TypeError: ctx.keys is not a function at exportContextStore
I reinstalled node-red in my system by removing all node-modules in user folder. I updated to latest version.
I am running node-red on pm2.
After successful instillation I am getting this error:
at exportContextStore (C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\red\api\admin\context.js:23:9)
at C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\red\api\admin\context.js:106:21
at Array.forEach ()
at get (C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\red\api\admin\context.js:105:24)
at Layer.handle [as handle_request] (C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\layer.js:95:5)
at next (C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\route.js:137:13)
at C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\red\api\auth\index.js:57:28
at complete (C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\node_modules\passport\lib\middleware\authenticate.js:263:13)
at C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\node_modules\passport\lib\middleware\authenticate.js:270:15
at pass (C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\node_modules\passport\lib\authenticator.js:431:14)
What is the reason for this error? How to resolve this error?
With regards,
Nithin B.
Hi @nithinbandaru1 - that's unexpected. I can't immediately explain why you'd hit that.
Have you enabled the persistent context feature in 0.19? If so, how have you got it configured?
What version of node.js are you using?
Hi @knolleary Thanks for replying.
I have no idea what this is. So I think I didn't enable it.
Node.js version I am using: v8.11.4
More Info:
The error is thrown on flow tab click only(have multiple flows).
Only changes I made in settings file are:
  1. Changed flow path.
  2. Enabled admin privileges.
  3. Enabled projects.
  4. Check the results I get when I start node-red form cmd.
7 Sep 18:08:40 - [info]
Welcome to Node-RED
7 Sep 18:08:40 - [info] Node-RED version: v0.19.3
7 Sep 18:08:40 - [info] Node.js version: v8.11.4
7 Sep 18:08:40 - [info] Windows_NT 10.0.17134 x64 LE
7 Sep 18:08:41 - [info] Loading palette nodes
7 Sep 18:08:42 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
7 Sep 18:08:42 - [info] Dashboard version 2.9.8 started at /ui
7 Sep 18:08:42 - [warn] ------------------------------------------------------
7 Sep 18:08:42 - [warn] [node-red/tail] Not currently supported on Windows.
7 Sep 18:08:42 - [info] Settings file : \Users\Nithin B.node-red\settings.js
7 Sep 18:08:42 - [info] Context store : 'default' [module=memory]
7 Sep 18:08:42 - [info] User directory : \Users\Nithin B.node-red
7 Sep 18:08:42 - [warn] Projects disabled : editorTheme.projects.enabled=false
7 Sep 18:08:42 - [info] Flows file : F:\1.Office\4.JSL\1.Projects\StreamAnalyticsNodeRed\SMS\EAF V1.json
7 Sep 18:08:42 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
7 Sep 18:08:42 - [info] Starting flows
7 Sep 18:08:43 - [info] Started flows
7 Sep 18:08:43 - [info] [mqtt-broker:SMS_EAF1(127.0.0.1)] Connected to broker: mqtt://127.0.0.1:1883
7 Sep 18:08:43 - [info] [mqtt-broker:SMS_EAF2(127.0.0.1)] Connected to broker: mqtt://127.0.0.1:1883
7 Sep 18:08:43 - [info] [mqtt-broker:SMS_AOD(127.0.0.1)] Connected to broker: mqtt://127.0.0.1:1883
7 Sep 18:08:43 - [info] [mqtt-broker:CRM_HAPL(127.0.0.1)] Connected to broker: mqtt://127.0.0.1:1883
7 Sep 18:08:43 - [info] [mqtt-broker:CRM_CAPL(127.0.0.1)] Connected to broker: mqtt://127.0.0.1:1883
at Array.forEach ()
at C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\red\api\auth\index.js:63:13
at Route.dispatch (C:\Users\Nithin B\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\route.js:112:3)
Thanks for sharing that.
In your browser's javascript console there should be a corresponding error - can you share the url being requested that hits the error?
Nick
URL requested:
http://127.0.0.1:1880/context/flow/86d0a059.c7f39
JS file:
vendor.js:5
Stack track:
GET http://127.0.0.1:1880/context/flow/86d0a059.c7f39 400 (Bad Request)
send @ vendor.js:5
ajax @ vendor.js:5
m.(anonymous function) @ vendor.js:5
getJSON @ vendor.js:5
f @ red.min.js:16
u @ red.min.js:16
(anonymous) @ red.min.js:16
emit @ red.min.js:16
onchange @ red.min.js:16
y @ red.min.js:16
show @ red.min.js:16
success @ main.min.js:16
j @ vendor.js:2
fireWith @ vendor.js:2
x @ vendor.js:5
b @ vendor.js:5
XMLHttpRequest.send (async)
send @ vendor.js:5
ajax @ vendor.js:5
a @ main.min.js:16
j @ vendor.js:2
x @ vendor.js:5
b @ vendor.js:5
send @ vendor.js:5
ajax @ vendor.js:5
t @ main.min.js:16
j @ vendor.js:2
x @ vendor.js:5
b @ vendor.js:5
send @ vendor.js:5
ajax @ vendor.js:5
r @ main.min.js:16
(anonymous) @ main.min.js:16
success @ red.min.js:16
j @ vendor.js:2
x @ vendor.js:5
b @ vendor.js:5
send @ vendor.js:5
ajax @ vendor.js:5
loadNodeCatalogs @ red.min.js:16
j @ vendor.js:2
x @ vendor.js:5
b @ vendor.js:5
send @ vendor.js:5
ajax @ vendor.js:5
e @ main.min.js:16
j @ vendor.js:2
x @ vendor.js:5
b @ vendor.js:5
send @ vendor.js:5
ajax @ vendor.js:5
t @ red.min.js:16
j @ vendor.js:2
x @ vendor.js:5
b @ vendor.js:5
send @ vendor.js:5
ajax @ vendor.js:5
a @ red.min.js:16
init @ red.min.js:16
(anonymous) @ vendor.js:39
g @ vendor.js:39
success @ vendor.js:39
j @ vendor.js:2
x @ vendor.js:5
b @ vendor.js:5
send @ vendor.js:5
ajax @ vendor.js:5
_fetchOne @ vendor.js:39
each @ vendor.js:2
each @ vendor.js:2
_fetch @ vendor.js:39
load @ vendor.js:39
g @ vendor.js:39
j @ vendor.js:2
ready @ vendor.js:2
J @ vendor.js:2
Image of console:
The below error is occurring on tab click of a flow.
Thanks for the info. I don't have a quick answer for you. If you haven't enable persistent context, then I can't explain why you should be hitting these errors and no one else is.
This shouldn't stop you using the editor and your flows should still be running.
@knolleary More info on this:
I think I found the issue.
I realized that one of my flows is not throwing the exception and tried to figure out the differences.
Flow1(with error):
[{"id":"ce98dcdb.871cf","type":"tab","label":"HAP","disabled":false,"info":""},{"id":"2fecfbfd.9180d4","type":"inject","z":"ce98dcdb.871cf","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"0.1","x":105,"y":80,"wires":[["1a7ef9ac.e8ddc6"]]},{"id":"1a7ef9ac.e8ddc6","type":"function","z":"ce98dcdb.871cf","name":"OnFlowsLoad","func":"// Delete all flow variables except global referenced variable.\nfor (var variableName in context.flow) {\n    if (variableName !== \"global\")\n    {\n        delete context.flow[variableName];\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":335,"y":80,"wires":[[]]}]
Flow 2(without error):
[{"id":"6daaea62.30e304","type":"tab","label":"HS","disabled":false,"info":""},{"id":"44313aa0.f97a54","type":"inject","z":"6daaea62.30e304","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":true,"onceDelay":"0.1","x":115,"y":50,"wires":[["57192856.fcbd88"]]},{"id":"57192856.fcbd88","type":"function","z":"6daaea62.30e304","name":"OnFlowsLoad","func":"// Delete all flow variables except global referenced variable.\nfor (var variableName in context.flow) {\n    if (variableName !== \"global\")\n    {\n        //delete context.flow[variableName];\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":345,"y":50,"wires":[[]]}]
Difference is:
In flow 1 I am deleting all variables in context.flow object using delete keyword. I am initializing all required objects on deploy which I will be using later for processing data. Before initializing I am deleting first all variables in context.flow object and then creating variables, common functions, objects etc in context.flow.
NOTE: I didn't see this errors in previous versions of node-red.
@knolleary Can you see any changes made in node-red that led to this error now?
@knolleary - This may be related
There seems to be a problem in NR v0.19.2 (node.js v8.9.4 on OSX) with 'flow' variables (see attached flow with examples). NOTE: if I use globals, there is no problem.
If I try to set them via a change or function node, I get the error
TypeError: target.set is not a function
    at Promise (/usr/local/lib/node_modules/node-red/nodes/core/logic/15-change.js:247:44)
    at new Promise (<anonymous>)
    at getFromValue.then.fromParts (/usr/local/lib/node_modules/node-red/nodes/core/logic/15-change.js:235:36)
    at <anonymous>
    at process._tickCallback (internal/process/next_tick.js:188:7)
While a 'get' of the flow variable results in this error:
TypeError: node.context(...)[type].get is not a function
    at Object.evaluateNodeProperty (/usr/local/lib/node_modules/node-red/red/runtime/util.js:371:39)
    at Promise (/usr/local/lib/node_modules/node-red/nodes/core/logic/15-change.js:113:30)
    at getToValue (/usr/local/lib/node_modules/node-red/nodes/core/logic/15-change.js:112:24)
    at applyRule (/usr/local/lib/node_modules/node-red/nodes/core/logic/15-change.js:199:24)
    at applyRules (/usr/local/lib/node_modules/node-red/nodes/core/logic/15-change.js:307:31)
    at ChangeNode.<anonymous> (/usr/local/lib/node_modules/node-red/nodes/core/logic/15-change.js:323:17)
    at emitOne (events.js:116:13)
    at ChangeNode.emit (events.js:211:7)
    at ChangeNode.Node.receive (/usr/local/lib/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
    at InjectNode.Node.send (/usr/local/lib/node_modules/node-red/red/runtime/nodes/Node.js:137:22)
    at InjectNode.<anonymous> (/usr/local/lib/node_modules/node-red/nodes/core/core/20-inject.js:78:26)
    at InjectNode.emit (events.js:211:7)
    at InjectNode.Node.receive (/usr/local/lib/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
    at /usr/local/lib/node_modules/node-red/nodes/core/core/20-inject.js:117:22
Here is a set of flows demonstrating this issue:
[{"id":"132aca24.42755e","type":"catch","z":"37535c9b.381484","name":"catch get flow wakeup","scope":["ad967390.1dac28"],"x":400,"y":580,"wires":[["bbeed82f.d918f8"]]},{"id":"bbeed82f.d918f8","type":"debug","z":"37535c9b.381484","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":610,"y":580,"wires":[]},{"id":"56d40061.b106b","type":"inject","z":"37535c9b.381484","name":"","topic":"","payload":"good morning","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":230,"y":200,"wires":[["3a7dd5fe.1a5f1a"]]},{"id":"3a7dd5fe.1a5f1a","type":"change","z":"37535c9b.381484","name":"","rules":[{"t":"set","p":"wakeup","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":200,"wires":[["d60e90a1.7dffd"]]},{"id":"3c224f09.02eb3","type":"inject","z":"37535c9b.381484","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":200,"y":540,"wires":[["ad967390.1dac28"]]},{"id":"ad967390.1dac28","type":"change","z":"37535c9b.381484","name":"get flow wakeup","rules":[{"t":"set","p":"payload","pt":"msg","to":"wakeup","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":540,"wires":[["f4cfefb2.9cff1"]]},{"id":"f4cfefb2.9cff1","type":"debug","z":"37535c9b.381484","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":610,"y":540,"wires":[]},{"id":"d60e90a1.7dffd","type":"debug","z":"37535c9b.381484","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":610,"y":200,"wires":[]},{"id":"91df793b.c9f58","type":"inject","z":"37535c9b.381484","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":220,"y":320,"wires":[["9e2a73ee.79f27"]]},{"id":"9e2a73ee.79f27","type":"function","z":"37535c9b.381484","name":"flow set wakeup","func":"flow.set(\"wakeup\", \"good morning\");\nreturn msg;","outputs":1,"noerr":0,"x":400,"y":320,"wires":[["abac1ca9.4d782"]]},{"id":"abac1ca9.4d782","type":"debug","z":"37535c9b.381484","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":610,"y":320,"wires":[]},{"id":"3244736b.b884c4","type":"catch","z":"37535c9b.381484","name":"catch set flow wakup","scope":["9e2a73ee.79f27"],"x":420,"y":360,"wires":[["a8c4a686.040878"]]},{"id":"a8c4a686.040878","type":"debug","z":"37535c9b.381484","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":610,"y":360,"wires":[]},{"id":"22eabd2d.0b5c0a","type":"catch","z":"37535c9b.381484","name":"catch change flow wakup","scope":["3a7dd5fe.1a5f1a"],"x":430,"y":240,"wires":[["366d40e.bd561c"]]},{"id":"366d40e.bd561c","type":"debug","z":"37535c9b.381484","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":610,"y":240,"wires":[]},{"id":"97a13312.c7d91","type":"comment","z":"37535c9b.381484","name":"Setting a 'flow' variable causes an error, but globals work","info":"","x":430,"y":140,"wires":[]},{"id":"9bbc5e37.45ca38","type":"comment","z":"37535c9b.381484","name":"Getting the flow fails too, but again globals work","info":"","x":380,"y":480,"wires":[]}]
@knolleary
And as soon as I posted, I noticed that NR v0.19.3 is ou, so I installed it and the issue is fixed there....however, there are lots of debug messages coming in the log...
I added some extra debug messages around the loading of node modules if that's what you mean.
Just realized I had turned debug on in settings.js
@nithinbandaru1 - I suggest you upgrade to NR v0.19.3 and see if the issue still exists for you. I tried your flow that had the error and I get no error which I did see in v0.19.2
@zenofmud I just checked node-red version I am using Its already v0.19.3.
Where you suggesting to upgrade form GitHub?
Here is the complete error I am getting:
Moreover I see this error only on tab click of a flow.
I also see this in pallet window. Is this normal? I think I didn't see this in previous versions.
The dashboard errors are due to the fact you have 2 different "dashboards" installed that are incompatible with each other.
Please delete node-red-contrib-ui_j and restart Node-RED
@knolleary - I've been able to reproduce the error the OP gets with the attached flow. I wonder if this is both a bug and the user accessing the contect object incorrectly which triggers the error.
First the bug: With the attached flow, Under the comment 'Vannila version' press the inject node and in the debug you will see the timestamp. Next swap to 'Flow 2' - nothing happens (even monitoring the log) now swap back to 'Flow 1' and I receive the error the OP posted.
Second the incorrect access of the contect object. My theory is that the way the function tries to access the 'contect' object is incorrect. (It may have been correct before the persistent option was added - as a side note the node 'node-red-contrib-contextbrowser' now throws an error and I will open an issue about that in GitHub).
If you restart NR and run the flow under the comment '`Debug version' you will see the OP's code returns 'get', 'set' and 'keys' which are not the names of flow variables set by the user.
So two questions:
  1. how do you now list all the flow variables set
    and
  2. is the situation the user has a bug or caused by the change in accessing the names of flow variables?
The exttra flows are for adding and displaying a flow variable and dumping the contect object. And a demo
showing flow variables do not work in function nodes using the flow.get/set format. (change nodes don't work eithor.)
Flow to reproduce this follows:
[{"id":"510516ec.7bad18","type":"inject","z":"c20906ef.52b988","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"0.1","x":180,"y":100,"wires":[["3a568dd.06a2172"]]},{"id":"3a568dd.06a2172","type":"function","z":"c20906ef.52b988","name":"OnFlowsLoad","func":"// Delete all flow variables except global referenced variable.\nfor (var variableName in context.flow) {\n    if (variableName !== \"global\")\n    {\n        delete context.flow[variableName];\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":400,"y":100,"wires":[["2d0a461f.fd3232"]]},{"id":"205c6d34.40afe2","type":"catch","z":"c20906ef.52b988","name":"","scope":null,"x":620,"y":560,"wires":[["c9c65c0b.e2dea8"]]},{"id":"c9c65c0b.e2dea8","type":"debug","z":"c20906ef.52b988","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":810,"y":560,"wires":[]},{"id":"2d0a461f.fd3232","type":"debug","z":"c20906ef.52b988","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":630,"y":100,"wires":[]},{"id":"2af14454.477944","type":"inject","z":"c20906ef.52b988","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"0.1","x":180,"y":340,"wires":[["c38e2a00.f1428"]]},{"id":"c38e2a00.f1428","type":"function","z":"c20906ef.52b988","name":"Dump context object","func":"msg.payload = context;\nreturn msg;","outputs":1,"noerr":0,"x":420,"y":340,"wires":[["3f3c3bc.252db44"]]},{"id":"3f3c3bc.252db44","type":"debug","z":"c20906ef.52b988","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":630,"y":340,"wires":[]},{"id":"9a3c422.1f73ec","type":"inject","z":"c20906ef.52b988","name":"","topic":"","payload":"Happy trails","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":190,"y":460,"wires":[["ab0068ce.b309c"]]},{"id":"ae468489.40884","type":"inject","z":"c20906ef.52b988","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":180,"y":500,"wires":[["3472f453.04841c"]]},{"id":"54f2571a.f84188","type":"debug","z":"c20906ef.52b988","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":650,"y":500,"wires":[]},{"id":"71887d9.00be704","type":"comment","z":"c20906ef.52b988","name":"Vannila version","info":"","x":180,"y":60,"wires":[]},{"id":"1e301b7e.92fdf5","type":"inject","z":"c20906ef.52b988","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":"0.1","x":180,"y":220,"wires":[["3801e321.50859c"]]},{"id":"3801e321.50859c","type":"function","z":"c20906ef.52b988","name":"OnFlowsLoad","func":"// Delete all flow variables except global referenced variable.\nfor (var variableName in context.flow) {\n    node.warn(\"debug1:\"+ variableName);\n    if (variableName !== \"global\")\n    {\n        delete context.flow[variableName];\n    }\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":400,"y":220,"wires":[["2b73f2a5.7fa04e"]]},{"id":"2b73f2a5.7fa04e","type":"debug","z":"c20906ef.52b988","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":630,"y":220,"wires":[]},{"id":"801a7e3c.caa7d8","type":"comment","z":"c20906ef.52b988","name":"Debug version","info":"","x":180,"y":180,"wires":[]},{"id":"d20dd1fd.3bf108","type":"comment","z":"c20906ef.52b988","name":"Debug version","info":"","x":180,"y":300,"wires":[]},{"id":"c26c178d.f2fc88","type":"comment","z":"c20906ef.52b988","name":"Debug version","info":"","x":180,"y":420,"wires":[]},{"id":"a7a51c21.ef657","type":"debug","z":"c20906ef.52b988","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":650,"y":460,"wires":[]},{"id":"4f582c9e.89915c","type":"change","z":"c20906ef.52b988","name":"dump the flow variable","rules":[{"t":"move","p":"test","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":560,"wires":[[]]},{"id":"ab0068ce.b309c","type":"function","z":"c20906ef.52b988","name":"Create flow variable","func":"flow.set(\"myData\", msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":440,"y":460,"wires":[["a7a51c21.ef657"]]},{"id":"3472f453.04841c","type":"function","z":"c20906ef.52b988","name":"Create flow variable","func":"var x = flow.get(\"myData\");\nreturn msg;","outputs":1,"noerr":0,"x":440,"y":500,"wires":[["54f2571a.f84188"]]}]
Hi @nithinbandaru1
The problem here is you are deleting all properties on the context.global object - which includes the get, set and keys functions.
Before 0.19, that probably didn't matter if you weren't using them. But in 0.19 we introduced the context sidebar panel which uses context.keys to list the properties in storage - so when the editor loads it tries to load the context contents in the sidebar (likewise when you switch tabs) and you hit this error.
I'll look to see if we can make the get/set/keys functions non-enumerable properties so they can't be deleted by mistake.
