Hi There,
I'm trying to send and receive massages via UDP with two Node-Red instances installed via Docker containers.
Flows on instance 1:
"id": "3affecfb.85c07c",
"type": "inject",
"z": "3fccb497.9b16f4",
"topic": "",
"payload": "",
"payloadType": "date",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 320,
"y": 160,
"8cf7dc9a.c37c7"
"id": "311c30f9.5930d8",
"type": "udp in",
"iface": "",
"port": "2001",
"ipv": "udp4",
"multicast": "false",
"group": "",
"datatype": "buffer",
"x": 320,
"y": 260,
"41fca546.e83e2c"
"id": "41fca546.e83e2c",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"x": 490,
"y": 260,
"id": "8cf7dc9a.c37c7",
"type": "udp out",
"addr": "192.168.2.101",
"iface": "",
"port": "1999",
"ipv": "udp4",
"outport": "2000",
"base64": false,
"x": 600,
"y": 160,
Flow on Instance 2:
"id": "3e48491b.09f93e",
"type": "udp in",
"z": "5ea6d14d.86d94",
"iface": "",
"port": "1999",
"ipv": "udp4",
"group": "",
"x": 220,
"y": 340,
"12cc1018.37d628"
"id": "12cc1018.37d628",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"x": 450,
"y": 340,
"id": "45d00fe0.41e258",
"type": "inject",
"topic": "",
"payload": "",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 220,
"y": 300,
"f01672f5.c1bee8"
"id": "f01672f5.c1bee8",
"type": "udp out",
"addr": "192.168.2.111",
"iface": "",
"port": "2001",
"ipv": "udp4",
"outport": "",
"base64": false,
"x": 490,
"y": 300,
Wireshark picture, of what happens:
So what I expected was sending and receiving from one to the other...
but that doesn't happen.
Docker Statement on both instances: (running on two different pi's) same network, static IP's
docker run -d -p1880:1880 --name nodered echteler/nodered:arm32v7
so I hope for some help fixing the issue
Thank You very much for Your help
