturn msg;","outputs":1,"noerr":0,"x":600,"y":140,"wires":[["767cd536.23e32c"]]},{"id":"767cd536.23e32c","type":"counter","z":"338389b4.ee7de6","name":"","init":"0","step":"1","lower":"-1","upper":null,"mode":"increment","outputs":"1","x":760,"y":140,"wires":[["3949835c.97434c","e0ac9e5d.79665"]]},{"id":"3949835c.97434c","type":"delay","z":"338389b4.ee7de6","name":"d01","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":750,"y":80,"wires":[["767cd536.23e32c"]]},{"id":"7f693540.e1b87c","type":"function","z":"338389b4.ee7de6","name":"Timer","func":"var mesin = msg.payload.mesin;\nvar ws = msg.payload.kodews;\nvar status = msg.payload.status;\n\nvar set_status = flow.set(\"status_\"+ws+\"_\"+mesin,status);\nif (status==\"W\"){\n    msg.payload=0;\n}\nelse {\n    msg.payload=msg.payload;\n}\nreturn msg;","outputs":1,"noerr":0,"x":350,"y":140,"wires":[["82c09237.f0847"]]},{"id":"82c09237.f0847","type":"switch","z":"338389b4.ee7de6","name":"","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":470,"y":140,"wires":[["e2dd5a4e.4e6598"],[]]},{"id":"f80327cb.61ae68","type":"switch","z":"338389b4.ee7de6","name":"","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":190,"y":240,"wires":[["fc1efc3d.b820b","525b02c5.b19b1c","7f693540.e1b87c","edaaf21.b59571"],[]]},{"id":"10f08c43.368dc4","type":"function","z":"338389b4.ee7de6","name":"InfluxDB","func":"var mesin = msg.payload.mesin;\nvar ws = msg.payload.kodews;\nvar breakdown = msg.payload.breakdown;\nvar report = msg.report;\nvar work = msg.work;\n\nif ((report>0)&&(work===0)){\n    msg.measurement = mesin;\n    msg.payload=[{\n        status:1,\n        als_stop:breakdown,\n        report:report,\n        durasi:work\n    },\n    {\n        kd_status:ws\n    }]\n}\nelse if ((report>0)&&(work>0)){\n    msg.measurement = mesin;\n    msg.payload=[{\n        status:2,\n        als_stop:breakdown,\n        report:report,\n        durasi:work\n    },\n    {\n        kd_status:ws\n    }]\n}\nelse{\n    msg.measurement = mesin;\n    msg.payload=[{\n        status:3,\n        als_stop:0,\n        report:0,\n        durasi:0\n    },\n    {\n        kd_status:ws\n    }]\n}\nreturn msg;","outputs":1,"noerr":0,"x":1060,"y":180,"wires":[[]]},{"id":"c8165c6d.03c58","type":"function","z":"338389b4.ee7de6","name":"Report","func":"var report = msg.report;\nvar mesin = (msg.payload.mesin).toLowerCase();\nvar ws = (msg.payload.kodews).toLowerCase();\n\nmsg.topic = ws+\"/\"+mesin+\"_report\";\nmsg.payload = report;\n\nreturn msg;","outputs":1,"noerr":0,"x":1210,"y":80,"wires":[[]]},{"id":"3093c42c.dcfffc","type":"function","z":"338389b4.ee7de6","name":"Work","func":"var work = msg.work;\nvar mesin = (msg.payload.mesin).toLowerCase();\nvar ws = (msg.payload.kodews).toLowerCase();\n\nmsg.topic = ws+\"/\"+mesin+\"_work\";\nmsg.payload = work;\n\nreturn msg;","outputs":1,"noerr":0,"x":1210,"y":120,"wires":[[]]},{"id":"e0ac9e5d.79665","type":"function","z":"338389b4.ee7de6","name":"Timer","func":"var mesin = msg.payload.mesin;\nvar ws = msg.payload.kodews;\nvar status =  flow.get(\"status_\"+ws+\"_\"+mesin);\n\nif (status==\"R\"){\n    var timer1 = flow.set(\"report_\"+ws+\"_\"+mesin,msg.count);\n    msg.report = msg.count;\n    msg.work = 0;\n}\nelse if (status==\"W\"){\n    var timer2 = flow.get(\"report_\"+ws+\"_\"+mesin);\n    msg.report = timer2;\n    msg.work = msg.count - timer2;\n}\nelse {\n    msg.report = 0;\n    msg.work = 0;\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":910,"y":140,"wires":[["cc328886.692dc8","10f08c43.368dc4"]]},{"id":"cc328886.692dc8","type":"function","z":"338389b4.ee7de6","name":"Show Timer","func":"var r_second = String(Math.floor(msg.report%60)).padStart(2,\"0\");\nvar r_minute = String(Math.floor((msg.report/60)%60)).padStart(2,\"0\");\nvar r_hour = String(Math.floor(msg.report/(60*60))).padStart(2,\"0\");\nmsg.report = r_hour+\":\"+r_minute+\":\"+r_second;\n    \nvar w_second = String(Math.floor(msg.work%60)).padStart(2,\"0\");\nvar w_minute = String(Math.floor((msg.work/60)%60)).padStart(2,\"0\");\nvar w_hour = String(Math.floor(msg.work/(60*60))).padStart(2,\"0\");\nmsg.work = w_hour+\":\"+w_minute+\":\"+w_second;\n\nreturn msg;","outputs":1,"noerr":0,"x":1070,"y":100,"wires":[["c8165c6d.03c58","3093c42c.dcfffc"]]},{"id":"f1da942f.fb70c8","type":"delay","z":"338389b4.ee7de6","name":"d02","pauseType":"delay","timeout":"100","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1150,"y":440,"wires":[[]]},{"id":"dbf723f1.a044f","type":"interval-length","z":"338389b4.ee7de6","format":"mills","bytopic":false,"minimum":"","maximum":"","window":"","timeout":false,"msgTimeout":"","minimumunit":"msecs","maximumunit":"msecs","windowunit":"msecs","msgTimeoutUnit":"msecs","reset":true,"startup":false,"msgField":"timer","timestampField":"timestamp","repeatTimeout":false,"name":"interval","x":760,"y":280,"wires":[["4fbdf7d6.a53d88"],[]]},{"id":"6311c293.15af0c","type":"change","z":"338389b4.ee7de6","name":"reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":260,"wires":[["dbf723f1.a044f"]]},{"id":"3782f91f.910526","type":"interval-length","z":"338389b4.ee7de6","format":"mills","bytopic":false,"minimum":"","maximum":"","window":"","timeout":false,"msgTimeout":"","minimumunit":"msecs","maximumunit":"msecs","windowunit":"msecs","msgTimeoutUnit":"msecs","reset":true,"startup":false,"msgField":"timer","timestampField":"timestamp","repeatTimeout":false,"name":"interval","x":760,"y":360,"wires":[["5369cbc1.55fdd4"],[]]},{"id":"75818a8.8ebab74","type":"change","z":"338389b4.ee7de6","name":"reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":340,"wires":[["3782f91f.910526"]]},{"id":"525b02c5.b19b1c","type":"function","z":"338389b4.ee7de6","name":"MySQL","func":"var data = msg.payload;\nvar kd_stp = msg.payload.status;\n\nif (kd_stp==\"R\"){\n    var msg01={payload:data};\n}\nelse if (kd_stp==\"W\"){\n    var msg02={payload:data};\n}\nelse if (kd_stp==\"F\"){\n    var msg03={payload:data};\n}\nreturn [msg01,msg02,msg03];","outputs":3,"noerr":0,"x":360,"y":340,"wires":[["ce299f36.8735e"],["564a78c7.bed468"],["f6872beb.0a5138"]]},{"id":"ce299f36.8735e","type":"link out","z":"338389b4.ee7de6","name":"t01","links":["e066d881.775108","4d2cee26.b4ef2","a38c52a7.c1e5a","9feb21bd.9ffef"],"x":475,"y":300,"wires":[]},{"id":"564a78c7.bed468","type":"link out","z":"338389b4.ee7de6","name":"t02","links":["66d2d37d.3024ec","e066d881.775108","9feb21bd.9ffef"],"x":475,"y":340,"wires":[]},{"id":"f6872beb.0a5138","type":"link out","z":"338389b4.ee7de6","name":"t03","links":["38ff1c5d.04c9d4","66d2d37d.3024ec","2a9c3990.882976","a38c52a7.c1e5a","c75615f8.b8ba18"],"x":475,"y":380,"wires":[]},{"id":"e066d881.775108","type":"link in","z":"338389b4.ee7de6","name":"t01","links":["ce299f36.8735e","564a78c7.bed468"],"x":655,"y":300,"wires":[["dbf723f1.a044f"]]},{"id":"38ff1c5d.04c9d4","type":"link in","z":"338389b4.ee7de6","name":"t03","links":["f6872beb.0a5138"],"x":535,"y":260,"wires":[["6311c293.15af0c"]]},{"id":"66d2d37d.3024ec","type":"link in","z":"338389b4.ee7de6","name":"t02","links":["564a78c7.bed468","f6872beb.0a5138"],"x":655,"y":380,"wires":[["3782f91f.910526"]]},{"id":"4d2cee26.b4ef2","type":"link in","z":"338389b4.ee7de6","name":"t01","links":["ce299f36.8735e"],"x":535,"y":340,"wires":[["75818a8.8ebab74"]]},{"id":"bef7ed2a.54934","type":"interval-length","z":"338389b4.ee7de6","format":"mills","bytopic":false,"minimum":"","maximum":"","window":"","timeout":false,"msgTimeout":"","minimumunit":"msecs","maximumunit":"msecs","windowunit":"msecs","msgTimeoutUnit":"msecs","reset":true,"startup":false,"msgField":"timer","timestampField":"timestamp","repeatTimeout":false,"name":"interval","x":880,"y":440,"wires":[["39f52fe7.413db"],[]]},{"id":"4ec97f7a.d541e","type":"change","z":"338389b4.ee7de6","name":"reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":420,"wires":[["bef7ed2a.54934"]]},{"id":"a38c52a7.c1e5a","type":"link in","z":"338389b4.ee7de6","name":"t01","links":["ce299f36.8735e","f6872beb.0a5138"],"x":775,"y":460,"wires":[["bef7ed2a.54934"]]},{"id":"2a9c3990.882976","type":"link in","z":"338389b4.ee7de6","name":"t03","links":["f6872beb.0a5138"],"x":535,"y":420,"wires":[["99a11821.c8cdf8"]]},{"id":"99a11821.c8cdf8","type":"delay","z":"338389b4.ee7de6","name":"d03","pauseType":"delay","timeout":"250","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":630,"y":420,"wires":[["4ec97f7a.d541e"]]},{"id":"5369cbc1.55fdd4","type":"function","z":"338389b4.ee7de6","name":"MySQL","func":"var key = msg.payload.key;\n\nvar date = String(new Date(msg.timestamp).getDate()).padStart(2,\"0\");\nvar month = String(new Date(msg.timestamp).getMonth()+1).padStart(2,\"0\");\nvar year = String(new Date(msg.timestamp).getFullYear());\nvar hour = String(new Date(msg.timestamp).getHours()).padStart(2,\"0\");\nvar minute = String(new Date(msg.timestamp).getMinutes()).padStart(2,\"0\");\nvar second = String(new Date(msg.timestamp).getSeconds()).padStart(2,\"0\");\nvar w_timestamp = year+\"-\"+month+\"-\"+date+\" \"+hour+\":\"+minute+\":\"+second;\n\nvar timer = msg.timer;\nvar w_second = String(Math.floor((timer/1000)%60)).padStart(2,\"0\");\nvar w_minute = String(Math.floor((timer/(1000*60))%60)).padStart(2,\"0\");\nvar w_hour = String(Math.floor(timer/(1000*60*60))).padStart(2,\"0\");\nvar w_timer = w_hour+\":\"+w_minute+\":\"+w_second;\n\nmsg.topic = \"UPDATE report_v0 SET ymd_work ='\"+w_timestamp+\"', time_work = '\"+w_timer+\"' WHERE day_id = '\"+key+\"'\";\n\nreturn msg;","outputs":1,"noerr":0,"x":900,"y":360,"wires":[[]]},{"id":"39f52fe7.413db","type":"function","z":"338389b4.ee7de6","name":"MySQL","func":"var key = msg.payload.key;\n\nvar date = String(new Date().getDate()).padStart(2,\"0\");\nvar month = String(new Date().getMonth()+1).padStart(2,\"0\");\nvar year = String(new Date().getFullYear());\nvar hour = String(new Date().getHours()).padStart(2,\"0\");\nvar minute = String(new Date().getMinutes()).padStart(2,\"0\");\nvar second = String(new Date().getSeconds()).padStart(2,\"0\");\nvar f_timestamp = year+\"-\"+month+\"-\"+date+\" \"+hour+\":\"+minute+\":\"+second;\n\nvar timer = msg.timer;\nvar f_second = String(Math.floor((timer/1000)%60)).padStart(2,\"0\");\nvar f_minute = String(Math.floor((timer/(1000*60))%60)).padStart(2,\"0\");\nvar f_hour = String(Math.floor((timer/(1000*60*60))%24)).padStart(2,\"0\");\nvar f_timer = f_hour+\":\"+f_minute+\":\"+f_second;\n\nmsg.topic = \"UPDATE report_v0 SET ymd_finish ='\"+f_timestamp+\"', time_finish = '\"+f_timer+\"' WHERE day_id = '\"+key+\"'\";\n\nreturn msg;","outputs":1,"noerr":0,"x":1020,"y":440,"wires":[["f1da942f.fb70c8"]]},{"id":"4fbdf7d6.a53d88","type":"function","z":"338389b4.ee7de6","name":"MySQL","func":"var key = msg.payload.key;\n\nvar date = String(new Date(msg.timestamp).getDate()).padStart(2,\"0\");\nvar month = String(new Date(msg.timestamp).getMonth()+1).padStart(2,\"0\");\nvar year = String(new Date(msg.timestamp).getFullYear());\nvar hour = String(new Date(msg.timestamp).getHours()).padStart(2,\"0\");\nvar minute = String(new Date(msg.timestamp).getMinutes()).padStart(2,\"0\");\nvar second = String(new Date(msg.timestamp).getSeconds()).padStart(2,\"0\");\nvar r_timestamp = year+\"-\"+month+\"-\"+date+\" \"+hour+\":\"+minute+\":\"+second;\n\nvar timer = msg.timer;\nvar r_second = String(Math.floor((timer/1000)%60)).padStart(2,\"0\");\nvar r_minute = String(Math.floor((timer/(1000*60))%60)).padStart(2,\"0\");\nvar r_hour = String(Math.floor(timer/(1000*60*60))).padStart(2,\"0\");\nvar r_timer = r_hour+\":\"+r_minute+\":\"+r_second;\n\nmsg.topic = \"UPDATE report_v0 SET ymd_report ='\"+r_timestamp+\"', time_report = '\"+r_timer+\"' WHERE day_id = '\"+key+\"'\";\n\nreturn msg;","outputs":1,"noerr":0,"x":900,"y":280,"wires":[[]]},{"id":"4150f35b.b0d5fc","type":"function","z":"338389b4.ee7de6","name":"Primary Key","func":"var mesin = msg.payload.mesin;\nvar breakdown = msg.payload.breakdown;\nvar flw = msg.payload.flow;\nvar key = msg.payload.key;\n\nmsg.topic = \"INSERT INTO report_v0 (day_id,mcn_id,stop_id,flow_id) VALUES ('\"+key+\"','\"+mesin+\"-\"+flw+\"','\"+breakdown+\"','\"+flw+\"');\"\nreturn msg;","outputs":1,"noerr":0,"x":490,"y":200,"wires":[[]]},{"id":"fc1efc3d.b820b","type":"switch","z":"338389b4.ee7de6","name":"","property":"payload.status","propertyType":"msg","rules":[{"t":"eq","v":"R","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":200,"wires":[["4150f35b.b0d5fc"],[]]},{"id":"a7488ed5.fcf97","type":"function","z":"338389b4.ee7de6","name":"Reset Variable","func":"var mesin = msg.payload.mesin;\nvar ws = msg.payload.kodews;\nvar status =  flow.set(\"status_\"+ws+\"_\"+mesin,undefined);\nvar report = flow.set(\"report_\"+ws+\"_\"+mesin,undefined);\n\nreturn msg;","outputs":1,"noerr":0,"x":660,"y":520,"wires":[[]]},{"id":"c75615f8.b8ba18","type":"link in","z":"338389b4.ee7de6","name":"t04","links":["f6872beb.0a5138"],"x":535,"y":520,"wires":[["a7488ed5.fcf97"]]},{"id":"edaaf21.b59571","type":"function","z":"338389b4.ee7de6","name":"Buzzer","func":"var mesin = (msg.payload.mesin).toLowerCase();\nvar ws = (msg.payload.kodews).toLowerCase();\nvar breakdown = msg.payload.breakdown;\nvar status = msg.payload.status;\n\nif (status==\"R\"){\n    if (breakdown==61){\n        msg.topic = \"bb/buzzer_\"+mesin;\n        msg.payload = 1;\n    }\n    else{\n        msg.topic = ws+\"/buzzer_\"+mesin;\n        msg.payload = 1;\n    }\n}\nelse if (status==\"W\"){\n    if (breakdown==61){\n        msg.topic = \"bb/buzzer_\"+mesin;\n        msg.payload = 2;\n    }\n    else{\n        msg.topic = ws+\"/buzzer_\"+mesin;\n        msg.payload = 2;\n    }\n}\nelse if (status==\"F\"){\n    if (breakdown==61){\n        msg.topic = \"bb/buzzer_\"+mesin;\n        msg.payload = 3;\n    }\n    else{\n        msg.topic = ws+\"/buzzer_\"+mesin;\n        msg.payload = 3;\n    }\n}\nreturn msg;","outputs":1,"noerr":0,"x":350,"y":60,"wires":[[]]},{"id":"3559585a.5ecd78","type":"inject","z":"89d730c1.41912","name":"","topic":"","payload":"R","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":100,"wires":[["ce956f94.1ec08"]]},{"id":"ce956f94.1ec08","type":"function","z":"89d730c1.41912","name":"","func":"var data = msg.payload;\n\nmsg.payload={\n    mesin:\"BF12412\",\n    status:data,\n    kodews:\"MA\",\n    kodearea:\"BF2\",\n    breakdown:\"61\",\n    plant:\"GM1\"\n};\nreturn msg;","outputs":1,"noerr":0,"x":230,"y":140,"wires":[["3a92d983.829456"]]},{"id":"3a92d983.829456","type":"function","z":"89d730c1.41912","name":"BF12412","func":"var mesin = msg.payload.mesin;\nvar status = msg.payload.status;\nvar breakdown = Number(msg.payload.breakdown);\nvar ws = msg.payload.kodews;\n\nif (mesin==\"BF12412\"){\n    msg.payload={\n        mesin:mesin,\n        status:status,\n        kodews:ws,\n        flow:\"F\",\n        breakdown:breakdown\n    };\n}\nelse {\n    msg.payload=0;\n}\nreturn msg;","outputs":1,"noerr":0,"x":360,"y":140,"wires":[["e6419cee.5f9b4"]]},{"id":"e6419cee.5f9b4","type":"switch","z":"89d730c1.41912","name":"Check Mesin","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":510,"y":140,"wires":[["fd5b6123.f5323"],[]]},{"id":"e29523fc.bee0c","type":"inject","z":"89d730c1.41912","name":"","topic":"","payload":"W","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":140,"wires":[["ce956f94.1ec08"]]},{"id":"486df0a1.b13bb","type":"inject","z":"89d730c1.41912","name":"","topic":"","payload":"F","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":90,"y":180,"wires":[["ce956f94.1ec08"]]},{"id":"fd5b6123.f5323","type":"function","z":"89d730c1.41912","name":"Material","func":"var status = msg.payload.status;\nvar mesin = msg.payload.mesin;\nvar ws = msg.payload.kodews;\nvar breakdown = msg.payload.breakdown;\nvar flw = msg.payload.flow;\nvar cek = flow.get(\"last_key_\"+ws+\"_\"+mesin);\n\nif ((breakdown>60)&&(breakdown<70)){\n    if (status==\"R\"){\n        if (cek===undefined){\n            var year = new Date().getFullYear();\n            var date = String(new Date().getDate()).padStart(2,\"0\");\n            var month = String(new Date().getMonth()+1).padStart(2,\"0\");\n            var hour = String(new Date().getHours()).padStart(2,\"0\");\n            var minute = String(new Date().getMinutes()).padStart(2,\"0\");\n            var second = String(new Date().getSeconds()).padStart(2,\"0\");\n\n            msg.payload.key = year+month+date+\"-\"+hour+minute+second+\"-\"+mesin+\"-\"+flw;\n            var key = flow.set(\"last_key_\"+ws+\"_\"+mesin,year+month+date+\"-\"+hour+minute+second+\"-\"+mesin+\"-\"+flw);\n            msg.payload = msg.payload;\n        }\n        else {\n            msg.payload = 0;\n        }\n    }\n    else if (status==\"W\"){\n        if (cek!==undefined){\n            msg.payload.key = flow.get(\"last_key_\"+ws+\"_\"+mesin);\n            msg.payload=msg.payload;\n        }\n        else {\n            msg.payload=0;\n        }\n    }\n    else if (status==\"F\"){\n        if (cek!==undefined){\n            msg.payload.key = flow.get(\"last_key_\"+ws+\"_\"+mesin);\n            msg.payload=msg.payload;\n            var timeout = setTimeout(function(){\n                msg.payload = flow.set(\"last_key_\"+ws+\"_\"+mesin,undefined);\n            },1000)\n        }\n        else {\n            msg.payload=0;\n        }\n    }\n}\nelse{\n    msg.payload=0;\n}\nreturn msg;","outputs":1,"noerr":0,"x":660,"y":140,"wires":[["4c21dad5.7bbd04"]]},{"id":"4c21dad5.7bbd04","type":"subflow:338389b4.ee7de6","z":"89d730c1.41912","name":"","env":[],"x":800,"y":140,"wires":[["c9f1620f.3eab3"],["524d475.70352b8"],["f6ef04cc.bc5028"],["72f1220f.35076c"],["a85a72e1.645eb"]]},{"id":"c9f1620f.3eab3","type":"debug","z":"89d730c1.41912","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":970,"y":60,"wires":[]},{"id":"f6ef04cc.bc5028","type":"debug","z":"89d730c1.41912","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":970,"y":140,"wires":[]},{"id":"524d475.70352b8","type":"debug","z":"89d730c1.41912","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":970,"y":100,"wires":[]},{"id":"a85a72e1.645eb","type":"debug","z":"89d730c1.41912","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":970,"y":220,"wires":[]},{"id":"72f1220f.35076c","type":"debug","z":"89d730c1.41912","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":970,"y":180,"wires":[]}]
Hi - the problem is you have two link nodes inside the subflow that are trying to link to nodes outside of the subflow. Whilst we do not allow links to go in/out of subflows, there is a bug where we don't handle it properly when a flow configuration tries to do it.
To fix it, open the edit dialog for these two nodes - the editor will automatically tidy up the invalid links just by opening the dialog. Then deploy.
Local_Node-RED
I have raised https://github.com/node-red/node-red/issues/2202 for us to address the underlying issue.
