Hello I have been working with the UI-SVG node, and I would like to get one step further.
I have installed some door sensors and manage to have my house blueprint update.
e.g Door Close
Door Open
I manage this by sending the following command
msg.payload=[
"command": "update_style",
"selector": "#porta_da_sala",
"attributeName": "stroke",
"attributeValue": "red"
"command": "set_attribute",
"attributeName": "x2",
"attributeValue": "210"
"attributeName": "y2",
"attributeValue": "1410"
My question is
In order to have a more clear indication that the door is open how could I animate this ( or any other suggestions indications)
considering underling the SVG
" path id="PORTA_TESTE" d="M676,1335 v-46 a46,46 0 0,0 -46,46 z" style="fill:red;fill-opacity: 1;stroke:black;stroke-width:1;stroke-dasharray: 20;"/>"
You could add the 2 elements and use visibility attribute
<rect id="door1_open_element" x="20" y="20" width="80" height="80" visibility="visible" /> <!-- open -->
<rect id="door1_closed_element" x="120" y="20" width="80" height="80" visibility="hidden"/> <!-- closed-->
send
"selector": "#door1_closed_element",
"attributeName": "visibility",
"attributeValue": "visible"
"selector": "#door1_open_element",
"attributeValue": "hidden"
Hi Steve
Thank you very much for your answer, albeit I might not have explain very well.
What you presented I already have, my main issue is how to animate this quarter pie, build as path,
path id="PORTA_TESTE" d="M676,1335 v-46 a46,46 0 0,0 -46,46 z" style="fill:red;fill-opacity: 1;stroke:black;stroke-width:1;stroke-dasharray: 2 "
what do you mean animate it? in what way?
that´s the question ... with circles I change the radius and it looks like a sonar.
In this case since its a path i dont know how to do it
I just want something that raises attentions ... blinking ... changing shape..
Thank you
ok, so not really a node-red question, more an SVG question.
What you are looking for is the animate tag
There are lots of resources out there.
some good demos and details here
Much of this can also be achieved in the ui-svg "animations" tab
