I had a flow that was running through then this occurred.
TypeError: Request path contains unescaped characters
I have searched for similar issues but have not found anything too similar to this.
I am assuming that I had a sustained network outage that impacted my openweathermap node?
I have stopped node-red and restarted the same message comes back and my i2c LCD display is stuck. I can not get the the message to stop which is a weakness of mine for being a Noob.
This is my broken flow:
"id": "55ac7a6f.5dc07c",
"type": "tab",
"label": "Project 24",
"disabled": false,
"info": "",
"env": []
"id": "d7e12e53.a06f6",
"type": "inject",
"z": "55ac7a6f.5dc07c",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "10",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "Click",
"payloadType": "str",
"x": 150,
"y": 180,
"6f7754a7.f6142c"
"id": "fd280da4.456798",
"type": "LCD20x4-I2C",
"name": "LCD",
"speed": "3",
"size": "20x4",
"address": "0x27",
"x": 610,
"y": 180,
"id": "3628ad74.330682",
"type": "function",
"name": "Display",
"func": "var T = msg.payload.tempc\nvar H = msg.payload.humidity;\nvar Temp = \"Temp= \" +((T*1.8)+32)+\" F\";\nvar Hum = \"Humidity = \" + H + \"%\";\nmsg.payload={msgs:[\n {msg:Temp},\n {msg:Hum}\n ]};\nreturn msg;\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 480,
"y": 180,
"fd280da4.456798"
"id": "6f7754a7.f6142c",
"type": "openweathermap",
"name": "Temp & Hum",
"wtype": "current",
"lon": "",
"lat": "",
"city": "DENVER",
"country": "usa",
"language": "en",
"credentials": {},
"x": 290,
"y": 180,
