Online help says:
However, the node does not consider a msg.port variable (unlike "UDP out").
Is there any workaround for that(?)
Online help says:
msg.ip and msg.port are output variables, from the UDP in node. You can not set port and ip dynamically with them
for me it seems as if they are variables for the "udp out".
I would like to use them for the "udp in" as also mentioned in the online help but this unfortunately doesn't work
I cannot see that mentioned in the online help. It says:
" It also provides msg.ip and msg.port set to the ip address and port from which the message was received."
Which means that the node outputs those values. Not that you can pass them in to the node.
yes, you are right.
Now I also see that this is the meaning of this sentence
It is really a pity that "udp out" supports this flexible handling and "udp in" not...
Why do you want to set it dynamically? for end user configuration? other reason?
Would an env variable for the port number suffice?
You can use ${ENV_VAR} in place of a port number if you wish.
I have to connect to a unit which can work with different port-numbers so I want to configure the port-number in the dashboard.
Can I also use flow or global variables in place of a port number within the "udp" node (?)
No. Your only options are
