Ui-table row contextmenu doesn't work?
Hello, I am trying to add Context menu on node-red-ui-table using the msg.ui_control as seen below:
However, It doesn't work when I right-clicked on my table.
As per Tabulator's manual:
I don't know what I did wrong. Hoping for your guidance. or a confirmation if it is not possible on this table?
Thank you Node-red experts :slight_smile:
Regards,
Henjoe
you did nothing wrong (beside the action should be a callback function) but ui-table uses the now outdated version 4.4.1 of tabulator which does not have the menue feature. (If you use the docs make shure that you are on version 4.4)
There is already an issue posted to update to 5.0 but I have no time in the near feature to contribute this (My first try revealed a lot of API changes and new problems).
I'm using the ui-context menue node to do so and even if it brings more effort you get Node-RED in control of the context menu. The [post you already found is still valid]. And there is a cellCotext and a rowContext callback too. ([Announce] node-red-contrib-ui-contextmenu - #55 by Christian-Me)
Here is a partial flow to handle the ui-context-menu. It works together with the callback described in the post above
I'll could not promise anything but I'm still willing to do the upgrade to 5.x - but there are so many possibilities to break things - so I'm a little bit afraid to do this in a rush.
[{"id":"fd36bbc4.fe50d8","type":"subflow","name":"OK/Cancel helper","info":"# OK/Cancel dialog helper\n\n## description\n\nThis is a little helper to make OK/Cancel dialogs easy to implement inside a data stream\n\n## how it works\n\nIf a message arrives at the **imput** a message dialog box is triggered. The original Message is cloned into `msg.dialogHelperOrgMsg`. If the dialog sends `msg.payload` with the **passPayload** the original message is released on the second output.\n\nIf you use the message node \"with input\" enter your cancel payload instead pass payload as `msg.payload` will include the entered text.\n\nmake shure you pass `msg.socketid`of the session you like the dialog to be displayed.\n\n## configuration\n\n- **Title** *optional* a string displayed on the title of the dialog or `msg.dialogTitle`\n- **Message** message to be displayed or `msg.dialogMessage`\n- **passPayload** the `msg.payload` expected on the imput to release to original message.\n- **cancelPayload** if this subflow is used for text imput dialogs enter your cancel payload instead pass payload als `msg.payload` will include the ented text.","category":"","in":[{"x":37,"y":85,"wires":[{"id":"6a44f1d4.72a75"}]}],"out":[{"x":343,"y":85,"wires":[{"id":"6a44f1d4.72a75","port":1}]},{"x":343,"y":136,"wires":[{"id":"6a44f1d4.72a75","port":2}]}],"env":[{"name":"title","type":"str","value":"Please Confirm","ui":{"icon":"font-awesome/fa-comment","label":{"en-US":"Title"},"type":"input","opts":{"types":["str","env"]}}},{"name":"message","type":"str","value":"should the message pass on?","ui":{"icon":"font-awesome/fa-comment-o","label":{"en-US":"Message"},"type":"input","opts":{"types":["str","env"]}}},{"name":"passPayload","type":"str","value":"OK","ui":{"icon":"font-awesome/fa-check-square-o","type":"input","opts":{"types":["str","env"]}}},{"name":"cancelPayload","type":"str","value":"Cancel"}],"color":"#3FADB5","icon":"font-awesome/fa-comments-o","status":{"x":343,"y":34,"wires":[{"id":"6a44f1d4.72a75","port":0}]}},{"id":"6a44f1d4.72a75","type":"function","z":"fd36bbc4.fe50d8","name":"confirm","func":"var status={fill:\"\",shape:\"dot\",text:\"\"};\nif (msg!==undefined && !msg.hasOwnProperty(\"dialogHelperOrgMsg\")) { // no message in queue\n    var dialogMsg={\n        topic:(msg.dialogTitle) ? msg.dialogTitle : env.get('title'),\n        payload:(msg.dialogMessage) ? msg.dialogMessage : env.get('message'),\n        socketid:msg.socketid,\n        dialogHelperOrgMsg:RED.util.cloneMessage(msg)\n    };\n    status={fill:\"yellow\",shape:\"dot\",text:\"waiting for response\"};\n    return [{payload:status},dialogMsg,null];\n} else {\n    var cancelPayload=env.get('cancelPayload').toLowerCase();\n    var passPayload=env.get('passPayload').toLowerCase();\n    if (passPayload!=='') {\n        if (msg.payload.toLowerCase()===passPayload) {\n            status={fill:\"green\",shape:\"dot\",text:\"message passed\"};\n            return [{payload:status},null,msg.dialogHelperOrgMsg];\n        } else {\n            status={fill:\"blue\",shape:\"dot\",text:msg.payload+\"==(!\"+passPayload+\") message droped\"};\n            return [{payload:status},null,null];\n        }\n    } else if (cancelPayload!=='') {\n        if (msg.payload.toLowerCase()!==cancelPayload) {\n            status={fill:\"green\",shape:\"dot\",text:\"message passed\"};\n            msg.dialogHelperOrgMsg.payload=msg.payload; // add input to msg.payload\n            return [{payload:status},null,msg.dialogHelperOrgMsg];\n        } else {\n            status={fill:\"blue\",shape:\"dot\",text:msg.payload+\"==(\"+cancelPayload+\") message droped\"};\n            return [{payload:status},null,null];\n        }        \n    } else {\n        status={fill:\"red\",shape:\"dot\",text:\"pass or cancel payload undefined\"};\n        return [{payload:status},null,null];\n    }\n}","outputs":3,"noerr":0,"initialize":"","finalize":"","x":196,"y":85,"wires":[[],[],[]],"info":"# OK/Cancel dialog helper function\n\n## description\n\nThis is a little helper to make OK/Cancel dialogs easy to implement inside a data stream\n\n## how it works\n\nIf a message arrives at the **imput** a message dialog box is triggered. The original Message is cloned into `msg.dialogHelperOrgMsg`. If the dialog sends `msg.payload` with the **passPayload** the original message is released on the second output.\n\n## envioment variables\n\n- **title** ***optional** a string displayed on the title of the dialog\n- **message** message to be displayed\n- **passPayload** the `msg.payload` expected on the imput to release to original message."},{"id":"e6740516.9b1688","type":"switch","z":"9d52d40a.a63668","name":"callback","property":"ui_control.callback","propertyType":"msg","rules":[{"t":"eq","v":"rowContext","vt":"str"},{"t":"eq","v":"headerContext","vt":"str"},{"t":"eq","v":"cellEdited","vt":"str"},{"t":"eq","v":"columnMoved","vt":"str"},{"t":"eq","v":"columnResized","vt":"str"}],"checkall":"false","repair":false,"outputs":5,"x":179,"y":1530,"wires":[["5bf60e7.23625f"],["f246c2d4.aa89c"],[],[],[]]},{"id":"749057bc.c4a6d8","type":"switch","z":"9d52d40a.a63668","name":"","property":"payload.command","propertyType":"msg","rules":[{"t":"eq","v":"updateDevice","vt":"str"},{"t":"eq","v":"updateDevices","vt":"str"},{"t":"eq","v":"deleteDevice","vt":"str"},{"t":"eq","v":"ignoreDevice","vt":"str"},{"t":"eq","v":"unIgnoreDevice","vt":"str"},{"t":"eq","v":"refreshTable","vt":"str"},{"t":"eq","v":"deleteTable","vt":"str"},{"t":"eq","v":"columnHide","vt":"str"},{"t":"eq","v":"columnsUnHide","vt":"str"},{"t":"eq","v":"columnUnHide","vt":"str"},{"t":"eq","v":"restoreColumnOrder","vt":"str"},{"t":"eq","v":"resetColumnWidth","vt":"str"},{"t":"eq","v":"setResponsiveLayout","vt":"str"}],"checkall":"false","repair":false,"outputs":13,"x":781,"y":1530,"wires":[["28af0304.acdeec"],["28af0304.acdeec"],["c59b8c64.16dc7"],["c59b8c64.16dc7"],["c59b8c64.16dc7"],["c59b8c64.16dc7"],["710ae3ea.b5244c"],["c59b8c64.16dc7"],["c59b8c64.16dc7"],["c59b8c64.16dc7"],["c59b8c64.16dc7"],["c59b8c64.16dc7"],["c59b8c64.16dc7"]]},{"id":"c59b8c64.16dc7","type":"link out","z":"9d52d40a.a63668","name":"toTable","links":["b1750dea.ac9c2","7d2b1b0d.058af4"],"x":950,"y":1530,"wires":[]},{"id":"28af0304.acdeec","type":"link out","z":"9d52d40a.a63668","name":"toAquire","links":["bfbc2876.2e7748","82fc1784.d3c078"],"x":950,"y":1445,"wires":[]},{"id":"13055b32.2932e5","type":"link out","z":"9d52d40a.a63668","name":"toPlugins","links":["b563fdad.d0b7c"],"x":1171,"y":1683,"wires":[]},{"id":"418512d5.1f8b6c","type":"function","z":"9d52d40a.a63668","name":"rowCommand","func":"// as this feeds back to the beginning of the flow it is time for a new message object\n// otherwise new and old data mix\n// all command data fills into a payload so it would unlikly survice verry long ;)\n\nvar msgOut={};\nswitch (msg.topic){\n    case 'unIgnoreDevice':\n        msgOut={\n            topic:msg.payload,\n            payload:{\n                \"command\":msg.topic,\n                \"object\":msg.payload\n            }\n        };\n        break;\n    case 'deleteTable':\n    case 'updateDevice':\n    case 'deleteDevice':\n    case 'ignoreDevice':\n        msgOut={\n            topic:msg.sourceMsg.topic,\n            socketid:msg.socketid,\n            payload:{\n                \"command\":msg.topic,\n                \"object\":msg.sourceMsg.topic,\n                \"$localip\":msg.sourceMsg.payload.$localip,\n                \"$name\":msg.sourceMsg.payload.$name,\n                \"name\":msg.sourceMsg.payload.name\n            }\n        };\n        break;\n    default:\n        msgOut={\n            topic:msg.sourceMsg.rowData.$topic,\n            payload:{\n                \"command\":msg.topic,\n                \"object\":msg.sourceMsg.$topic,\n                \"$localip\":msg.sourceMsg.payload.$localip,\n                \"$name\":msg.sourceMsg.payload.$name,\n                \"name\":msg.sourceMsg.payload.name,\n            }\n        }\n}\nnode.status({fill:\"green\",shape:\"dot\",text:msgOut.payload.command});\nreturn msgOut;","outputs":1,"noerr":0,"x":607,"y":1513,"wires":[["749057bc.c4a6d8","61b6cd67.e87d74"]]},{"id":"4b103b82.d5f934","type":"function","z":"9d52d40a.a63668","name":"colCommand","func":"// as this feeds back to the beginning of the flow it is time for a new message object\n// otherwise new and old data mix\n// all command data fills into a payload so it would unlikly survice verry long ;)\n\nvar msgOut={\n    topic:\"columnRightClick\",\n    payload:{\n        \"command\":msg.topic,\n        \"object\":msg.payload\n    }\n}\n\n// some commands need the column from the prosition where the context menu was triggered\n\nswitch (msg.topic){\n    case \"columnHide\":\n        msgOut.payload.object=msg.sourceMsg.payload;\n        break;\n}\nnode.status({fill:\"green\",shape:\"dot\",text:msgOut.payload.command});\nreturn msgOut;","outputs":1,"noerr":0,"x":614,"y":1564,"wires":[["749057bc.c4a6d8","b6f10d4c.dde98"]]},{"id":"430f3c7c.5622d4","type":"ui_context_menu","z":"9d52d40a.a63668","group":"3e8e6acd.3587c6","order":1,"width":0,"height":-1,"fontSize":16,"position":"msg","xCoordinate":"500","yCoordinate":"450","menu":"msg","outputField":"payload","menuItems":[{"id":"2","icon":"fa-plus-square","label":"unhide all columns","topic":"columnsUnHide","payload":"","payloadType":"str","visible":true,"enabled":true},{"id":"3","icon":"fa-recycle","label":"refresh Table","topic":"refreshTable","payload":"","payloadType":"str","visible":true,"enabled":true},{"id":"4","icon":"fa-table","label":"delete table","topic":"deleteTable","payload":"","payloadType":"str","visible":true,"enabled":true}],"colors":"theme","textColor":"#000000","backgroundColor":"#ffffff","borderColor":"#626262","intervalLength":"2","intervalUnit":"secs","startTimerAtOpen":false,"startTimerAtLeave":true,"stopTimerAtEnter":true,"name":"msgBased","x":410,"y":1615,"wires":[["4b103b82.d5f934"]]},{"id":"f246c2d4.aa89c","type":"function","z":"9d52d40a.a63668","name":"build column menu","func":"msg.menu=[\n    {\n        \"text\": \"update devices\",\n        \"icon\": \"fa-undo\",\n        \"enabled\": true,\n        \"topic\": \"updateDevices\",\n    },\n    {\n        \"text\": \"---\"\n    },\n    {\n        \"text\": \"hide column\",\n        \"icon\": \"fa-minus-square\",\n        \"enabled\": true,\n        \"topic\": \"columnHide\",\n    },\n    {\n        \"text\": \"unhide column\",\n        \"icon\": \"fa-minus-square-o\",\n        \"enabled\": (msg.hiddenColumns.length>0) ? true : false,\n        \"sub\": msg.hiddenColumns\n    },\n    {\n        \"text\": \"unhide all columns\",\n        \"icon\": \"fa-minus-square\",\n        \"enabled\": true,\n        \"topic\": \"columnsUnHide\",\n    },\n    {\n        \"text\": \"---\"\n    },\n    {\n        \"text\": \"restore column order\",\n        \"icon\": \"fa-sort fa-rotate-90\",\n        \"enabled\": true,\n        \"topic\": \"restoreColumnOrder\"\n    },\n    {\n        \"text\": \"reset column width\",\n        \"icon\": \"fa-arrows-h\",\n        \"enabled\": true,\n        \"topic\": \"resetColumnWidth\"\n    },\n    {\n        \"text\": \"rersponsive layout\",\n        \"icon\": \"fa-mobile\",\n        \"enabled\": true,\n        \"topic\": \"setResponsiveLayout\"\n    },\n    {\n        \"text\": \"refresh table\",\n        \"icon\": \"fa-recycle\",\n        \"enabled\": true,\n        \"topic\": \"refreshTable\"\n    },\n    {\n        \"text\": \"clear table\",\n        \"icon\": \"fa-trash\",\n        \"enabled\": true,\n        \"topic\": \"deleteTable\"\n    }\n];\n\nreturn msg;","outputs":1,"noerr":0,"x":379,"y":1564,"wires":[["430f3c7c.5622d4","90341f51.c352c"]]},{"id":"f9962a15.0fb1e8","type":"comment","z":"9d52d40a.a63668","name":"callbacks & context menus","info":"","x":229,"y":1411,"wires":[]},{"id":"5bf60e7.23625f","type":"function","z":"9d52d40a.a63668","name":"build row menu","func":"msg.menu=[\n    {\n        \"text\": \"update device\",\n        \"icon\": \"fa-undo\",\n        \"enabled\": true,\n        \"topic\": \"updateDevice\",\n    },\n    {\n        \"text\": \"---\"\n    },\n    {\n        \"text\": \"delete device\",\n        \"icon\": \"fa-trash\",\n        \"enabled\": true,\n        \"topic\": \"deleteDevice\",\n    },\n    {\n        \"text\": \"ignore device\",\n        \"icon\": \"fa-minus-square-o\",\n        \"enabled\": true,\n        \"topic\": \"ignoreDevice\",\n    },\n    {\n        \"text\": \"unignore devices\",\n        \"icon\": \"fa-plus-square-o\",\n        \"enabled\": (msg.ignoredDevices.length>0) ? true : false,\n        \"sub\": msg.ignoredDevices\n    },\n    {\n        \"text\": \"unignore all devices\",\n        \"icon\": \"fa-plus-square\",\n        \"enabled\": true,\n        \"topic\": \"unIgnoreDevices\",\n    },\n    {\n        \"text\": \"---\"\n    },\n    {\n        \"text\": \"refresh table\",\n        \"icon\": \"fa-recycle\",\n        \"enabled\": true,\n        \"topic\": \"refreshTable\"\n    },\n    {\n        \"text\": \"clear table\",\n        \"icon\": \"fa-trash\",\n        \"enabled\": true,\n        \"topic\": \"deleteTable\"\n    }\n];\n\nreturn msg;","outputs":1,"noerr":0,"x":369,"y":1462,"wires":[["19e8fb55.948665","4b6a4466.69800c"]]},{"id":"19e8fb55.948665","type":"ui_context_menu","z":"9d52d40a.a63668","group":"3e8e6acd.3587c6","order":1,"width":0,"height":-1,"fontSize":16,"position":"msg","xCoordinate":"500","yCoordinate":"450","menu":"msg","outputField":"payload","menuItems":[{"id":"2","icon":"fa-plus-square","label":"unhide all columns","topic":"columnsUnHide","payload":"","payloadType":"str","visible":true,"enabled":true},{"id":"3","icon":"fa-recycle","label":"refresh Table","topic":"refreshTable","payload":"","payloadType":"str","visible":true,"enabled":true},{"id":"4","icon":"fa-table","label":"delete table","topic":"deleteTable","payload":"","payloadType":"str","visible":true,"enabled":true}],"colors":"theme","textColor":"#000000","backgroundColor":"#ffffff","borderColor":"#626262","intervalLength":"2","intervalUnit":"secs","startTimerAtOpen":false,"startTimerAtLeave":true,"stopTimerAtEnter":true,"name":"msgBased","x":410,"y":1513,"wires":[["418512d5.1f8b6c"]]},{"id":"ab78269b.859828","type":"link in","z":"9d52d40a.a63668","name":"callbacksIn","links":["69cccd2b.cae4c4"],"x":66,"y":1530,"wires":[["e6740516.9b1688","620ab579.114dbc"]]},{"id":"b6f10d4c.dde98","type":"debug","z":"9d52d40a.a63668","name":"colCommand","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":801,"y":1649,"wires":[]},{"id":"61b6cd67.e87d74","type":"debug","z":"9d52d40a.a63668","name":"rowCommand","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":811,"y":1411,"wires":[]},{"id":"620ab579.114dbc","type":"debug","z":"9d52d40a.a63668","name":"callback","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":179,"y":1598,"wires":[]},{"id":"edbc167b.5a5748","type":"ui_toast","z":"9d52d40a.a63668","position":"dialog","displayTime":"3","highlight":"","sendall":false,"outputs":1,"ok":"OK","cancel":"Cancel","raw":false,"topic":"","name":"OK / Cancel","x":1226,"y":1598,"wires":[["710ae3ea.b5244c"]]},{"id":"4b6a4466.69800c","type":"debug","z":"9d52d40a.a63668","name":"rowMenu","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":587,"y":1462,"wires":[]},{"id":"90341f51.c352c","type":"debug","z":"9d52d40a.a63668","name":"rowMenu","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":587,"y":1615,"wires":[]},{"id":"710ae3ea.b5244c","type":"subflow:fd36bbc4.fe50d8","z":"9d52d40a.a63668","name":"delete Table?","env":[{"name":"message","value":"Do you realy whant to delete the complete table and all statistics. Cell edits and layout will be preserved.","type":"str"}],"x":1047,"y":1649,"wires":[["edbc167b.5a5748"],["13055b32.2932e5"]]},{"id":"3e8e6acd.3587c6","type":"ui_group","name":"Remote Device Table","tab":"dc3e656c.bbd048","order":2,"disp":false,"width":"19","collapse":false},{"id":"dc3e656c.bbd048","type":"ui_tab","name":"Remote Device Table","icon":"dashboard","order":22,"disabled":false,"hidden":false}]
Thanks my friend @Christian-Me, I will try this and will get back here once done.
Highly appreciated your efforts.
Keep it up!
Regards,
Henjoe
Hi @Christian-Me , apologies, but I got confused on your sample.
Do you have a sample flow where I can see how to use this subflow:
Thanks!
Regards,
Henjoe
Hi @Christian-Me , I get it now! :slight_smile:
Thanks for your help!
node-red-ui-contextmenu is the key in here, just need that X and Y position. :slight_smile:
Again!
Regards,
Henjoe
Do you still need help for the notification helper subflow? This is handy to work with popup alert and input windows.
Hi Christian,
Might as well can I have samples on how to use this helper subflow. Sounds interesting :slight_smile:
Thank you!
Sure.
The task is to hold up a message until the user confirms to proceed.
the subflow is configured like this
the connected message node like this
How it works:
The subflow packs the incoming message into a new message to the message node and sets the title and display text. If the passPayload equals the result OR the cancelPayload is not equal the result the original (incoming) message is sent out the second output.
Beside the subflow config dialog you can send msg.dialogTitle and msg.dialogMessage with the incoming message. If a socketid is passed the dialog opens only on this client.
Note: If a second message arrives before the first is confirmed the first is message is dropped and a new popup opens.
So an easy reusable way to stop messages until the user confirms to pass. Perhaps it is useful for others too.
Here is a test flow, have fun:
[{"id":"fd36bbc4.fe50d8","type":"subflow","name":"OK/Cancel helper","info":"# OK/Cancel dialog helper\n\n## description\n\nThis is a little helper to make OK/Cancel dialogs easy to implement inside a data stream\n\n## how it works\n\nIf a message arrives at the **imput** a message dialog box is triggered. The original Message is cloned into `msg.dialogHelperOrgMsg`. If the dialog sends `msg.payload` with the **passPayload** the original message is released on the second output.\n\nIf you use the message node \"with input\" enter your cancel payload instead pass payload as `msg.payload` will include the entered text.\n\nmake shure you pass `msg.socketid`of the session you like the dialog to be displayed.\n\n## configuration\n\n- **Title** *optional* a string displayed on the title of the dialog or `msg.dialogTitle`\n- **Message** message to be displayed or `msg.dialogMessage`\n- **passPayload** the `msg.payload` expected on the imput to release to original message.\n- **cancelPayload** if this subflow is used for text imput dialogs enter your cancel payload instead pass payload als `msg.payload` will include the ented text.","category":"","in":[{"x":37,"y":85,"wires":[{"id":"6a44f1d4.72a75"}]}],"out":[{"x":343,"y":85,"wires":[{"id":"6a44f1d4.72a75","port":1}]},{"x":343,"y":136,"wires":[{"id":"6a44f1d4.72a75","port":2}]}],"env":[{"name":"title","type":"str","value":"Please Confirm","ui":{"icon":"font-awesome/fa-comment","label":{"en-US":"Title"},"type":"input","opts":{"types":["str","env"]}}},{"name":"message","type":"str","value":"should the message pass on?","ui":{"icon":"font-awesome/fa-comment-o","label":{"en-US":"Message"},"type":"input","opts":{"types":["str","env"]}}},{"name":"passPayload","type":"str","value":"OK","ui":{"icon":"font-awesome/fa-check-square-o","type":"input","opts":{"types":["str","env"]}}},{"name":"cancelPayload","type":"str","value":"Cancel"}],"color":"#3FADB5","icon":"font-awesome/fa-comments-o","status":{"x":343,"y":34,"wires":[{"id":"6a44f1d4.72a75","port":0}]}},{"id":"6a44f1d4.72a75","type":"function","z":"fd36bbc4.fe50d8","name":"confirm","func":"var status={fill:\"\",shape:\"dot\",text:\"\"};\nif (msg!==undefined && !msg.hasOwnProperty(\"dialogHelperOrgMsg\")) { // no message in queue\n    var dialogMsg={\n        topic:(msg.dialogTitle) ? msg.dialogTitle : env.get('title'),\n        payload:(msg.dialogMessage) ? msg.dialogMessage : env.get('message'),\n        socketid:msg.socketid,\n        dialogHelperOrgMsg:RED.util.cloneMessage(msg)\n    };\n    status={fill:\"yellow\",shape:\"dot\",text:\"waiting for response\"};\n    return [{payload:status},dialogMsg,null];\n} else {\n    var cancelPayload=env.get('cancelPayload').toLowerCase();\n    var passPayload=env.get('passPayload').toLowerCase();\n    if (passPayload!=='') {\n        if (msg.payload.toLowerCase()===passPayload) {\n            status={fill:\"green\",shape:\"dot\",text:\"message passed\"};\n            return [{payload:status},null,msg.dialogHelperOrgMsg];\n        } else {\n            status={fill:\"blue\",shape:\"dot\",text:`${msg.payload}!==\"${passPayload}\" message droped`};\n            return [{payload:status},null,null];\n        }\n    } else if (cancelPayload!=='') {\n        if (msg.payload.toLowerCase()!==cancelPayload) {\n            status={fill:\"green\",shape:\"dot\",text:\"message passed\"};\n            msg.dialogHelperOrgMsg.payload=msg.payload; // add input to msg.payload\n            return [{payload:status},null,msg.dialogHelperOrgMsg];\n        } else {\n            status={fill:\"blue\",shape:\"dot\",text:`${msg.payload}==\"${cancelPayload}\") message droped`};\n            return [{payload:status},null,null];\n        }        \n    } else {\n        status={fill:\"red\",shape:\"dot\",text:\"pass or cancel payload undefined\"};\n        return [{payload:status},null,null];\n    }\n}","outputs":3,"noerr":0,"initialize":"","finalize":"","libs":[],"x":196,"y":85,"wires":[[],[],[]],"info":"# OK/Cancel dialog helper function\n\n## description\n\nThis is a little helper to make OK/Cancel dialogs easy to implement inside a data stream\n\n## how it works\n\nIf a message arrives at the **imput** a message dialog box is triggered. The original Message is cloned into `msg.dialogHelperOrgMsg`. If the dialog sends `msg.payload` with the **passPayload** the original message is released on the second output.\n\n## envioment variables\n\n- **title** ***optional** a string displayed on the title of the dialog\n- **message** message to be displayed\n- **passPayload** the `msg.payload` expected on the imput to release to original message."},{"id":"b2689755.7e7e48","type":"subflow:fd36bbc4.fe50d8","z":"9d52d40a.a63668","name":"pass message?","env":[{"name":"message","value":"Let the message pass?","type":"str"}],"x":726,"y":1955,"wires":[["84e70024.bd2e1"],["fb2a3c99.ecc46"]]},{"id":"84e70024.bd2e1","type":"ui_toast","z":"9d52d40a.a63668","position":"dialog","displayTime":"3","highlight":"","sendall":false,"outputs":1,"ok":"OK","cancel":"Cancel","raw":false,"topic":"","name":"OK / Cancel","x":954,"y":1904,"wires":[["b2689755.7e7e48"]]},{"id":"333e900c.2ef9a","type":"inject","z":"9d52d40a.a63668","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"test message","payload":"","payloadType":"date","x":484,"y":1955,"wires":[["b2689755.7e7e48"]]},{"id":"fb2a3c99.ecc46","type":"debug","z":"9d52d40a.a63668","name":"confirmed msg","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"msg","x":964,"y":2006,"wires":[]}]
Thanks ! Christian!
Highly appreciated your effort in here! :slight_smile:
Regards,
Henjoe
Hi @Christian-Me ,
do you have sample subflow on how to use this sub flow?
https://flows.nodered.org/flow/35d0480ce9151b2a722fa9d185a37825
I want to get in JSON format all the data on my table, so that I can use it to store my data into variables or etc.
Regards,
Henjoe
