I am trying to delete several columns at once by sending the command deleteColumn, but it only deletes the column that refers to the first item of the arguments array. Do have I have to send an independent command for each individual column I want to delete? Is there a single command to delete all columns and data, i.e. to clear the table completely?
{"command": "deleteColumn", "arguments": [ "event", "active", "trigger" ], "returnPromise": false}
In this case only event column is being deleted.
