Ui_dropdown, looking for better/faster inputting solution
I need a few UI dropdowns with a large number of Options (1-900 in steps of 1, 80-150 in steps of 1, etc.).
I created this in two different ways, both by inputting an array with the desired Options.
The first is: creating the options inside a function using a for loop, then inputting them into the dropdown. This results in very slow loading of the dashboard after deployment/restart flows.
ver-1.json (9.1 KB)
The second is: creating the Options and saving them in flow.context. Then through a function, inputting them into the dropdown. This way is a bit faster.
ver-2.json (13.9 KB)
I'm looking for an idea/suggestion for an even better (faster) way to inject the dropdowns and load the dashboard.
Thanks.
I understand you are still using dashboard-1, which is no longer supported.
Anyway, What I would do is define the dropdown as an HTML object in a ui-template node, and populate it programmatically in the JS script.
With that number of options wouldn’t a slider be better
Yes, I did this on DB-1. After trying it on DB-2, I see that loading is much faster, almost instantaneous! No need for further improvement. Thx!
Yes, that was the last option. The user interface is clearer with dropdown. In DB-2 everything is much faster.
In DB-2 everything works much faster!
