UI control node_ Group doesnt hide anymore
I am using UI control node to hide and unhide groups in same tab. And it was working well all the time.
Suddenly I have started facing an issue that the one group doesnt hide anymore. Do sommone else experience issues with ui control node??
        "id": "7de330bd20e3d9cb",
        "type": "ui_button",
        "z": "3377f80e1f360e5f",
        "group": "7d101395a5edf44f",
        "order": 1,
        "width": "4",
        "height": 3,
        "passthru": false,
        "label": "<font size= 70> Station Left",
        "tooltip": "",
        "color": "",
        "bgcolor": "green",
        "className": "",
        "icon": "fa-send fa-3x ",
        "payload": "{\"group\":{\"hide\":[\"ARS_Protective Stops\"],\"show\":[\"Admin_Control\",\"ARS_Assembly_______________ACP_______________FKT_______________EOL_________________Laser\"]}}",
        "payloadType": "json",
        "topic": "",
        "topicType": "str",
        "x": 380,
        "y": 3860,
                "2fcb2b9168a1c180",
                "b5068acd97dcb04c",
                "38548e5ebcdb8faf",
                "ad6fb563d335278f"
        "id": "5eeb2e2fa662a1f5",
        "order": 2,
        "width": "4",
        "height": 3,
        "passthru": false,
        "label": "<font size= 70>Station Right",
        "tooltip": "",
        "color": "",
        "bgcolor": "green",
        "className": "",
        "payload": "{\"group\":{\"hide\":[\"ARS_Assembly_______________ACP_______________FKT_______________EOL_________________Laser\"],\"show\":[\"Admin_Control\",\"ARS_Protective Stops\"]}}",
        "topic": "",
        "topicType": "str",
        "x": 380,
        "y": 3940,
                "455a8356c04bc3d2",
                "07a27db802244f45",
                "38548e5ebcdb8faf",
                "ad6fb563d335278f"
        "id": "455a8356c04bc3d2",
        "type": "change",
        "name": "Enable",
        "rules": [
                "t": "set",
                "p": "enabled",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 720,
        "y": 3740,
                "7de330bd20e3d9cb"
        "id": "2fcb2b9168a1c180",
        "type": "change",
        "name": "Disabled",
        "rules": [
                "t": "set",
                "p": "enabled",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 500,
        "y": 3740,
                "7de330bd20e3d9cb"
        "id": "07a27db802244f45",
        "type": "change",
        "name": "Disabled",
        "rules": [
                "t": "set",
                "p": "enabled",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 940,
        "y": 3760,
                "5eeb2e2fa662a1f5"
        "id": "b5068acd97dcb04c",
        "type": "change",
        "name": "Enable",
        "rules": [
                "t": "set",
                "p": "enabled",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 900,
        "y": 3860,
                "5eeb2e2fa662a1f5"
        "id": "939eeeab9104f730",
        "type": "comment",
        "name": "Station A",
        "info": "",
        "x": 340,
        "y": 3960,
        "id": "38548e5ebcdb8faf",
        "type": "ui_ui_control",
        "events": "all",
        "x": 800,
        "y": 3980,
        "id": "ad6fb563d335278f",
        "events": "all",
        "x": 680,
        "y": 3660,
        "id": "7d101395a5edf44f",
        "type": "ui_group",
        "name": "Group 3",
        "tab": "52c8484964ef80aa",
        "order": 1,
        "disp": true,
        "width": 5
![UI control|690x162](upload://xYdQXZ3Ui1yhXauJBFPcC8Brkjz.jpeg)
        "id": "52c8484964ef80aa",
        "type": "ui_tab",
        "name": "ARS",
        "icon": "dashboard",
        "order": 31,
        "disabled": false,
        "hidden": false
  1. your flow doesn't import because of this line in it:
    "type": "ui_group",
    "name": "Group 3",
    "order": 1,
    "disp": true,
    "width": 5
  2. There is only one tab in the flow you provide
From help text
tab_name_group_name_with_underscores
You have a space that needs to be an underscore. ARS_Protective Stops.
oHH Thank you
