Show/Hide Using ui-control Issues
Hi all,
I have created several different dashboards (both v1 and v2) using the ui-control node to show/hide certain pages and groups or to redirect the user to a particular page with no issues. The syntax obviously changed slightly between dashboard v1 and v2 but everything was working. Today I looked at one of my dashboards and no matter what I did, the ui-control node would not properly show/hide certain pages and groups and wouldn't redirect to different pages. I took the flow and recreated it on a separate, isolated instance and had no issues being able to show/hide or redirect. I connected debug nodes and see no errors. I tried on multiple browsers but still the issue persists. I cleared browser cache and checked for any console errors (there were none). I feel quite dumb as I stated this was working before. Is there something I am missing? Any help would be appreciated.
Is it D1 or D2 that is failing?
D2 is the one failing.
Add a debug node showing what you are sending to the ui-control node and post what it shows for a failing operation.
Show and hide has been improved in the new v1.23.0 released today.
docs: Control ui-control | Node-RED Dashboard 2.0
So now you can do:
msg.payload = {
    groups: {
        show: [
           'abcd1234', // ID of group to show
        hide: [
           'efgh5678', // ID of group to hide
           'wxyz9876', // ID of group to hide
The advantage of using IDs is if you change the name of the page or group, the ID remains the same.
To get the ID of a group, use the i info panel on the right hand sidebar
You didn't tell us, but I am guessing that it stopped working when you changed the group names and added in colons.
That has also been fixed in the most recent release, I believe.
I found the mistake and corrected the issue. Thanks for the assistance.
