typedInput with optgroup
I am working on some updates on one of my Nodes.
I have created a list of options for my type.
Nodes.push({
    value: `ZWJS-LOC:${location}`,
    label: `${location.toUpperCase()}`,
const input = $('#node-input-filteredNodeId');
input.typedInput({
    type: 'nodes',
    types: [{
        value: 'nodes',
        multiple: true,
        options: Nodes,
I have a need to create separators.
Now, I am managing this with some very hacky methods (I am not happy with my self)
so, I'll ask:
is there a native way to do this with typedInput using a custom list of options.
  • I,e using some type of optgroup support?
I couldn't see anything in docs, but understand this can sometimes be outdated
You can use the icon property to inject HTML content, just like the conf-types type does. But I don't know if you'll be able to get the desired final result.
Thanks - but not sure that is what I am after..
I just need a way to create groups of options (at least a separator) - where that separator is not selectable and that it is not used in the final serialised value that is stored.
Indeed :confused: I'll look into a way to integrate it.
Something like:
// options =
Array<{ value: string; label: string; group?: string }>
// or
Array<{ value?: string; label: string; group?: Array<{ value: string; label: string }> }>
Its based on this...
$("#node-input-example5").typedInput({type:"fruit", types:[{
    value: "fruit",
    multiple: true,
    options: [
        { value: "apple", label: "Apple"},
        { value: "banana", label: "Banana"},
        { value: "cherry", label: "Cherry"},
I have used it for a while.
Problem is, this doesn't seem to support optgroup, so something like
$("#node-input-example5").typedInput({type:"foods", types:[{
    value: "foods",
    multiple: true,
    options: [
        { value: "apple", label: "Apple", group: "Fruit"},
        { value: "banana", label: "Banana", group: "Fruit"},
        { value: "cherry", label: "Cherry", group: "Fruit"},
        { value: "twix", label: "Apple", group: "Chocolate"},
        { value: "chomp", label: "Banana", group: "Chocolate"},
        { value: "Curley-wirly", label: "Cherry", group: "Chocolate"},
I think will be a great upgrade?
Note: Im going to move this to an FR.
Yep :winking_face_with_tongue:
The question is: can the appearance of the separator be customized? The data format will depend on this. Using custom optgroup.
I think if this is seen as an accepted feature.
one should denote that the options are grouped?
    value: "foods",
    multiple: true,
    grouped: true, /* <-- Here */
    options: [
Example...
Devs might group certain options - but not all.
grouped:true
  • Options are only visible if they have a group
grouped:false | undefined
  • group is ignored - A flat list
+1 for groups!
When working on version 3 of CronPlus, I went hunting in the source code for group support after finding that separators were not a thing.
If anyone does pick this up, I would hope that on top of group support, it would add simple line separator support too.
In the mean time,
I have a clean way of doing this...
When I know something in my list is a separator.
I ensure its value has a maker : ZWJS-LOC:XXXX
Then css it out
a[value^="ZWJS-LOC:"] {
	font-weight: bold;
	pointer-events: none;
	background-color: var(--red-ui-form-button-background);
a[value^="ZWJS-LOC:"] input[type="checkbox"] {
	display: none;
Seems to work well for the interim.
using this...
adding something like isSeparator to an option as apart of the native support, I think will allow great control of this..
    value: "foods",
    multiple: true,
    options: [
        { label: "Fuit", isSeparator: true},
        { label: "Chocolate", isSeparator: true},
        { value: "twix", label: "twix"},
        { value: "chomp", label: "chomp"},
        { value: "Curley-wirly", label: "Curley-wirly"},
