Please see the global variables and function below.
I hope you can find out why this fails.(error in post subject) I can only assume this is happening at line 6 or 8.
I needed:
global.get("garage.temperature"),
global.get("garage.humidity"),
global.get("storage.temperature"),
global.get("storage.humidity")
Before you can access the global you need to fetch it. If this is in a function node I suggest you read the documentation
yes. I just discovered it the hard way
it work now ![]()
