Hey guys
I need help
I am using ui_notification in red node. But I don't want it to show on other tabs.
It should appear in a single tab.
Can you help me?
Try this
[{"id":"bb7ef9863eea1ea9","type":"ui_ui_control","z":"02ca79a9a08a0cf4","name":"","events":"all","x":200,"y":740,"wires":[["98f6f8872fac0320","854585b31749180e"]]},{"id":"f33a6678ec5c0348","type":"change","z":"02ca79a9a08a0cf4","name":"allow notifications","rules":[{"t":"set","p":"notifications","pt":"global","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":660,"wires":[[]]},{"id":"98f6f8872fac0320","type":"switch","z":"02ca79a9a08a0cf4","name":"check for dashboard changes","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"change","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":470,"y":740,"wires":[["6392474fdfc3ea0f"],["6bc115b9e5e2ec8e"]]},{"id":"6392474fdfc3ea0f","type":"switch","z":"02ca79a9a08a0cf4","name":"allow notifications for tab 0 ","property":"tab","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":620,"y":680,"wires":[["f33a6678ec5c0348"],["6bc115b9e5e2ec8e"]]},{"id":"6bc115b9e5e2ec8e","type":"change","z":"02ca79a9a08a0cf4","name":"disable notifications","rules":[{"t":"set","p":"notifications","pt":"global","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":720,"wires":[[]]},{"id":"e9315c323af950c2","type":"ui_toast","z":"02ca79a9a08a0cf4","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"className":"","topic":"","name":"","x":870,"y":840,"wires":[]},{"id":"5d88b5eb9222e5a0","type":"inject","z":"02ca79a9a08a0cf4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Hello world","payloadType":"str","x":400,"y":840,"wires":[["e5107f52fa76871c"]]},{"id":"e5107f52fa76871c","type":"switch","z":"02ca79a9a08a0cf4","name":"if notifications enabled","property":"notifications","propertyType":"global","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":620,"y":840,"wires":[["e9315c323af950c2"]]},{"id":"854585b31749180e","type":"debug","z":"02ca79a9a08a0cf4","name":"Dashboard says","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":320,"y":680,"wires":[]}]
Perfect @hotNipi
But I have several users connected to the server, and your example is linked to screen switching. It can get confusing if one user doesn't switch screens and another does. ![]()
but the idea was really good. thank you
Thank you for your help.
I was trying to get away from an html because I have no experience, but I think it's the only way.
I don't see any options to send or limit notifications based on socket I'd so this seems to be end of story. It is not possible.
Notifications should only go to a single client if the socketId is included. It isn't a terribly robust mechanism though since many things can cause a client to get a new socket id.
Can you help me?
this is my node:
"id": "10df8c489491addf",
"type": "ui_button",
"z": "c61d0d5905659bc7",
"group": "50e5db1fad5aad4a",
"order": 1,
"width": 3,
"height": 1,
"passthru": false,
"label": "OP",
"tooltip": "",
"color": "",
"bgcolor": "",
"className": "",
"icon": "",
"payload": "DIGITE A OP",
"payloadType": "str",
"topic": " ",
"topicType": "str",
"x": 70,
"y": 60,
"bcca6b5d3dda1e53"
"id": "bcca6b5d3dda1e53",
"type": "ui_toast",
"position": "prompt",
"displayTime": "5",
"highlight": "",
"sendall": true,
"outputs": 1,
"ok": "OK",
"cancel": "CANCEL",
"raw": true,
"className": " ",
"topic": "",
"name": " OP",
"x": 230,
"y": 60,
"b069222f31e953af",
"2fe887e4857ec0bb",
"453135cd52728d3e"
"id": "b069222f31e953af",
"type": "change",
"rules": [
"t": "move",
"p": "payload",
"pt": "msg",
"to": "op_busca",
"tot": "global"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 170,
"y": 140,
"id": "50e5db1fad5aad4a",
"type": "ui_group",
"name": "SELECIONAR CONSULTA",
"tab": "01defd39958bdd2d",
"order": 1,
"disp": true,
"width": 15,
"collapse": false,
"className": ""
"id": "01defd39958bdd2d",
"type": "ui_tab",
"name": "CONSULTA PRODUĂĂO",
"icon": "find_in_page",
"order": 10,
"disabled": false,
"hidden": false
how change for ui_template? Thank you
Definitely useful info but didn't find anything in documents.
Anyway, that makes it kind of possible again...
[{"id":"bb7ef9863eea1ea9","type":"ui_ui_control","z":"02ca79a9a08a0cf4","name":"","events":"all","x":200,"y":1040,"wires":[["854585b31749180e","95883a3ea9e161b1"]]},{"id":"e9315c323af950c2","type":"ui_toast","z":"02ca79a9a08a0cf4","position":"top right","displayTime":"5","highlight":"","sendall":false,"outputs":0,"ok":"OK","cancel":"","raw":false,"className":"","topic":"","name":"","x":730,"y":1080,"wires":[]},{"id":"854585b31749180e","type":"debug","z":"02ca79a9a08a0cf4","name":"Dashboard says","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":400,"y":1040,"wires":[]},{"id":"c3e698e26b68d589","type":"inject","z":"02ca79a9a08a0cf4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Hello world from trigger node","payloadType":"str","x":210,"y":1080,"wires":[["a39eeb910b13efe8"]]},{"id":"95883a3ea9e161b1","type":"function","z":"02ca79a9a08a0cf4","name":"store dashboards states","func":"let dashboards = global.get('dashboards') || []\nswitch (msg.payload) {\n case \"connect\":\n dashboards.push({socketid:msg.socketid, tab:-1})\n break;\n case \"lost\":\n dashboards = dashboards.filter(function (d) { return d.socketid != msg.socketid; });\n break;\n case \"change\":\n let changed = false\n dashboards.forEach(function(d) {\n if(d.socketid == msg.socketid){\n d.tab = msg.tab\n changed = true\n } \n });\n if(!changed){\n dashboards.push({ socketid: msg.socketid ,tab:msg.tab});\n }\n break;\n default:\n dashboards = []\n \n}\n\nglobal.set('dashboards',dashboards);\n","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":1000,"wires":[]},{"id":"ea53ae149ba0da3e","type":"inject","z":"02ca79a9a08a0cf4","name":"clear on init","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":210,"y":980,"wires":[["95883a3ea9e161b1"]]},{"id":"a39eeb910b13efe8","type":"function","z":"02ca79a9a08a0cf4","name":"check for connected dashboards tabs","func":"let allowedTab = 0;\nlet dashboards = global.get('dashboards') || []\n\ndashboards.forEach(function(d) {\n if(d.tab === allowedTab){\n node.send({payload:msg.payload,topic:msg.topic,socketid:d.socketid})\n }\n});\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":470,"y":1080,"wires":[["e9315c323af950c2"]]}]
You can use the following:
"id": "bde8e413e9664562",
"type": "ui_template",
"z": "cc0dc37e13d8db0a",
"order": 1,
"width": 0,
"height": 0,
"format": "<form>\n <md-button style=\"background-color:gray;text-transform:none\" class=\"button\" ng-click=\"buttonClick()\"> OP </md-button>\n</form>\n\n<script>\nvar $scope = this.scope;\n\nthis.scope.buttonClick = function()\n{\n let ok = confirm('OK to proceed?');\n let newMsg = {};\n if (ok)\n newMsg.payload = \"OK\";\n else\n newMsg.payload = \"Cancel\";\n \n $scope.send(newMsg);\n}\n\n</script>",
"storeOutMessages": false,
"fwdInMessages": false,
"resendOnRefresh": false,
"templateScope": "local",
"className": "",
"x": 320,
"y": 100,
"b39e2c5ec3b1750e"
"id": "b39e2c5ec3b1750e",
"type": "debug",
"name": "debug 57",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 460,
"y": 100,
"type": "ui_group",
"order": 1,
"disp": true,
"width": 15,
"collapse": false,
"className": ""
"type": "ui_tab",
"order": 10,
"disabled": false,
"hidden": false
Don't move your result to a global variable, as you might run into concurrency issues (race conditions)
I'm sure I remember seeing it somewhere. But worth remembering that Dashboard uses the Socket.IO library to manage its websocket connections. The id is managed by that library.
