I updated ui-state-trail from 0.4.2 to 0.4.4 and found that the label is not updating where i have used mustache template
i was getting the values into this in earlier version.
is it a bug ?
is it a bug ?
Some things has been changed between those versions. It was never promised out, that mustache is supported at the configuration.
What is supported, - you can change the label by using msg.control
See the README document
Got it. Thanks for the help.
placed a change node with jsonata expression to set property msg.control.label and kept the label field in state-trail blank.
