stgj
2 December 2024 21:23
1
This is not a bug, but I need help with something.
I have a set of data in an influxdb. I feed the ui-chart with this data.
The timeframe is chosen in the influx query.
eg.
"series": "Air",
"time": "21:12:02"
"value": "15.2"
"series": "Cabinet",
"time": "21:12:30",
"value": "14.1"
The ui-chart then in the ui groups this in "Air" and "Cabinet".
If i press "Cabinet" the ui sorts the "Cabinet" away. Thats nice.
The ui-chart is set to "replace" the data that comes in.
And the new data comes in at an interval of 5seconds.
This means that when the new data comes in, the sorting I have done gets reset.
Anyone with a good idea on how to maintain the sorting?
Best regards
Steffen
When you say "sort", do you mean "hide/show"? I noticed this recently too, you click on the line in the Legend, and that hides the line, but new data arriving re-draws the chart and clears any filtering you'd applied
Can be fixed by doing follwing:
Add custom click handler for legend plugin
plugins: {
legend: {
display: true,
position: 'top',
labels:{
boxHeight:1,
boxWidth:10,
onClick: function (evt, item) {
if(this.chart.isDatasetVisible(item.datasetIndex)){
//store dataset visibility
root.visibility[item.datasetIndex] = false
else{
root.visibility[item.datasetIndex] = true
// call default click handler
Chart.defaults.plugins.legend.onClick.call(this, evt, item, this);
And when upating (probalby needed for replace only)
set the visibility of dataset
this.chart.data.datasets = this.datasets
this.chart.data.datasets.forEach((dataSet, i) => {
let meta = this.chart.getDatasetMeta(i);
meta.hidden = this.visibility[i] == false
this.chart.update()
Needs of course decision how and where to save and should it survive sessions and such things..
stgj
4 December 2024 18:44
4
Yes, I mean "hide/show".
Will look in to your answer in a few days hotNipi.
Best regards
Steffen
My answer was targeted rather how the core chart widget can be improved. But same strategy fits if you do chart using the ui_template.
system
Closed
3 January 2025 18:49
6
