I have a ui-list with switches and need to replace that with dashboard v2.
How can I replace that?
I read this: https://discourse.nodered.org/t/ui-list-for-dashboard-2
It seems like a dynamic list of switches doesn't yet exist?
I am not aware of anyone writing a ui-list contrib node. You can however quite easily create this using a ui-template.
If I get time later in the week I'll show you how - feel free to nudge me if I've not replied by Friday afternoon.
If anyone else in the meantime wants to provide a solution, please jump in.
Thanks. I created a template node that takes two additional fields to annotate the switch label and description.
<template>
<v-list class="switch-list" density="compact">
<v-list-item v-for="item in items" :key="item.id" density="compact" class="switch-item">
<v-list-item-title class="label">
{{ item.label }}
</v-list-item-title>
<v-list-item-subtitle class="description">
{{ item.description }}
</v-list-item-subtitle>
<template #append>
<v-switch v-model="item.value" density="compact" hide-details :color="item.value ? 'primary' : undefined"
@update:modelValue="onToggle(item)" />
</template>
</v-list-item>
</v-list>
</template>
<script>
export default {
props: ["msg"],
data() {
return {
items: []
watch: {
msg: {
immediate: true,
handler(newMsg) {
if (Array.isArray(newMsg?.payload)) {
// Deep copy, damit Vue reaktiv bleibt
this.items = JSON.parse(JSON.stringify(newMsg.payload))
methods: {
onToggle(item) {
this.$socket.emit("msg", {
payload: {
value: item.value
label: item.label,
description: item.description
</script>
<style scoped>
.switch-list {
padding: 0;
.switch-item {
padding-top: 6px !important;
padding-bottom: 6px !important;
.label {
font-weight: 600;
.description {
opacity: 0.7;
</style>
