Ui-table and css - fails for more than one table
Hi there,
due to a private discussion with a fellow member of this forum I came across a limitation of my approach to customize a ui-table with css.
While it works great for one table, it falls back to default if I choose more than one table.
It works as follows:
  • set a ui-table according to your needs and assign it to ui-group "whatever"
  • add a ui-template, set Template Type to "Widget in group", assign it to the same ui-group "whatever" and apply your css code
Check the example I posted here.
Now:
If I want to add more ui-table nodes to the very same ui-group "whatever" the css adjustments in ui-template are ignored. All tables are shown with default/standard layout. Is this by design, an error or do I miss something here?
Note:
A workaround that works: Assign each additional table to a separate ui-group, uncheck "Display group name" and arrange those tables as needed on the dashboard page. However, downside is, that it requires multiple clones of the very same ui-template. Each assigned to a different ui-group though.
The general assumption is that the dashboard is themed once and that all instances of widgets pick up the overall theme. I suspect the workaround you have that allocates each to it's own template then allows you to target your CSS more precisely is probably the best answer.
Thanks dceejay for your answer. So I am not missing a bit here. It works as designed.
Does that explain why, with more than one table, the css applies to none of them? I would have expected it to apply to all of them.
That was my assumption as well. I just tested it again. And it is even crazier.
If, in my setup, I just clone my ONE table, both table show in the same group, however, layout is back to default.
If I then re-assign the table clone to another group of that page, my customizing applies to both table. Even though the ui-template node is neither cloned as well nor is it in any way assigned to the ui-group of the clone.
Further tests and further craziness:
If I swap the ui-group in the ui-template to that assigned to the table clone's group, my tables are back to default layout and my css is completely ignored.
original table assigned to [Z]A
cloned table assigned to [Z]B
ui-template assigned to [Z]A --> my css customization works fine for both table
ui-template assigned to [Z]B --> my css customization doesn't work for both table
Does the alphabetical order of groups have an effect here? In the final gui itself, [Z]A is listed below [Z]B :smiley:
DISCLAIMER: I have no clue about CSS at all. I "developed" my solution based on trial and error. I only have a vague gut feeling how things work, but I am at least able to share my observation here :smiley:
Clear the browser cache when anything odd happens just to make sure that is not the problem.
I did so with both, Safari and Firefox on macos.
OK, it was just a thought. I think you will have to wait for Dave or someone who knows more about css to comment further.
